Question about Toshiba Satellite A15-S129 Notebook
LCD screen is blank when lap top is on
I have a Toshiba A15-S129 notebook. When the power is on, the LCD screen is blank..nothing. I tried the tips listed in the troubleshooting guide for my model(hold Fn down and press F5 repeatedly), however, the screen still remains blank. The only thing I have not tried is to see if the "hinge" is hanging up..Do I have to take the screen apart to do this? Any suggestions on how to get my picture back on the screen? Thanks...
  • 7 more comments
  • steve1043 Sep 24, 2007
    After posting my problem with the LCD screen on the Toshiba Satellite laptop, I located a solution which worked from a different laptop model. I checked the memory chips to make sure they were clean and didn't come loose. After reinstalling the memory, laptop has been working great and my LCD screen is working properly...thanks for the help!
  • bossynurse Dec 25, 2007
    This is very irritating. I am having this problem with winbook si. Same thing. Goes to boot up and can't get it to stay on. try toggle f1 and f2, nothing except f1 comes on for 1 second then black again. wondering about the hinge deal, but also maybe hardware problem. tried cleaning f1 key, no help. afraid to try other. any help appreciated, poor student. thanks !
  • Anonymous Jan 18, 2008
    I had exactly the same problem on our new Satellite and Steve1043's solution worked. Just took off the memory cover, pushed on the memory cards to make sure they we in place, put the cover back on and it was fixed. Thanks.
  • NKSK Feb 16, 2008
    we plug in our laptop - it says its on and the screen is completly black. Tried clicking all different keys - still nothing.
    Thanks
    Nancy
  • NKSK Feb 16, 2008
    I will try holding down the Fn key and click the Fn5 key - I hope that works - what is the hinge thing......
    Thanks
  • Anonymous Feb 29, 2008
    yes
  • nightvision Mar 11, 2008
    yes i do i have the dell latitude d810 when i turn it on all i get is a blank screen
    my problem is the same as i mention on my other posted message i did not mention i did connect to a monitor and it did boot up and ask me to type a password i do not know it and i don't have a windows boot up recovery disk i did look underneth the lap top open a panel and found on the left side something missing maybe mem of what ever again i have a dell latitude d810
  • MrMark Jul 21, 2013
    I've determined it's a hinge/ribbon cable problem. Now what?
  • 150 Answers
I would suggest ensuring it's not video chipset. You have a VGA (monitor) conenctor on the back of that, plug in a regular computer moniter and see if it works. If it boots on the monitor you know it's a display problem(hinge,ribbon cable), if it still doesn't boot, it's a hardware problem(video card, main board). Let me know what happens, try cleaning the hing with rubbing alchol & a q-tip Good luck Hope this Helps!
Posted on Sep 23, 2007
    Scholar:
  • 68 Answers
My soultion may be costly. The reason I say that is taking apart a lap top is no walk in the park. In many cases you will need special tools plus if you pull one part to far you might rip the delicate cable that sends the signal to your lcd screen. When it comes to lap tops and hardware problems its better to leave it to the manufacture to fix. I know this is not a solution but I just want to give you a heads up of what kind of problems you will run into if you try to fix it yourself. I would call manufacture see if there is a recall or somekind of tech service. Then you will be rest assured that it will be repaired properly and there will not be more problems that you caused when you opened it up.
SOURCE:
I replaced motherboard on my Toshiba A15 - S129 and now y model is A10. Is it possible to change that to A15. I can't use restore CD because of that. Please help.
You need to run the dmi utility. if you go on toshiba's support site it should be there. if not email me and i will send it to you.
Nov 04, 2009 | Toshiba Satellite A15-S129 Notebook
DC power light is blinking orange on my Toshiba Satellite a15-s1292. Nothing else is working.
In general this indicates a problem with the power supply, this a very difficult error code to decipher unless you are familiar with hexadecimal code. I suggest you contact Toshiba Technical Support.
Sep 23, 2009 | Toshiba Satellite A15-S129 Notebook
Toshiba laptop does not run, just amber light blinking
Did the computer ever work? Have you checked that your memory is properly seated? Remove the bottom plate that reveals the memory modules, pop both loose then back in. Try to restart. Is the battery fully seated?
Sep 18, 2009 | Toshiba Satellite A15-S129 Notebook
Toshiba Satellite A15-S129 PC Notebook
Have you turn the wireless antenna switch on?
Mar 31, 2009 | Toshiba Satellite A15-S129 Notebook
Screen blank when turned on
Hi, Replace it, the LCD is damage...
Jan 10, 2009 | Toshiba Satellite A15-S129 Notebook
DVD Rom
try re-installing the device drivers to sort the problem
Nov 18, 2008 | Toshiba Satellite A15-S129 Notebook
I can't Get the Drivers i need i don't know where to look!!!!!!
S129 "A"? Found nothing on Tohiba web site, but this must be S129 or S1291. Go to:
http://www.csd.toshiba.com/cgi-bin/tais/su/su_sc_modSel.jsp
and choose your model (there is a label on the bottom with the correct model number, right?).
When you choose "Show results" you will end up in a page where you can get drivers and manuals.
Good luck
Oct 15, 2008 | Toshiba Satellite A15-S129 Notebook
Acer aspire 4310 lcd
its fine....
try replacing Display driver,
Mar 17, 2008 | Toshiba Satellite A15-S129 Notebook
Compaq presario v2000 notebook will not boot up blank sreen
If it is working fine with AC Adaptor, change your battery it need replacement.
Feb 09, 2008 | Toshiba Satellite A15-S129 Notebook
Toshiba Satellite A15-S129 Notebook Logo
235 people viewed this question
Top Toshiba Computers & Internet Experts
Ekse
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
