Question about Kenmore 50522 / 50524 Side by Side Refrigerator
Ice buildup on floor of side by side freezer floor..
When auto-defrost kicks on water comes out the door onto kitchen floor...there is a recessed depression on the freezer floor which fills with ice.this started about a year after we bought it...pleeze help...SMITTY
  • mbiff218 Apr 26, 2009
    ice build up on bottom of freezer, removed the ice now it is not getting cold enough to freeze and the refridgerator is not getting cold either
  • patel_ashesh May 04, 2009
    pls advice for same issue i have.I cleaned tube
  • 358 Answers
Inside the freezer in the lower part of the back wall there's a drain hole wich probably is clough and the water from defrost doesn't go through and freezes up .Put hot water to defrost it and keep pooring it until goes through.If is still clogh try with a wire but do it ery carefull to not put a hole in the drain plstic tube.
Posted on Apr 22, 2009
Water is building up on bottom of fridge
If you have water build-up on the floor of the food compartment, or ice buildup on the floor of the freezer compartment, you are probably suffering from either a frost problem or from a clogged defrost drain.
Remove everything from your freezer, including all food and any shelves. Do not remove the icemaker (if installed.)
Look at and feel the panel covering the bottom or back of the freezer compartment. Is it thick with frost?
On top freezer models, are the holes in the top of the food compartment that lead to the evaporator choked with ice?
Is there ice forming on, or lots of water on the ceiling of the food compartment?
If the answer is yes to any of these questions, there's probably a defrost problem.
If you suspect a defrost problem, first remove any icemaker that may be installed. You will see a removable panel covering the entire back or bottom of your freezer compartment. There may be 6 to 10 or more screws holding it on. In some units there is a light socket attached to the panel; you'll see this arrangement most often in side-by-sides.
If you start to get an unusual buildup of ice in one particular spot in your freezer, especially beneath the icemaker, check for water leaks.
Water leaking onto the kitchen floor not traceable to one of the problems in Chapters 4 or 6 may be from a leak in the icemaker or door dispenser water system. Icemakers have a water solenoid valve mounted on the back of the fridge, usually behind the back bottom panel, and a water tube that leads straight up the back of the fridge to the icemaker. Door dispensers have a similar water solenoid valve with a water tube that leads beneath the fridge and into the door through a hollow hinge. If your fridge has both features, it's usually a dual water solenoid valve. It can be simple or not-so-simple to fix, but basically it's just a plumbing job.
Jun 13, 2016 | Refrigerators
Tdc18paaaww leaking ice buildup
Is this auto-defrost model? Usually, heating element that defrosts the ice in back of freezer can go bad. How old is the model?
Dec 29, 2013 | GE Profile 22.2 Cu. Ft. Bottom-Mount...
GE Monogram bottom freezer leaking water from left side onto the freezer floor and onto hardwood floor of the kitchen . Already tried totally defrosting freezer and that did not solve problem. Help!!
ck the drain in the back of freezer . it may be pluged and when it goes into defrost cycle you get about a cup of water on the floor . if there ice on bottom of freezer then the drain is iced over . some models require a drain heater to prevent this . mm hope this helps ..
Oct 14, 2010 | GE Monogram ZICS360NR Bottom Freezer...
My Maytag side-by-side refrigerator/freezer Leak
There is a pan and drain hose under the freezer coil that is there to catch any water when the freezer goes into defrost. I feel strongly that is where you will find your leak.
I hope this helps.
Apr 19, 2010 | Maytag MSD2756G Side by Side Refrigerator
When the auto defroster comes on, the water is running out of the freezer onto the floor. What could be wrong?
defrost drain clogged. in bottom of freezer at back area..hot water,clear ice..1 tablespoon full of automatic dishwaher detergent, put in drain,wait, flush with hot water
Oct 17, 2009 | GE GSL25JFPBS Side by Side Refrigerator
Ice Buildup in Bottom of Freezer
Hi: The tube in the back of the freezer is not clogged with ice. It is most likely clogged with mold below the freezer section just above the warm tray where the defrost water evaporates. Also a pea or other piece of debris could have gotten in there. Do your thawing again and pour some clorox water through it and use a pipe cleaner if it's a tough clog. I hope this helps, Jeff
Jun 01, 2009 | GE 25.2 cu. ft. Side-by-Side Refrigerator...
Ice buildup on freezer floor.auto defrost puts water on floor
You have a clogged drain. If you have a top mounted freezer you might have the drain line on the outside of the fridge. Look for a tube that is thicker than the water intake line and goes from back of bottom of freezer down into the back of the unit to a drain pan. Remove that tube and take it outside and use your hose to shoot a stream of water to clean it out.
If you have a side by side fridge, your drain is still at the lowest point at the rear of your freezer. You may have to removed the rear wall of the freezer to get at it. Remove the back cover to get at the other end of the drain tube. It needs to be cleaned out also.
Apr 22, 2009 | Refrigerators
Water Freezing in bottom of Freezer and dripping out front of freezer door
this could either be a blocked drain from the freezer not allowing defrost water to escape or the defrost heater failing to turn on due to a faulty defrost heater or defrost timer not enabling the water to escape
Aug 12, 2008 | Frigidaire FRS26KF5C Side by Side...
Defrost Problem
there is a drain in the middle of the defrost water collector and it is probably blocked - usually with ice. dry ot the tray and put very hot water in to melt the ice. you may have to do several times. do this until water flows away freely
Jul 25, 2007 | Maytag MSD2756G Side by Side Refrigerator
Kenmore 50522 / 50524 Side by Side Refrigerator Logo
283 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
