Question about Philips Magnavox DVD/VCR Dual Player
The tv is stuck on channel 3 and i want to change the channel and i have no remote. How do i do it? I have a magnavox tv dvd/vcr vcr recorder model 20mc4304/17
  • Philips Master
  • 3,866 Answers
This is hard but understandable. If you cannot change it on the frount of the unit with the channel up and down buttons then you may have to get a universal remote there is no solution or quick fix or any type of factory reset unless you had the remote to get into the menu. good luck
Posted on Apr 22, 2009
I got a magnavox dvd recorder and 4 head hi-fi stereo vcr and im having trouble with hooking it up to my cable box how do i record shows on my recorder without switching inputs on my tv because i switch...
Don't hook the DVD/VCR recorder through ur cable box.Hook the DVD/VCR recorder through ur tv only it should work find.This way each units have it own direct functions to the tv.U recording the shows from the tv not the cable box ok.
Nov 15, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
I have a Magnavox ZV427MG9 A VHS & DVD Recorder
U must make sure ur tv channels must work throught ur DVD and VCR unit.Then u can record it out the tv show programs.U must connect the tv air signal or cable to the DVD VCR unit in the antena port.Use another cable connect out on the DVD &VCR unit and in the tv signal input in ur tv antena input.Make sure u in the channel 3 or 4 switch desire back of the DVD&VCR of the back,and the tv correct to ur desire channel switch to 3 or 4 .U
can record tv shows now.
Aug 18, 2009 | Philips Magnavox DVD+R/+RW Recorder/VCR
Would like to record from my tv to my magnavox dvd/vcr combo box
If I understand your request right, You do not have cable or satellite box.
You can not record from your TV. You use the TV as a monitor from the dvd/vcr combo box. What the box receives is what shows on the TV. So you will have to have a digital convertor hooked to the (antenna in) dvd/vcr combo box, (antenna out to the tv antenna in) Depending on the antenna you are using that is on the other end of your cable-in coax connection this will hook to your antenna in on the digital convertor box. If your cable is hooked up and operating correctly and directly to the tv that is digital ready you probabbly have a good picture. When the vhf/uhf signal was transmitted you could go from the dvd/vcr to the tv with no problem. But now that the signal is digital and the tv is set for digital the dvd/vcr will not pass a digital signal to the tv. Best suggestion, you have to get a digital dvd/vcr receiver. If you have more question please contact me.
Mike
Jul 25, 2009 | Philips Magnavox DVD/VCR Dual Player
I can't setup channels for Magnavox tv/vcr.
Good luck! We are taking our unit back. We are both professionals dealing with multiple intense things, then we get home and can't figure this stupid POS out.
May 28, 2009 | Philips Magnavox MDV530R DVD VCR
I cant record tv through my vcr.
set the vcr up so that you change the chanels through the vcr,,,check the vcr setup menu
May 16, 2009 | Philips Televison & Video
Electronic ILLITERATE!!! - nothing recorded from cable tv channel
okay, if you have a cable box (cable out plug to dvd/vcr in), then from the dvd/vcr (cable out plug to tv/monitor). make sure tv/monitor and dvd/vcr are set to ch #3. you swith channels with the cable box ,you are not going to be able to record HBO on dvd (but you can with the vcr), any other cable ch(tnt, history, tbs,we, oxygen and more) is recordable w/ both dvd/vcr
no cable box. take cable wire plug to dvd/vcr in, than other wire is connected to tv/monitor
now go to dvd/vcr with remote, menu, set to catv, scan channels. now when you wish to look at tv the dvd/vcr must be on at all times. again you will not be able to record Premium ch like HBO
hope this help............pls feel free to rate
May 14, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Need the remote code for a phillips dvd player
These are the codes printed in the owners manual for your dvd/vcr player.If they do not work you will have to contact Emerson and ask them for help getting the code. The contact number should have come with the instructions for the remote. Just give them the model number of you remote and the units model number and they should be able to help you. I hope this information helps you with your problem. Switch the input selector on your TV to an appropriate external input channel (usually near channel 0).
Press a button on the TV’s original remote control that selects an external input channel until the DVD
recorder’s picture appears. Check your TV owner’s manual for details.
Admiral
Curtis Mathis
GE
Hitachi
JVC
Kenwood
LXI-Series
Magnavox
AUX
LINE1, LINE2, 00, 90, 91, 92, 93
INPUT, TV/VCR, 00, 90, 91, 92, 93
INPUT, AUX
VIDEO, VIDEO 1, VIDEO 2, VIDEO 3
AUX
00
AUX CHANNEL
Input Mode Names for Common TV Brands (Example)
Panasonic
RCA
Samsung
Sanyo
Sharp
Sony
Toshiba
Zenith
TV/VIDEO
TV/VIDEO
VIDEO
00
VIDEO1, VIDEO2, VIDEO3
TV/GAME
00
Apr 25, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Vcr will not record
THE CABLE OR ANTENA NEED TO SCREW INTO THE INPUT OF YOUR UNIT THEN A SMALL WIRE OUT TO THE TV FROM YOUR UNIT PUSH RECORD WHEN SHOW IS ON TV !SO ITS CABLE INTO VCR INPUT THEN CABLE FROM OUTPUT OF VCR TO TV ....TV ON CHANNEL 3 AND VCR UNIT ON CHANNEL 3
Dec 07, 2008 | Philips Magnavox DVD/VCR Dual Player
Philips Magnavox DVD/VCR Dual Player Logo
197 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
