Question about RCA HD52W59 HDTV Projection Television
I have an RCA hd52w59. I just replaced fl231,
I have an RCA hd52w59. I just replaced fl231, dl231, and cl230 because of a convergence problem. Now when I turn it on the picture comes on for about a second and goes out. It does this 3 times and on the 3rd time the picture stays out and doesn't come back. What's the problem?
    Problem Solver:
  • 12 Answers
Find your 'service' page, usually you have to hold the input button and the power button together for a couple sec. a new menu should appear Look for the factory restore choice and choose it.
Posted on Apr 22, 2009
Double vision
Its usually caused by a failed FL231, DL231 and CL230. You can get the repair kit from www.tvrepairworld.com called the ITC222 & ITC222A convergence option missing repair kit. The kit contains the parts and the CD with instructions.
Jul 09, 2010 | RCA HD52W59 HDTV Projection Television
Wont turn on after replacing FL231 fuse on a RCA HD52W59
If you replaced the fuse alone without installing the other components that are rquired to repair that issue the new fuse can allow voltages to flow trough the diode in both directions which can prevent the set from firing up. You need to replace the FL231, DL231 and CL230 as a set then reflow the solder on the flyback and vertical IC.
Dec 04, 2009 | RCA HD52W59 HDTV Projection Television
My convergence keep going out, I replaced the convergence twice. I have a rca hd52w59 modle
When you say replaced the convergence twice, are you refering to the convergence boards or the FL231 fuse? If its the FL231 fuse unless you replaced the DL231 and CL230 plus reflowed the solder on the flyback it will continue to keep blowing untill the 3 parts are replaced together and the flyback gets resoldered. If you replaced the convergence boards then try resoldering the flyback.
Nov 27, 2009 | RCA HD52W59 HDTV Projection Television
Need part number for f231 fuse HD52W59 TV set
you can get the FL231 at the following link.
http://servicemanuals.vstore.ca/
But you will also need DL231 and CL230 or the new FL231 will blow shortly after installing it.
Aug 02, 2009 | RCA R52WM24 52" HDTV Projection Television
MY HDTV 52IN RCA HAS BOWED PICTURE. I CANT FIGURE HOW TO FIX IT
heres where they are located but you have to resolder the flyback and vertical IC also.
Look at the flyback ( with the Large red wire) Just to the right of the flyback you will see three small brown Fuses the cehter one is FL231 DL231 is just to the right of FL231 and Cl230 is just below and alittle to the right of DL231
Jun 14, 2009 | RCA HD52W59 HDTV Projection Television
Screen is in 3D
If the convergence option has disappeared from the on screen menu you wll need to replace FL231, DL231 and CL230 total cost about 12.00 parts come with instructions on how to install. The following link has them listed under the RCA parts category.
Jun 13, 2009 | RCA HD52W59 HDTV Projection Television
Can't find convergence on menu
Please consult THe fl231 fuse problem under the tips and tricks section. The instructions are simple to complete
Apr 12, 2009 | RCA HD52W59 HDTV Projection Television
I have an RCA HD52w59 with a convergence problem. I've been told different things on this site. First I was told to change FL231, CL230, and DL231. I've also been told to replace both IC's (STK392-110)...
Your set doesnt have STK ICs. If the convergence adjustment option has disappeared from the on screen menu, then replace FL231, DL231 and CL230 If the adjustment option hasnt disappeared from the menu then you need to check the resistors on the convergence power supply board some of those will be open. The actual convergence Board will usually not develope problems just the Convergence power supply if the convergence adjustment option is still in the on screen menu.
Mar 15, 2009 | RCA HD52W59 HDTV Projection Television
Hd52w59
you need to replace FL231, CL230 and DL231. You can get the parts at the following link with free instructions for under 20.00
Jan 29, 2009 | RCA HD52W59 HDTV Projection Television
RCA HD52W59 HDTV Projection Television Logo
196 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
