Question about Kenmore 24 in. 17482 / 17484 / 17489 Built-in Dishwasher
My kenmore dishwasher drain rinsh water slow - Kenmore 24 in. 17482 / 17484 / 17489 Built-in Dishwasher
  • Kenmore Master
  • 43,501 Answers
Here is a tip that I wrote that will help you with your dishwashermy kenmore dishwasher drain rinsh - 2_bing.gif not draining problem...
Dishwasher2_bing.gif Problems - Water will not drain out
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
heatman101
Posted on Jul 12, 2010
  • 460 Answers
I hope this solve your problem
http://www.youtube.com/watch?v=nr6tIO5iNSc
Was this helpful?
Posted on May 13, 2009
Wont drain
Here is a tip that I wrote that will help you with your dishwasher2_bing.gif not draining problem...
heatman101
Jun 06, 2010 | Kenmore 24 in. 15079 Built-in Dishwasher
New washer draining out while washing or rinshing
If this is a brand new unit, make sure that the drain hose is hooked up at a level at or above the level of the tub. If it is too low, it can siphon the tub of water.
Apr 30, 2010 | GE WSM2480DWW Unitized Spacemaker Washer...
Dishwasher does not fill
Double check that your water supply line is not kinked.
This sounds like a bad fill valve. If you have hard water and most everyone does after a few years the valve will quit working properly and will fail in one of 2 ways a slow or no fill or it will not shut off completely.
I hope this helps if I can help with anything else please let me know.
Apr 15, 2010 | Kenmore 24 in. 16003 Built-in Dishwasher
WATER NOT DRAINING OUT OF DISHWASHER AND SEEMS TO GO
This happened to me. Go to your local Lowes, Home Depot, etc and get some disposal claner. Clean the garbage disposal and see if that helps
Feb 19, 2010 | Kenmore 24 in. 17032 Built-in Dishwasher
Older kenmore warsher, Model num 110.14202300. not drain or spin
If it won't drain or spin check the lid switch. If it sounds like the motor is running when in spin check the coupler between the motor & and the transmission will have to pull the motor to get to it.two plastic parts with a rubber piece between them.
Jan 02, 2018 | Kenmore Washing Machines
Water keeps coming back into dishwasher after cycle is done
sounds like maybe one of your check valve is not working right.
Jun 03, 2009 | Dishwashers
While not in operation dishwasher slowly fills up.
water valve is clogged try to turn your valve to dishwasher under sink
Nov 29, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Kenmore Ultrawash QuietGuard 3 Dishwasher not draining or rinsing
Hi Claire,
Are you using rinse aid?
that may help with the film.you may also have stuff down in the trap causing the water to drain slow.
Nov 05, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Dish washr
Can you access the drain hose without moving the dishwasher out? Is it close to the garbage disposal. You probably have a plugged drain. I would begin by plugging the sink that the garbage disposal is in and filling it full of hot water. Then I would unplug it and turn on the disposal and continue running water in it. This should clean the disposal drain well.
If you can access the dishwasher drain hose, you will need to disconnect it and look for a plug. If you can unplug the dishwasher do this first. It may be hardwired in, but some are not. It will all be behind the adjacent cabinetry. Have towels and a bucket handy. It is a good idea to always run some water through the disposal after running the dishwasher (they usually drain into that sink.)
If you cannot access the drain, I would clean the disposal and check all other household drains for slow drainage before calling a plumber. or your dishwasher repairman.
Good luck to you and thank you for using Fix Ya.
Aug 22, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Kenmore dishwasher
fatubu, are you sure you have the correct model number, Im not finding anything on the posted model. They had an issue on models close to this that had an issue with a twisted or missing seal in the pump assy. causing water to fill the pressure switch hose. The dishwasher would drain water after the fill. The fix was to replace the pump and motor assy. Catriver..post back.
Feb 18, 2007 | Kenmore 24 in. 16032 Built-in Dishwasher
Kenmore 24 in. 17482 / 17484 / 17489 Built-in Dishwasher Logo
100 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
