Question about T-Mobile MDA
I need the data on my dead MDA!!!
My T-Mobile MDA will not turn on at all. It's still under warranty though so customer service is sending me a new one in about a week. The problem is, I can't get my data off the phone because it won't receive power! Does anybody know a way to get my address book, etc. off my MDA? (no I didn't synch with my laptop. no I didn't store anything on removable memory.) Thanks!
  • Anonymous Apr 27, 2008
    once batteryis completly dead it doesnt take proper charge
  • 59 Answers
Try to trickle charge it by hooking it up to the USB and then to your computer. Let it charge up a bit then try powering it on or charging it the regular way to charge it even faster.
Trickle charging
Some Palm devices have the ability to "trickle charge" from a USB port on a PC or Mac. This means that it receives a very small amount of charging from the USB port, even if it is not connected to its AC charger. If your device is capable of this function, the charging time will be significantly longer for a trickle charge (depending on the power rating of the PC USB port). However, the device may not charge at all on an unpowered USB hub (or for example off off a keyboard).
Posted on Jan 08, 2008
SOURCE:
Smashed my screen on my mda vario got a new phone now want to active sync in but cant remember my pssword is there a work around?
Yes, you need to perform a hard reset.
To perform a hard reset
1. Press and hold the Comm Manager button and Voice Command
button on the device. At the same time, use the stylus to lightly
press the RESET button.
T-Mobile MDA Vario hard reset soft reset hardreset softreset
2. Keep the Comm Manager button and Voice Command button
pressed, and the following message will appear on the screen:
3. Release the two buttons, and press the Send button to perform a
hard reset
Feb 05, 2011 | T-Mobile MDA Vario Smartphone
MDA Not turning on anymore
u r phone is dead so plz admit into a service center to repair
Jul 25, 2009 | T-Mobile MDA Compact Smartphone
MDA is dead slow
u have to take backup of ur all data and reinstall ur OS...from "clear storage" option in ur setting...this is the only solution...use Pimbackup for backup of ur data
Mar 05, 2009 | T-Mobile MDA
No bluetooth hardware on t-mobile mda
dear u need to reinstall ur OS on ur MDA it will automatically install ur blue tooth device drive..there is no possiblity that in MDA blue tooth wont present...so go to start>> setting >> clear Storage...and then wait for ur OS to install automatically...but remove ur storage card and also backup of ur data (device data) or copy it to storage card...it will work..
Feb 17, 2009 | T-Mobile MDA
My MDA Compact III doesnt turn on!
You can contact the Vendor/Customer Care for this issue.
Jul 03, 2008 | T-Mobile MDA Compact Smartphone
UNCOMPLETED MDA UPDATE
this is a sw boot up screen. this is what the screen will look like with no sw on the device, so you guessed it....the download was unsuccessful and corrupted the firmware.....if you tried to reinstall the sw again, and it does not work, you might need a new phone....contact t-mobile to do that.....OR, you can try to do a master reset by pressing the sw keys.
to do that, turn off the phone, and press and hold the soft keys (buttons located beneath the touch screen that have the lines on them on top of the green call button and the red end call button).....while holding these down, press the power button for 3 seconds and release the power button.....all this time you are holding those soft keys down....the phone SHOULD turn on and go to a black screen with white writing.....at this time you can relase the two buttons......press the green button and reset. if this does not work.....my friend, you need another one......good luck!
Dec 16, 2007 | T-Mobile MDA
Blank screen
it seems like the cable from the lcd to the phone mabye loose or you NEED A NEW LCD,,,
i HAVE WINDOWS MOBILE 6 ON THE MDA AND I HAVE A LOT OF PROBLEMS
Nov 01, 2007 | T-Mobile MDA
T-Moblie MDA Dead
I did the same thing, Blue Bay Electronics had a seven day warranty just long enough to fool me into giving a good report. Anyway look for a repair center and spend another 100.00. Good luck
Oct 07, 2007 | T-Mobile MDA
T-mobile MDA on/off switch broken
plug in your charger to your phone, find something small to stick into the reseting hole, when your phone turns on, go into settings>power>advanced: un-click the "turn off device if not used for"
it may drain your battery faster, BUT it works!!! :D
Good Luck!
Apr 14, 2007 | T-Mobile MDA
Reset Problem
Your internal battery is dead. Its just a little watch battery that needs to be replaced.
Aug 09, 2006 | T-Mobile MDA III Pocket PC
T-Mobile MDA Logo
144 people viewed this question
Top T-Mobile Computers & Internet Experts
Ekse
Marvin
Marvin
markpain
Level 1 Expert
Are you a T-Mobile Computer and Internet Expert? Answer questions, earn points and help others
