Question about Frigidaire PHSC39EGS Side by Side Refrigerator
Water on floor and ice on freezer bottom
We have noticed water on our hardwood floor outside the refrigerator on the freezer section side. First thought ice had fallen from dispenser and left to melt. Happened a few more times and then discovered the bottom floor inside freezer covered with ice. Are these 2 related and is there a problem with the defrost cycle?
  • 358 Answers
The problem is that the drain hole inside the freezer in the lower back wall is clough and the water from defrost doesn't go through that drain to the evaporative pan in the back by the compresor ,you need to clear thatdrain first meltting the ice in that hole with hot water until it goes through then once in a while (every 3,4 months put bleach into the drain to keep it clear .
Posted on Apr 22, 2009
GE Monogram bottom freezer leaking water from left side onto the freezer floor and onto hardwood floor of the kitchen . Already tried totally defrosting freezer and that did not solve problem. Help!!
ck the drain in the back of freezer . it may be pluged and when it goes into defrost cycle you get about a cup of water on the floor . if there ice on bottom of freezer then the drain is iced over . some models require a drain heater to prevent this . mm hope this helps ..
Oct 14, 2010 | GE Monogram ZICS360NR Bottom Freezer...
Water leaking on the floor
Clean the drain pan and drain line in the back of the freezer section underneath the evaporator coil. Make sure water drains when you pour it in.
Good luck! :)
Vlad
First Choice Appliance
Jun 03, 2010 | Jenn-Air JCD2290HES Side by Side...
I have a Kenmore side by side Model No. 363.9565522. Noticed water dripping out of front of freezer onto floor - this has happened periodically over the lifetime of the side by side. Slid bottom freezer...
The drain heater goes into the drain,not outside it.
You need a longer drain probe to push all the way through the drain.
Look underneath for a kink in the drain tube.
Feb 06, 2010 | Kenmore 22.0 cu. ft. Side-By-Side...
Water on floor under unit & ice bottom of freezer
By going online, saw several posts re this problem. In short, the water drain was clogged and there was also a problem with the defrost timer. Service man blew out the drain line with compressed air and installed a new timer. Voila! Problem fixed. Interestingly, the serviceman found a wad of what looked like putty, but was sticky like gum in the drain area. He said he had never encountered anything similar.
Aug 04, 2009 | Jenn-Air JCD2295HES Side by Side...
Water on Floor Outside Freezer (Side by Side)
take a wire and run it through the drain until there is no resistance and then put hot water into it.
Mar 06, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Frigidaire Side-By-Side Refrigerator Leaks Water on Floor
I don't have the same refrigerator, but had a similar issue with a GE. Melt the ice at the bottom of the freezer. I think the water comes from the auto defrost feature. There should be a hole at the back bottom of the freezer that water would go into, and run to an evaporator pan under the refrigerator. The tube may be blocked that allows this water to drain, so it is backing up in the bottom of the freezer, and overflowing through the front bottom of the freezer to your floor.
Sep 28, 2008 | Refrigerators
Leak From Freezer
you have a clogged evap drain, you need to take the back panell off the freezer and pour boiling water down the drain port until it flows freely
Jun 13, 2008 | Maytag MZD2768G Side by Side Refrigerator
Ice forming in Freezer Basin
Hi. That is the only drain for the evaporator water during the defrost cycle. Take the back aluminum cover off again and pour hot water into the drain. If it won't drain, take a hose and put it over the drain and blow into it. That will remove the sludge in the trap and it will drain good now. I've seen alot of nice hardwood floors damaged with this problem. Good luck, Mack
Feb 02, 2008 | Kenmore 50522 / 50524 Side by Side...
Frigidaire PHSC39EGS Side by Side Refrigerator Logo
188 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
