Question about Antec TVator Pro (64130-2)
Lost original ac adapter for Antec TVator Pro. Requires 9v dc supply. Is center pin + or - ?
  • Anonymous Apr 25, 2009
    only need to know what the voltage and millamps are - then can buy at any radio shack. do you have the manual? if so, please tell me voltage and amps since they did not mark this info on the power port
  • 525 Answers
Very carefully open unscrew the equipment and follow the path of your power , you will see inside a capacitor , if the +of that capacitor is connected to the center , then the plus will be in center
Posted on Aug 14, 2009
Center is (+) Positive...
Posted on Aug 16, 2009
Power supply
Yes you can, but there are 2 important considerations. One is if the adapter puts out AC or DC signal. Adapters may have the same plug on them and putting the wrong one on could permanently damage your equipment. The other thing to look for is amperage, or an A rating. You may see something like 9V DC 2A on an adapter. If you are replacing a damaged adapter, look on it before you try a new one. Most all adapters have printed on them, by the plug, what their voltage, amperage, and AC or DC output are. Try to get the closest possible match. If you are off a bit on the amperage, the equipment may still work, but may act sluggish, or not like it is powered up all of the way. You could still damage the equipment this way too, so do be careful.
Mar 20, 2014 | Behringer Audio Players & Recorders
I lost my adapter to my keyboard and I need to find either a substitute or a new way to turn it on without the adapter, HELP!!!.
Some Casio Keyboards use 9V DC (center negative) others 12V DC (center negative).
If check what voltage your Keyboard use. Generic AC adapters are usually center positive. So you have to invert the wire with a new DC plug to make it center negative,
Easiest is to buy a Casio ac adapter made for your keyboard from a Casio retailer.
Sep 12, 2013 | Casio Keyboard Power Adapter
Need spec and power supply for this set of speakers "Juster DC-691P"
Speakers (External, Powered), (Adapter, 9V, -Outer, +Center) Juster DC-691PASpeakers (External, Powered), (Adapter, 9V, -Outer, +Center) JusterDC-691PA
Sep 08, 2010 | Juster AC-691 Computer Speakers
Where do I buy a spare power adapter pa-225
For those who run across this situation, don't add to the land fill if you can fix it. The majority of the problems with the PA-225 and 226's, is the DC plug connector that connects to the MX-1. That plug's connections are 4 pins and one thru-hole terminal that's meant for the center wire, ground line connected to the plugs metal jacket, which is the ground for both 5 and 12 volt lines. The problem is that during assembly, they miss getting the wire through the eyelet of the ground terminal and solder it anyway, which usually creates an intermittent or permanent disconnection later. Although this can happen for the pins, the main culprit is this ground connection. When this becomes disconnected, the LED will Blink indicating a problem. Normally the LED is a solid orange. The plug's molding can be cut (spit in half) and slid back to expose the plugs ground terminal. The inside molding can be cut/chipped away in if need be to expose the ground line. You might need a really good mag lens to show the fault. I took some pictures and created a pdf on what I found but haven't posted any where. If all else fails, you can order one from Antec. However, beware that the connector used on the replacements will most likely not be the same as the originals. So, if your supply is really DEAD, keep it for the 4 pin male connector, and check out this Antec Online Store for their replacement. Also be aware that I've discovered that the original supplies, two of the pins are used as one 12v supply, and the other two pins are the 5 volt supply with the plugs metal jacket as the ground for both. The original supply's labeling is incorrectly pictures as each pin pair being both positive and negative, with the metal jacket not connected. Make sure that this your next supply does not ground to any of these pins, only to the jacket. The motherboard inside the MX1 connects each pin pair together for a positive terminal only, therefore, if you get a supply incorrectly matching, you can toast a new supply. If you look at the male connector from the original supply with the plastic key "top". The left pin pair is 12VDC, and the right pair is 5VDC with the metal jacket as ground for both. Good luck.
http://store.antec.com/Product/accessory-spare_parts/mx-1-power-adapter/0-76
1345-30290-6.aspx
Sep 23, 2009 | Computers & Internet
Does it need a power supply to work?
Yes it requires a AC to DC power supply putting out 9 volts.
Aug 04, 2009 | Antec TVator Pro (64130-2)
Atari 2600 Console Power Adapter
The Atari 2600 adapter has the following information on it:
Input: 120V AC 60Hz 12W
Output: 9V DC 500mA
Positive tip
Make sure you test the power supply before you use it. I have 2 original atari power supplies, and they are both putting out about 15V DC, which may be why my atari's aren't working anymore!
Anubis
Jan 05, 2009 | Atari 2600 Console
GP4101 Powere Supplay
The Ultra AC Adapter has the following output specification.
Rated Output Voltage - 9 Volts DC at 200 Milliamps to 1.3 Amp Max
Center of pin Positive
Pin Size
Length - 9.5 mm
Width - 5.5 mm
Center Hole - 2.1 mm
Sep 03, 2008 | Gyration Ultra Cordless Optical Mouse
Power - AC Adapter
12 volts DC-1 amp
center pin is +
Mar 13, 2008 | V-Stream Xpert 1280x1024 LCD TV Box...
Antec TVator Pro (64130-2) Logo
343 people viewed this question
Top Antec Televison & Video Experts
Are you an Antec Televison and Video Expert? Answer questions, earn points and help others
