Question about Sharp XR10XL DLP Projector
Sharp xg-v10wu with good lamps and i get two red
Sharp xg-v10wu with good lamps and i get two red lamp incators and a flashing red power will not go green to fire lamps
  • 2,237 Answers
Check to see if the filter cover is open and/or the lens cover is open. there are switches in both openings, so see if the switches work (they are usually blue).
Posted on Jul 17, 2009
Lamp 1 light is on upon turning power on. Then lamp 2 light turns from green to red
it might be a bad lamp. i'd recommend reversing the 2 lamps, and if the problem follows, then you know you have a bad lamp.
May 31, 2011 | Sharp XG-PH70X Projector
I had to replace the lamp and it blew the fuse on the power board. I replace the fuse and put in a new lamp and still have now power. the red light will come on in the front but it will not power on. ...
When you replaced the lamp, did you use a patten part lamp or an official sharp lamp. When you replaced the fuse did you check there were no signs of burnt components on the board was the power disconnected when you changed the lamp
Mar 05, 2011 | Sharp XG-E1200U Projector
How do you replace the bulb in Sharp XG-E3000U
To replace the lamp is pretty simple its located on the bottom of the unit the cover has one screw to remove it the cover. The lamp has three screws to remove it theres a handle to pull it stright out.The internet is a very good place the find a new lamp.
Jan 10, 2011 | Sharp (CLMPF0046DE01) Projector Lamp for...
Replaced both bulbs with brand-new bulbs. Now all
Verify that the lamp doors are securely closed. The blinking red lights indicate a lamp problem. In this case, both appear to be defective. I doubt that the lamps are the problem. double chack all connections and doors for proper seating. Update this if the problem remains.
Thanks,
Dan
Apr 16, 2010 | Sharp XG-PH50X Multimedia Projector
Installation projector sharp xg-e690u
Unplu the unit
Locate the user service screw, the lamp door should be underneath the projector.
open the lamp door
the lamp is removed by undoing 2 or 3 screws and pulling out with the handle.
a genuine replacement lamp with cage will mean you won't have to worry about wiring the lamp.
put new one in push connectors in firmly
do up the 2 or 3 lamp screws close the lamp door and screw up
reset procedure usually plug in power while holding down up, left and power and the lamp will be reset.
Hope this helps you
Good luck
Hope this helps
Nov 30, 2009 | Sharp (BQCXGE690UB1) Projector Lamp for...
Sharp XG-E650UB LCD Projector won't display picture.
it only takes up to a 640x480 resolution. it is a very antiquated projector.
Aug 10, 2009 | Sharp PROJECTOR LAMP, Projector Lamp FOR...
Need to reset lamp counters on a sharp XG-V10WU
1 turn projector switch off
2 remove lid and remove lamps
3 replace lid with out lamps
4 turn main switch to the on position
5 press the on switch on top
6 press enter
7 flip main switch to the off positon
8 replace lamps and lid
your done!!!!
Aug 03, 2009 | Sharp Projector Lamp for XGV10WU
I have a Sharp LCD Projector, Model #XG-E650UB & it won't power up.
are there any leds lit? if not, it may be the bimetal circuit breaker. if the unit overheats, the breaker trips to cut the heat source, and needs to be reset manually. unfortunately, the top needs to be removed. it's located on top of the lamp housing (red button). if it's not tripped and still no power, you need to replace the power supply.
Jun 09, 2009 | Sharp PROJECTOR LAMP, Projector Lamp FOR...
SHARP XG-P25X PROJECTOR PROJECTOR RUNNING THEN IT IS AUTOLOG OFF AFTER 2MIN. WHEN PROJECTOR IS RUNNING ITS SHOW GREEN LED AFTER LOG OFF IT IS SHOW RED LED ON LAMP AND POWER LED
either the lamp hours are close to or exceeding 1400 hrs and the lamp needs replacing, or the ballast is starting to fail. with the projector on, check the lamphours in the menu. after you replace the lamp (if it needs it), reset the lamp timer by holding down the down arrow, right arrow, and enter buttons, then press power.
Jan 10, 2009 | Sharp Conference Series XG-P25X Multimedia...
Sharp XR10XL DLP Projector Logo
297 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
