Question about Hitachi 61UWX10B 61" Rear Projection Television
The blue hangs down 61udx10b
It looks like the blue fell down slightly and the other colors are coming through fine. Other than that it works fine. But the actual model number is 61udx10b. I can't find it on here. Thank you
  • 65 Answers
Did u try the auto or manual convergence?
Posted on Apr 22, 2009
HELLO I have recently made an Blue LED writing sign, at close up its fine, but the more further i go away from it , it becomes blurry and hard to read. please help
LED's have a very specific wave length that defines the color, and blue isn't that sharp. Plus the type of LED's itself may not be of the right angle. Together this makes for looking fuzzy at a distance. A different color blue (different manufacturers have slightly different colors of blue and each are slightly different wave lengths) and/or a different angle of lens might improve the legibility of the sign.
By the way this is also true to a point about octics, your eyes for the color blue. Think of how much harder it is to read lighter blue ink print than it is to read either black or red....
May 17, 2011 | Kitchen Appliances - Others
Hdtv that has double vision
There are two common problems with these sets.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 23, 2009 | Hitachi 53UWX10B 53" Rear Projection...
Toshiba TP43H60 - Unable to adjust colors left/right
Have you tried to adjust in the customer menu or in the TECH menu? I can tell you how to get into the tech menu--if it will not adjust there you have a convergence circuit problem and I can tell you what is needed to repair the set.
SD TECH
Oct 08, 2009 | Toshiba TP43H60 43" Television
Full Color fading to blue then screen turns off. Repairable?
Here is what you need to do.
1.) You need to remove the entire plastic piece below the front of the screen. You most likely will find 3 screws on either side in back that you have to remove.
2.) The grill will not come out easy, pull from one side and then when it starts to come loose from the other side(there are several plastic pegs that hold it in.) Then from the bottom pull out( most of these sets have square plastic tabs at the top that tuck in.)
3.) With the grill removed locate the inspection plate behind it (it usually has 6 screws.) You will have to tilt the grill to the left and on its side as several cables are connected to it--they are held in place with trash bag like ties that you can release to get some room.
4.) With the inspection plate removed you will see a fairly small (about 3 inch square) BLACK PLASTIC BLOCK WITH SIX CONTROLS-usually they are marked with whiteout so someone can tell if they have been adjusted.
5.) You need to look very close at the block with a flashlight----usually the top three controls are FOCUS--don't touch those.
The lower three are usually marked Screen and if you look very close you will see b, g, r(blue green red)
6.)Usually the blue will be on the bottom left--it does vary
7.) Once you locate the BLUE screen control have the set on and turn it down--if the set is shutting down you may have only a few seconds to try to turn it down---usually to the left with the Blue Screen control.
8.) Best way to do this if the set is on is on a video input with nothing connected--you turn the blue down until the set stays on and then very slowly turn it up until you see a slightly blue screen with or without diagonal trace lines----if you get it to turn on this way turn the blue screen back down slowly until the blue screen and trace lines just disappear.
Let me know if you get it to work--Like I said if it is shutting down you may have to slowly turn the blue screen down a few times to get it to stay on.
I do this here for free and if this helps you at all give me a vote here--it costs you nothing.
Regards, SD TECH
Sep 17, 2009 | Sony KP-65WS500 65" Rear Projection...
Non working driver side power window 2003 Nissan Sentra
I had a similar problem, window fell down one day while driving. Screw was loose at bottom of window that connects to track. Was hard but fixed it and worked great after. Hope it helps u out.
Aug 08, 2009 | 2003 Nissan Sentra
Hitachi 61udx10b picture problem
Replace both of your STKs these are your convergence ICs STK392-110- use STK392-180s .
Dec 14, 2008 | Hitachi 61UWX10B 61" Rear Projection...
Red line
its the convergence tube is faulty try to replace it.
Sep 17, 2008 | Hitachi 43F300 43" Rear Projection...
Sony kp57hw40
Reset RGB screen controls....located behind lower front speaker
grill & access cover.....turn down ( CCW ) green screen slightly
and other two colors as needed.....T.
Mar 05, 2008 | Sony KP-57HW40 57" Rear Projection...
Philips 50P8341 50 in. Rear Projection Television most of the color is red
Usually if you remove the speaker grill in front there is a convergence panel that can be carefully removed. If you look inside you should see a small rectangular block with six controls. They are labelled focus and screen, and red, blue and green. Adjust only the screen controls very carefully and slowly. I would recommend reducing the red slightly brfore raising the green and then blue until the picture looks acceptable. Be sure to center the on screen controls before starting.
Nov 18, 2007 | Philips 50P8341 50" Rear Projection...
Hitachi 61UWX10B 61" Rear Projection Television Logo
220 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
