Ac front 45 degrees, the back unit on the roof towards the back is warm. How do you charge the vents on the back/roof.
  • christian nielsen May 11, 2010
    What kind of ac you have and can be more specific about charging the vents.
  • 71 Answers
Find a way to remove the cover, after that, clean the condenser, make sure you don't press too hard on the fins, creating restriction on the cooling fan. About charging the vents?, that, I don't understand.
Posted on Apr 22, 2009
May tag window air conditioner 8000BTU #M6X08F2A. Water blowing out A/C vents. I have 2 and both do this. Thanks so much
Hello Ron,
The water is from condensation.
  • These units have to have a pitch. Your units are mounted too straight (90 degrees), the pitch or inclination is supposed to be around 2 to 3 degrees outward ( toward the back of the unit)
  • And also there may be a rubber plug on the bottom of the AC for drainage.It has to be taken out.
Maytag Air Conditioner Installation Instructions
Jun 22, 2015 | Heating & Cooling
Do i need to strengthen roof in jayco 2006 hawk outback to fit dometic b3000 a/c unit in roof vent cutout????
On the coleman hardtops they have/had an 2 internal braces similar to "U" channel that bolted across from side to side for added strength to support the AC. Might be smart to just drop by a dealer and browse to see if they have a unit similar to yours with AC already on and have a quick look inside to see what I mean. They were about 2" "U" shape with about a 1" x 90 degree flange/lip to sit up against ceiling, and bolted to the sides with a small 90 degree flange up against sides with 2 bolts. Also, if you check with parts dept at Jayco dealer, they should be able to order them for you, already painted and arced to fit properly from factory.
Mar 15, 2013 | Dometic Rooftop RV Air Conditioner
The air blowing out of the vents is only 76 degrees.
Check the condenser coil and see if it blowing warm, or not warm air. Also, clean it and check the filter.Any furnace or A.C. unit has to be clean. I tell all of my customers to assume you have a baby in your hands, and you put a pillow over the baby's face. The baby cannot breathe. It is the same with furnace and A.C units:THEY HAVE TO BREATH.
Feb 19, 2010 | Ruud Heating & Cooling
My attic air conditioner will stay at 81 degrees in the hottest part of the day only when it is sunny when it is cloudy it works fine I have a small 900 sq foot ranch
if the difference in termperature is between 15 and 20 degrees between the inlet and outlet, the unit is doing all it can and is undersized. if not check for airflow problems, filters, dirty coils etc. and if that is all good, then there may be issues with the refrigerant charge
Jul 12, 2009 | Dometic Rooftop RV Air Conditioner
Lint bypassing lint filter and water in vent transition hose
your hose is to long you should vent it stright out wall if you can't you can buy a small inside vent kit it take so long to dry becuase it's not exsusted proper
Jan 27, 2009 | Maytag Neptune MDE6800A Electric Dryer
Vent-A-Hood dumping water on Cooktop
only thing i can think of would be a condensation issue. see if it is when you have a temperature change outside while it is warm in you home.
Nov 22, 2008 | Euro-Pro EPH18-236SS Vent-A-Hood Euro Pro...
Mothers AC unit
That has nothing to do with the water. Sounds to me like it needs cleanning, (the water is not drainning toward the back of the unit) ,,(dirty filter, which its trying to **** air anywhere it can even thru the drain hole, or not enough slope, leanning toward the back so gravity can flow the water to the back of the coil! Thank you-very-much!
Aug 28, 2008 | GE Zoneline AZ38H12DAD Split System Air...
Over Stop Microwave Vent Blower doesn't remove steam
Whirlpool customer service is here and you can also enter your model number on that page to download your owner's manual, installation instructions, etc..
The installation instructions are what you need.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 13, 2008 | Microwave Ovens
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
