Question about Dell Inspiron 6400 Notebook
My control key won't choose incontiguous data. I want to select point A and point C and skip point B. as opposed to holding down the shift key to select from point A to point C that will include point B. Control key is working ok for Copy>paste etc.... Weird... Any thoughts from you brainiacs? I have a Dell Inspiron 6400 laptop. TIA....Christine
  • ccannon707 Apr 24, 2009
    Hi and thanks for responding ...& the bonus points :-). I am embarrassed to say it IS working - I just wasn't seeing it. I am using it in Excel. Thank you again. I am delighted to find this site.
  • OnlyOneN
    OnlyOneN May 11, 2010
    What program are you working in, that you wish to choose incontiguous data?
    Scholar:
  • 82 Answers
The program is irrelevant , it is a basic function of Windows.
Two possiblities:
1: Intel hotkey is messing things up. Disable it.
Start > Run
Type msconfig
Hit OK
Go to the startup tab.
Uncheck hkcmd.exe
Hit OK.
Restart.
2: If that doesn't do it , you can work around the issue by using stickykeys.
Go to control panel, accessibility options.
Put a check in use stickykeys.
If you double tap ctrl it will lock it down while you are selecting things. Tap again to release it.
Hope that helps.
Oh, and +5 bonus points for using incontiguous correctly in a sentence ; )
Posted on Apr 22, 2009
ASUS ZENPAD 102300C AFTER CHARGING GOES BACK TO RESET
Have you checked for firmware updates? You can try to do a hard reset which can force OS errors to clear up.
First method:
  1. In order to switch off the device, hold down the Power button for a short while.
  2. In the next step press and hold Volume Up + Power key at the same time for a few seconds.
  3. You can release held keys when you see menu on your screen.
  4. Then press Volume Down to select option "Factory Reset", and press Power button to confirm.
  5. Success! The hard reset has just been performed.
Second method:
  1. Turn on the device by using the Power button.
  2. Afterwards go to Settings and then to Backup & Reset.
  3. Tap Factory Data Reset and select Reset Device.
  4. If it's necessary enter the safety code and choose Erase Everything
  5. Select OK to confirm the whole operation.
  6. Well done! After a while your tablet should be ready to use.
Third method:
  1. At the beginning press the Power key to turn off your device.
  2. Afterwards press and hold Volume Up + Power simultaneously for about 5 seconds.
  3. you can release held keys when you see menu on your screen.
  4. Then press Volume Down to select option "Recovery", and press Power button to confirm.
  5. Press Volume Down to choose "wipe data/factory reset", and then push the Power button to confirm.
  6. Select "Yes--delete all user data". Use Volume Down button to scroll and Power key to select.
  7. To restart the tablet, select "reboot system now".
  8. Success! The hard reset is done!
A Hard Reset will erase all of your data
Feb 16, 2017 | ASUS Computers & Internet
Tip
Barcode scanner reapir tips
Loading Scanner: With the scanner powered off press and hold the SHIFT key & BK SP key on the scanner. While holding those two keys down press power, let power key go and then let SHIFT and BK SP go. The scanner will now go thru a reboot process. When done the scanner should read:
“ COMMAND MODE “
Select function
Self Test
At this point press the up arrow key twice and the scanner will now read:
“ COMMAND MODE “
Select function
Program loader
Place the scanner in the cradle and press enter. The scanner may or may not give a message saying “ WARNING: EEPROM WILL BE ERASED CONTINUE? “ At this point push enter. Let it erase the EEPROM. When done the scanner will ask you for “BAUD” press the up arrow twice and the scanner should read 38400. Press enter and, the scanner will ask you for “data bits”, press the up arrow key for 8 bits. The scanner will now prompt you for “flow control”, press enter. The scanner will now be on a screen that says:
“COMM Parameters”
Start? <ENT>
Just leave the scanner at that screen for now.
There is a file you need to test its called Diags.hex that needs to be transferred to the unit. once that is downloaded you can test the laser memory and even the keyboard.
on Dec 01, 2009 | Computers & Internet
Why cant i hard reset my kyocera C6740
1. At the very beginning hold down the Power key in order to switch off the cell phone.
2. Press and hold the Volume Down + Power button for a few seconds
3. You should release held keys when the Recovery Mode starts.
4. Afterwards, press Volume Down a few times to highlight "wipe data/factory reset", and then push the Power button to confirm this option.
5. Next, select "Yes--delete all user data". Use Volume buttons to scroll and Power rocker to select
6. When the Recovery Menu appears once more on the screen, choose "reboot system now".
If this didn't work:
Go to "Settings", then-> "Backup & Reset", after that tap "Factory data reset", choose "Reset phone", and select "Erase everything"
Aug 11, 2016 | Kyocera Cell Phones
How to delete multiple emails
Hi Laurie
Select an email to delete
move down the list by e.g. 5 messages
Hold Shift Key Down
Select last message in group of 5
All messages in a row will be selected.
Hit DELETE KEY
They get placed in deleted items in case you wish to recover later.
OR
skip down list one or two
Hold APPLE Key (Cmd Key)
Select next message
continue down list
Press APPLE Key just prior to clicking email message
This will allow you to randomly select from a list
Just hit Delete Key when ready
These Keys apply the same principal in many programs on the Mac
You can do the same with a directory in any window.
