Question about Victory Freezers
There is ice build up beneath commercial freezer on the coil and possibly the condensor. The unit is a Victor food display inside a grocery store. the fan is running
    Problem Solver:
  • 19 Answers
Make sure you have the proper freon charge.
Posted on Apr 22, 2009
Frigidaire upright commercial freezer started a LOUD buzz and the second light was on at the bottom front..turned off..then back on one hour later,.still loud buzz,..any idea what s wrong ?
The green light should be a normal running light and the other one, either yellow or red(ish) should be a high temp alarm. Check the contents to make sure they are still reasonablly frozen and if not start finding the cause....Is the condensor fan motor running correctly? Is the condensor coil clean and free from dirt/lint/fuzz which serves to restrict the transfer of heat? Is there an excessive accumulation of ice build up indicating possibly a problem with the automatic defrost cycle?
Apr 03, 2015 | Frigidaire Freezers
Tip
Freezer not working, things to check
The unit needs two fans running and good airflow, one fan outside cools the condensor coil and the other inside the unit blowing across the evaporator coil, warming it. The compressor must start up. The defrost timer stops everything and switches on a heating element to defrost the evaporator for several minutes. Please verify these conditions. The condensor coil may get clogged with dirt and lint, the evaporator may get clogged with ice build up, or the fan may quit working due to bad bearings, need for lubrication, or burn out. The defrost timer has an internal motor and contacts which may quit working, some have a way to manualy turn it to switch its mode in case it quits working.
on Feb 11, 2015 | Freezers
I have general electric chest freezer that is over heating what can be the cost of the problem
if it has a condensor coil and running fan try cleaning them and leave wall gap for air flow
Sep 17, 2013 | Hoshizaki Freezer Commercial Ice Machines...
ICE BUILD UP ON INSIDE BACK OF FREEZER.
The air in the freezer is circulated by a fan, there are a number of possibilities
1. Is the internal fan running, this may be switched by the door opening, to test push the small switch on the door frame ( if fitted). If the fan is running go to
2. If the fan is running can you feel air coming out of the bottom of the duct inside at the bottom.
3. If there is no air coming out of the duct the duct is possibly blocked with ice, or the cooling coil at the top is iced up.
4. If there is no air flow then the best and quickest option is to empty the freezer, store your goods elsewhere, switch it off, use a wedge to keep the door partly open and leave off for at least 24 hours. You may find a large pool of water on the floor after this and you will also need to dry out the inside of the cabinet.
Icing of this type is caused by
1. Door not being closed properly, door misaligned or faulty door seals.
2. Putting "hot" product (over 2deg C / 34 deg f) into the freezer.
3. Not covering or sealing product being stored in the freezer.
4. Defrost timing not working (ask your service guy) for this and the rest I'm afraid
5. Defrost heater not working
6. Blocked condensate drain
7. Faulty thermostat, keeps on cooling
Hope this helps
Apr 14, 2011 | Arctic Air 22 cu. ft. Commercial Freezer...
Imperial commercial upright. Top shelf is icing and frezzing bottom is not freezing.
Fan problem is one of the most common reasons for the freezer to start failing, this is called "frost free failure." Ice can build up on the evaporator coils over time, and this ice builds up until it starts blocking the fan. The fan is responsible for circulating cold air throughout the freezer, so if it is blocked the freezer will not be able to freeze any food. You can usually check this by removing an access panel in the back of the freezer to inspect the coils. If ice is built up on the coils, a hairdryer can assist in defrosting them.
It's also possible that the fan is not running at all. If the fan is burned out or the motor isn't running, cold air can't circulate through the freezer and everything will melt. You can normally hear the fan motor switch on and off from time to time. Listen for it and if you can't hear it coming on for an extended period of time, the motor may need repair or replacement. The wires connecting to the fan may be the problem, preventing the fan from receiving electricity.
Several other problems could be keeping your freezer from freezing:
There could be leaks in one or several of the hoses in the refrigerator, which results in the cold air being lost instead of circulating properly throughout the fridge and freezer.
If you have the freezer so full that the cold air can't circulate, your food will thaw even though the freezer isn't malfunctioning. Always leave some space open in the freezer and try to not store food right up against the cooling vents.
The thermostat might have shorted out, which means the freezer can't accurately determine how cold it is. If this is the case, the refrigerator would probably not be working, either.
If your defrost drain becomes clogged, the water in the line will just refreeze over and over again, which could damage the lines as well as the fan. Always check the drain and make sure no sludge is building up in it if you have a self-defrosting refrigerator.
Always try to keep the freezer door closed for long periods of time. The more the door is opened, the more warm air is let in and cold air is released. If the door is opened frequently, the freezer could be warming faster than the fridge can cool it, which will thaw your food.
I hope this helps........
Good luck.
Apr 12, 2011 | Freezers
KFS220RHY Is this freezer good for frozen foods as well as ice cream storage
Good day,
No reason it wouldn't work fine. It should be noted that if your in a grocery store the freezer sections used to store ice cream are separate from those for normal produce.
The reason is the ice cream is normally kept 15 degrees colder.
However, this unit has an adjustable tstat that should get you around the ideal 0 degree range.
As well, it's designed to be rugged not as energy effecient as a standard domestic freezer.
May 07, 2010 | Kelvinator KFS220RHY Freezer
Thaw's. Turn-off for period of time it would freeze as normal
Make sure nothing is inhibiting air flow. I don't think it is advisable to store food in an ice machine however that is not likely the problem unless the food itself is inhibiting air flow. Most ice machine manufacturers recommend against storing any food in an ice machine. If there is a freezer component in you model the check to see if the evaporator coils are frosting up and the frost is blocking airflow causing the ice storage chamber to get warm. High humidity can cause frosting. Leaving a door to the ice maker open too long can cause frosting. A low refrigerant charge can do this although it seems logically like it should not. With a very slightly low charge one end of the evaporator gets super cold and the other end is not cold enough. Frosts starts collecting on the super cold end and accumulates across the evaporator coil to the other end eventually blocking all air flow. With too much humidity from open doors frost accumulates over the entire evaporator evenly but still blocks. You shut the unit down. It thaws out and works OK on restart until frost again builds up. If its not a frosting problem but it just stops making ice then the ice may not be releasing. Check the water supply and change any filters to insure good water flow. A good water supply is required for proper release and harvest of the ice in many ice machines. If the ice doesn't release it takes a shut down and thaw to clear the suspended ice out. Check for these things and write back if you need further assistance and can provide me with more details.
Jan 19, 2009 | Hoshizaki Freezer Commercial Ice Machines...
Machine turns on makes one or two batches of ice and then shuts off
Try cleaning the condensor coils. Check the fan blowing across them. When the compressor is running the fan should be too.
Jun 28, 2008 | Hoshizaki Freezer Commercial Ice Machines...
Freezers Logo
76 people viewed this question
Top Victory Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Victory Freezer Expert? Answer questions, earn points and help others
