Question about Palm Tungsten E Handheld
Tungsen E Having problems with getting ebooks onto my device. Have 32k MMC but device telling me there's lots of memory left but basically when I try to transfer from PC to palm via docs to go it doesn't work and I get a message saying not enough memory. The card doesn't have enough space for the ebook trying to transfer but the palm does but won't accept it...am I missing software?? I bought the palm second hand and it already had 2 ebooks on it so totally confused! Any help would be really appreciated.
  • Anonymous Nov 18, 2007
    MemoryMgr.c,Line:3823,non-word aligned handle
  • 8 Answers
SOURCE: Hotsync problem
With a USB 1.1 machine .. try this ...My work around - disconnect ALL USB devices from the computer, NO multiport hubs, make a direct USB connection to one of the available open ports, then reboot the computer. Upon gaining control, then try to hotsync. If I had any other items connected or ran any other programs prior to hotsync, I was not able to perform a successful hotsync. The qwerks of the T5 and the sync conduits. Hope this helps Bob
Posted on Aug 10, 2007
  • 171 Answers
SOURCE: Trying to insert a 2gb expansion card into my palm
A lot of palm haldhelds only support SD cards up to 1gb. The 2gb and up ones are not supported. So check your manual and figure out waht the maximum size of sd card is in your palm, or try a smaller size SD card.
Posted on Feb 04, 2008
quakefiend
  • 15 Answers
SOURCE: USB Device Not Recognized for Palm Treo 680
if you are using Vista ultimate, it is a 64 bit operating system and therefore palm doesn't have official support for it yet, but someone has found a solution:
http://forums.palm.com/palm/board/message?board.id=windows_hotsync&thread.id=17980
Posted on Jul 19, 2008
SOURCE: Palm 755P Freezes
Well, thank God I had done a recent Hot sync! I found out how to do a hard reset by holding down the power button while reinserting the battery then letting the button go and the system will ask if you want to erase all data? I put yes! Then it erases all my data and restarts the phone. I had to plug the phone in to be recharged because the looping ultimately drains the battery. Then, I plugged in the Hot sync cable and pushed the button to start the sync and ta da! back to its working state! Yippee! Do it! It's easy! Just make sure to hot sync often so your info stays current!
Posted on Sep 19, 2008
  • 62 Answers
SOURCE: Error in Palm Desktop on PC
You need version Palm desktop v6.2 (not v4) to run under Vista. If you have the 64 bit version of Vista you will have to use Bluetooth to transfer data, not USB. Enjoy and please rate this post.
Posted on Mar 23, 2009
Memory not readable by PSP or Computer. HelP!
Dear Friend,
you have to check the Following
  • Make Sure Your MMC is NOT PASSWORD PROTECTED
  • Your Card Reader properly Connected to PC(Make Sure GOOD in Condition about the Reader)
  • Properly Inserted MMC to READER
  • Change USB port if Still Not Detecting
  • Try another MMC to Reader
  • Reinsert your MMC
  • Reboot your PC
Remove Lock of MMC(Lock might be in Left Side of Your MMC).Still you have Problem Please Change your CARD READER/MMC ...
YOu are done...Solved.....
IS this HelpED you ... Do RaTe mE...
you can Feel Free contact me... Thanks for Using FixYa
Apr 04, 2010 | Sony 4GB Memory Stick PRO Duo Memory Card
Having a lot of memory but showing no space
If you have a memory card installed, backup your contacts to the memory card, then remove it. type this code onto your phone *#7370#, phone will ask you for security code, enter 12345(default) and wait. when it restarts, all problems will be gone. insert your MMC again and restore your contacts.
hope it helps.
Dec 03, 2009 | Nokia N70 Cellular Phone
Actually, I am having this problem with 2 memory cards that i have been using for a while. All of a sudden I cant access the pics. It wont autorun, and when I try to go directly to the drive I get the...
The possible cause of issue is file corruption or virus infection, scan your MMC cards for any virus infection or format it using the device in which you use it.
Jul 02, 2009 | SanDisk 4GB Memory Stick PRO Duo Memory...
Sd mmc corrupted after formating also it show mmc corrupted so how to reprogramme sd mmc file system or how can it will be repair
bro... i'm warren from philippines... try my solution... insert you mmc to your reader and connect it to your personal computer (USB).. if your computer is having a problem to open that removable drive its ok.. don't worry about that i have solution with that later... then if your computer is having a problem detecting your removable drive be sure that you reader is working correctly.. if your reader is working maybe your mmc is broken...things you do.. REPLACE IT..!!! lets go back in other solution, if your computer is having a problem to open that removable drive (it means your memory detects by your computer) try LOW LEVEL FORMAT YOUR MEMORY CARD..install a low level format to your computer then format that mmc, then insert to your cellphone and format it to FAT..
here's the link for low level format tool...
http://hddguru.com/download/software/HDDGURU-Low-Level-Format-Tool/LLFsetup.2.36.1181.exe
i hope this solves your problem..
e-mail me at squeeker_2314@yahoo.com.ph if theres anything.. ^_^
i post this solution to another problem here in fixya..because his problem ad your problem has the same solution..
Oct 28, 2008 | Nokia 6680 Handheld
N70 mmc corrupted and can't be formated
in ur phone go to Tools ,memory,options and Format memory card.....
It will work......!!!!!!
Oct 01, 2008 | Nokia N70 Cellular Phone
good day
try replaceing it with a new mmc from a reliable brand. be sure not to scratch the contact points of your mmc card
Nokia N70 wont acknowledge memory card?
Note: This device uses a Reduced Size Dual Voltage
(1.8/3V) MultiMediaCard (RS-MMC). To ensure
interoperability, use only dual voltage RS-MMCs. Check
the compatibility of an RS-MMC with its manufacturer or
provider.
Use only compatible Reduced Size MultiMediaCards
(RS-MMC) with this device. Other memory cards, such as
Secure Digital (SD) cards, do not fit in the memory card
slot and are not compatible with this device. Using an
incompatible memory card may damage the memory card
as well as the device, and data stored on the incompatible
card may be corrupted.
You cannot use the memory
card if the door of the
memory card slot is open.
Format a memory card
When a memory card is reformatted, all data on the card
is permanently lost.
Some memory cards are supplied preformatted and others
require formatting. Consult your retailer to find out if you
must format the memory card before you can use it.
To format a memory card, select Options > Format mem.
card
. Select Yes to confirm. When formatting is complete,
enter a name for the memory card, and select OK.
Apr 03, 2008 | Nokia N70 Cellular Phone
Memory card problem
i think the MMC card is the prob' try to format it first, if you still having the same prob.
try to change MMC....
Mar 08, 2008 | Nokia N70 Cellular Phone
Memory card of nokia n72
its better to buy a new cellphone and memory card mama
Feb 13, 2008 | Nokia N72 Cellular Phone
Phone not working properly
try to remove your memory card'
and resset your phone,
and after you resset your phone'
don't yet put your MMC try it if the slowly is fix'
and turn off your phone and put your MMC,
if your phone is slowly again
you should have to Resset your phone again and format your MMC in PC and turn it off again your phone'
insert your MMC and turn it on and format your MMC in your N73 mobile... i hope thix procedure will help your prob.
fixyah......
Jan 21, 2008 | Nokia N73 Cellular Phone
Palm Tungsten E Handheld Logo
Top Palm Computers & Internet Experts
Marvin
Marvin
JC Meredith
JC Meredith
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
