Question about Getac W130, High Bright Touch Screen XGA LCD, 1.4GHz, 1GB, 40GB, Win XP, Backlight Rub (W34B3A20GA00) PC Notebook
Screen When I turn on the computer the screen turns on but not the backlight.
  • JOHNMAC_619 Jul 17, 2008
    YEA I HAVE THE SAME PROBLEM, WHEN I TURN OF THE SCREEN IT TURNS FOR ONE SECOND THEN IT GOES BLACK LIKE ITS SHUT OFF BUT THE MONITOR IS STILL ON. HOW DID THIS HAPPEN AND HOW CAN I PREVENT IT FROM HAPPENING AGAIN?
    Sergeant:
  • 457 Answers
Plug an external monitor if it goes you have LCD problems
Posted on Sep 23, 2007
SOURCE:
Toshiba satellite p75-A7200 how to turn on keyboard backlight
Backlights turn on automatically when you power on the computer. If you have no image on the screen, either the lcd inverter or screen is bad.
Feb 01, 2014 | Toshiba Satellite Computers & Internet
Samsung LED backlighting turns off
The only cure for this is to get it repaired and stop smacking on it before you do some real damage.
Jan 24, 2013 | Samsung NP300E4C-A02US Laptop
Hi my screen is black when I turn on my laptop.
ysounds like you either have to replace the backliught tubes and/or the circuit board that runs the backlight tubes.backlight tubes are available on ebay from a gentleman in oklahoma city oklahoma
Jun 23, 2010 | Dell Inspiron 710m Notebook
My laptop screen will not turn on. The laptop turns on & I hear it working, the screen will just not turn on.
Hi
This sounds very much a backlight or invertor issue and will need to be replaced. If it is the backlight then a screen replacement at about £140 is a rough guide. IF its the invertor then they tend to range from £10 to £40 and really both jobs should be done by a reputable computer retailer.
Thanks
Taz
Nov 02, 2009 | Toshiba QOSMIO F15-AV201 Notebook
Acer 5810t laptop. screen gone black
Press and hold the Power button for 45 seconds to turn the laptop off.
Then, remove the battery from the battery compartment and clean the metal contacts.
Next, reinsert the Battery and try to turn it ON.
If the display still doesn't come then you may try connecting an external display to check if the Computer is able to produce display and the issue is with the backlight of the LCD screen.
wish u good luck!!!!!!!!!!!
Sep 17, 2009 | Computers & Internet
W2242T's backlight not working...
You can buy backlight fluorescent bulbs on eBay.
Jul 04, 2009 | LG W2242TQ-BF 22 inch Monitor
I turn on my computer but the screen is still black
think you might have a failed screen inverter (FL inverter); this problem is very common with laptops. The inverter board acts as a power supply for the LCD screen backlight bulb, it converts low voltage DC power into high voltage AC. On most laptops the inverter board is located inside the display assembly below the LCD screen and you can get access to it if you remove the screen bezel (LCD mask). When the screen inverter goes bad the backlight will not turn on anymore or it turns on for a short time and then goes off, but you still can see a faint image on the screen and the external monitor works just fine. First of all I would make sure it’s not just a loose connection and reseat connectors on the inverter (it looks like you already done this part). Next, I would try replacing the inverter board. It might fix your problem with the backlight. It’s possible that you have a faulty cable, bad motherboard or even bad LCD screen, but I would try replacing the screen inverter first.
Oct 06, 2008 | Toshiba Satellite Pro 4600 Notebook
Dell latitude Cpi LCD screen Backlighting?
What do you mean exactly?
To increase or decrease the backlight brightness use Fn-key(next to left Ctrl-key) with up and down arrows.
There is not some key-combination to turn off the screen, you can make your computer turn it off after some time (if you're using XP this can be done in control panel->Power options), or just close the lid :)
Mar 24, 2008 | Dell Latitude CPI Notebook
The screen still displays the image but the backlight if off
you need to get the inverter changed out. Thats the part that changes DC to AC and powers the backlight
Jan 16, 2008 | Toshiba Satellite A135-S2276 Notebook
Open Questions:
See all Getac W130, High Bright Touch Screen XGA LCD, Questions
Computers & Internet Logo
148 people viewed this question
Top Getac Computers & Internet Experts
Ekse
Alun Cox
Are you a Getac Computer and Internet Expert? Answer questions, earn points and help others
