all the dash warning lights are on and the rpm gauge and temp gauge go on and offall the dash warning lights are on and the rpm gauge and temp gauge go on and off
You can't post conmments that contain an email address.
Many times, When electrics act up. it has to do with a ground problem. Fuses must be good you have power. Auto electrics like to have a single wire running to the device and then depend on a ground near by to grounded steel instead of a return wire. Loose grounds have no return and the device acts crazy and will be erratic, and not act properly. No where for the electricity to go. Eliminate the possibility of bad or missing grounds first, then get out an electric volt ohm meter, Start checking voltage, and eliminating things that have proper and constant voltage. Then look for bad devices. Just trying to save you some money. Electrical Trouble shooting can be time consuming and expensive. You can do it. lbreen
all fuses all boxes checked. cab and engine bay?
well we scan all modern cars first./ it will show DTC errors. like dead cluster communications? or?
do not skip scans on cars, or go broke guessing endlessly.for sure.
a guess
thats a lot of sensors to fail all at once
may need an auto electrician
.any fuses blown
if happened all at once
voltage overload/spike from alternator regulator
or huge short / wire loom melt ....
Recalls only go back ten years. since you are having other dash problems, it probably time to replace the dash panel. They have computer chips in them that run most all the gauges and warning lights. I would get one from the salvage yard. they can tell you what years will work in the van
A good place to get wiring schematics for your vehicle is at the Auto Zone web site. It is free to use, the only thing you have to do is register.
Good luck.
regards,
Hello:
you will need to check the fuel pressure to see if your getting fuel, then pull off a spark plug wire and check for spark (spark should be blue) start there and this will help determine your problem.
Good luck
On thedash of my 2003 sedan sebring ,My dash ilumination lights for the speed,temp,tack\rpm and fuel are unlit.
I found that there is a paper thin plastic across and behind all four of these gauges which lights up all four gauges,if working correctly, There is a very poor connection to this thin film lighting system ,basicaly a wire terminal used as a staple and that very well could be your problem.
It as far as I know would require whole gauge assembly replacement! because dealers dont sell such small portions of some assemblies!
I myself will attempt to crimp this poor connection on my car without damaging thin film! there are no bulbs for those four gauges too iluminate!
