Question about Dometic RM2852 Refrigerator
I have a 2009 toy hauler with a dm 2852, freezer is cold, but the refrigerator is not cold enough. I know there is a temp sensor that attaches to the condensor and I have it as high as it will go on the finns. Does it have to go to the left as well?? The cable is not very long to allow any other movement, can anyone help me?? clinedvpr@yahoo.com Thanks
I have the same fridge in a 2009 Heartland Cyclone 3950. Just recently had the same problem. Is your fridge in a slideout? If so, in order to vent out the wall (as opposed to a fridge NOT in a slideout, they vent through the roof, and sometimes don't have fans) - the fan must come on to assist with hot air movement. If you have not heard the fan come on, go outside and check in the access panels.
On mine, the fan is mounted inside, just under the top opening. The thermal switch that operates the fan is mounted to the fins at the top. After verifying I had power, I bypassed the thermal switch and connected the wires together - the fan runs 24/7 now (until I install my new switch) and its cooling like new! I have a 2009 toy hauler with a dm 2852, freezer - smile.gif For the DM2852 model fridge, the Dometic part number is: 3104133.016
I called Dometic myself and got the part number in order for the "authorized service center" to order it - he had no parts breakdown for this section of my fridge. The fridge has a 3 year warranty, so I let the service center order the part for me - free of charge - otherwise I could have paid for it straight from Dometic.
Posted on Aug 03, 2009
Dm 2852 dometic
check seals if bad will frost up
Aug 09, 2014 | Dometic Refrigerators
I have a 2852 model doesn't seem to be cold enough
RV refrigerators will not always get as cold as your home refrigerator because they operate on a heat absorption principle rather than cold induction. The first thing you need to do is determine the temperature. Place a thermometer in a glass of tap water and set the glass inside the refrigerator and allow it to set for 24 hours without opening the refrigerator. Check it after 24 hours to determine the temp. It should be around 33-38 degrees. Let me know what the results are.
Jun 17, 2014 | Dometic RM2852 Refrigerator
Freezer freezes fridge not cold enough
move temp sensor down or let hang if same replace temp sensor
May 21, 2014 | Dometic RM2652 Refrigerator
I have a Kenmore Elite 51374. The refrigerator is not getting cold enough but freezer is too cold. Technician said that it was an electrical problem to call a electrician that I needed a new outlet. I...
That is the dumbest answer I've ever heard from a technician.
The cold control on most boxes controls the freezer temperature. You want the freezer temp to be around zero degrees.
Somewhere (usually in the refrigerator section) there's another control that actually sets a damper, letting some cold air from the freezer into the refrigerator. Higher numbers equal lower temperature. Find that second control knob and turn it up by 1 or 2 numbers, let an hour or so pass and check your refrigerator temp. You want about 40 degrees in the fridge.
Aug 02, 2017 | Kenmore 23.3 cu. ft. Side-by-Side...
Frigidaire refrigerator with a broken freezer
He is correct. The temp in the refrig controls how often and for how long the refrig runs. Lets say the temp in your garage is 34 degrees, and you have your refrig set to 36 degrees: The refrig will never run, the fresh foods section will cool to 34, and the freezer will warm to 34. Even if the temp is 45 in the garage and you set the fresh foods to be 33, the refrig will not need to run long enough and often enough to keep the freezer temp cold enough. You will most likely need to have the ambient room temp at least 55 degrees to get satisfactory refrigerator performance. Insulating the refrig will not help. (by the way, outdoor beverage vending machines use an internal heater in cold weather to prevent liquid beverages inside from freezing,..... so using that info, you could put a low wattage heater in your refrig to make your refrig run enough to make the freezer section work. The %&#* with that, just move it into the house!)
Feb 06, 2010 | Frigidaire FRT17B3A Top Freezer...
Dometic 2852 freezer gets cold but refridge does not
If your freezer is getting down close to zero degrees (F) then I doubt that your refrigerant is low. The most common cause of the refrigerator section not getting cool (approximately 40 degrees (f)) is a fan that pulls the coils in the freezer into the refrigerator has failed. A very common failure of a cheep little fan motor. Normally that fan is behind a panel in the freezer section at the bottom. Determine where the cold air in the refrigerator section normally enters and the fan will be above there.
Aug 11, 2009 | Dometic RM2652 Refrigerator
Same problem freezer is ice cold and the fridge is warm.
Make sure that the knob that controls the opening of the vent so the cold air in the freezer get to the refrigerator is operating. If it does, I don't see any reason why the refrigerator should not work.
Jun 30, 2009 | Dometic NDR 1292 Refrigerator
Freezer compartment on refrigerator not cold enough
depending on the temp it could
if the ambient temp get below 32
you freezer wont come on and actually begin to get warm (insulation factor)
but the refer will seem cold because of the low ambiant temp is the temp inside
we go in the refer alot more than the freezer
Mar 28, 2009 | Frigidaire FRT21S6A Top Freezer...
Amana Fridge with bottom Freezer
either the switch or the temp sensor it broken. on the sears site you can get the part number
Apr 24, 2008 | Amana ABB1921DE Bottom Freezer...
Dometic RM2852 Refrigerator Logo
707 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
4stevetaylor
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