Good Luck
Trevor
Aug 12, 2014 | Apple Air Computers & Internet
I have a virgin mobile cell phone forgot locked pattern how to by pass it
  1. Press and hold the POWER key and both volume keys
  2. Continue to hold all 3 keys until an exclamation point and a little green android robot appear
  3. Press the HOME key to display the menu
  4. Navigate using the volume keys
  5. Select Wipe data/factory reset
  6. Use the BACK key to select
  7. Scroll down to Yes delete all user data
  8. Use the BACK key to select
  9. Select reboot system now
Apr 14, 2014 | Samsung Cell Phones
Size of the excel file increased from 721 KB to 50MB
Many businesses use Excel to track their data and expenses.
However, you can run into problems when files grow too big.
Try reducing the size of your Excel files in different ways to eliminate your storage problems.
Remove unnecessary graphics and fonts from the Excel file.
Simple report data doesn't need a lot of excess formatting to make it attractive.
If you need to keep different fonts in your file, reduce some of the font sizes you originally used.
Reduce the number of pivot tables you allow in your data analysis.
Run your pivot table wizard when dealing with involved calculations.
When given options to format the file, choose those that allow the data to refresh instead of adding a new table.
Input your data, close the file and save as an Excel (XLS format) file and as an HTML (XML format) file.
To do this, choose "XML Data" in the "Save as type" drop down box.
Change the name of your document as well, so you can tell the difference between the two files.
Open the XML file and save it back into the regular XLS file to create a smaller file than the original.
Again, rename this file, as well as changing its type. This act removes odd programming left from past calculations since the last "save."
Check into file compression software such as OzGrid.
These products exist because you cannot open a file once it gets too big.
Compress the XLS data by compelling the program to recalculate the cells used for your file.
Excel File Size Reduce Software 7.0
http://www.newfreedownloads.com/Business/Spreadsheets/Excel-File-Size-Reduce-Software.html
http://www.ozgrid.com/
or
Microsoft Excel files can contain thousands of cells filled with data.
When you combine this information with graphics, such as charts and graphs, as well as ever-expanding links to other worksheets, you can end up with an enormous file that takes up precious system space and slows Excel down.
While there are many software programs available that promise to shrink Excel files, there are many ways to reduce the bulk without downloading a new application.
1. Click on any cell in the Excel file you want to reduce.
Open the "Go To" dialog box in Excel 2007 by clicking the "Find" drop-down arrow on the Home tab of the ribbon and selecting "Go To."
In Excel 2003 or earlier, go to the "Edit" menu and select "Go To."
You can also use the keyboard shortcut "Ctrl+G" in any version of Excel.
2. Click the "Special" button on the "Go To" dialog box.
Select "Blanks" and click "OK." Click the "Clear" drop-down in the "Editing" group in Excel 2007 and select "Clear All."
In Excel 2003 or earlier, go to the "Edit" menu, point to "Clear" and select "All." This will clear any blank cells to help reduce the file size.
3. Go to the very last cell containing data in the Excel file.
Select the entire row beneath this cell by clicking the number to the left of it.
Hold "Ctrl+Shift" and then press the down arrow key to select all of the cells beneath this point.
4. Click the "Clear" drop-down in the "Editing" group in Excel 2007 and select "Clear All."
Select the column to the right of the last cell. Hold "Ctrl+Shift" and then press the right arrow key. Again, select "Clear All."
5. Repeat Steps 1 through 5 for any other Excel files that are linked to the workbook you are trying to reduce.
Save the files and then check the new file size by clicking the "Office Button" in Excel 2007.
Point to "Prepare" and then click on "Properties." In Excel 2003 or earlier, go to the "File" menu and select "Properties."
The file size will be listed on the "General" tab.
http://www.ozgrid.com/Excel/ExcelProblems.htm
Apr 22, 2013 | Microsoft Office Professional 2010
Reduce the size of excel file
or
Apr 22, 2013 | Microsoft Office Computers & Internet
How to set the packet data setting for nokia 5310?
  1. Press Menu
  2. Choose Settings and select
  3. Scroll down screen to choose Configuration and select
  4. Scroll down screen to choose Personal config. Settings and select
  5. Now, press Add (visible if you don’t have a previous Personal Setting created) or press the Options button. when you have pressed the Options button, choose Add New. Then you will have several options to choose from.
  6. Now, scroll down and choose the Access Point and select.
  7. Choose option Access point settings and select
  8. Go into Bearer Settings
  9. Now, choose Packet Data Access Point
  10. Now, enter your APN address corresponding to your operator, then press OK
  11. Now, go back to the Personal Configurations Settings menu (press Back 3 times), where you now should be able to see an Access Point (or called My access point) selected.
  12. Now press Options button, and then choose to activate the Access Point.
  13. Now you should be able to access internet.
Aug 10, 2010 | Nokia 5310 Cellular Phone
Madden NFL 07 instruction booklet
There are two optaions for you to find one, one of the simpler ones would be to find a video game store and ask if they have the booklet in stock and they should be able to give you one, or you can try e-bay, im sure there is something on there. I hope I have helped you in anyway.
Wayne
Jun 26, 2009 | EA - Electronic Arts Madden NFL 07 for...
Dell Inspiron 6400 Notebook Logo
Alun Cox
