Question about Sport & Outdoor - Others
The Safety on My Marksman Repeater Pistol is Jammed
The safety that keeps the trigger from being pulled WAS stuck in the off position. After working on it for a while I got it to engage. I thought that was the end of it until I realized it was stuck ON. Now I can't pull the trigger, the safety just won't budge. Is there a trick to it, or is the whole thing going to have to come apart. It belonged to my grandfather (who has passed) and I have no manual to turn to.
  • Anonymous May 14, 2009
    i took mine apart trying to fix a spring and cant figure out where the spring goes to make the safety and trigger work
3 Suggested Answers
SOURCE: marksman 1010C repeater air pistol
My Grandfather left me one when he passed. We used to play with it all the time. Loading is very simple, but is much easier if you get a speed loader. You can get one from the Marksman website. www.marksman.com. I have the website of the owner's manual, which clearly shows how to load the BBs. Hope this helps.
http://www.pyramydair.com/site/manuals/marksman-1010/
Posted on Dec 19, 2008
sorry if you already learned but you have to **** it, and at the front under the barrel exit is a button looking shape press down on that really hard and on the top of the gun a sloped shape should appear. do not put the bb in the circle shape hole put the bbs in the top square shaped hole. push the object down and aim then pull the trigger!
Posted on Apr 07, 2009
How do I remove a jammed nail in the SHF50?
Hi Al:
Usually nailers are built so that removing jammed nails is an anticipated activity.
WORK SAFE!!!
make sure the air supply is disconnected from the nailer.
Press the safety against a piece of wood and pull the trigger. Nothing should happen but it's just one of my safety phobias.
Now you can have a really close look at the nailer mechanism.
Remove any nails that are still in the magazine.
Some nail guns have a cam or tab that will release the face of the nailing assembly.
Others have a plate secured with cap screws or little bolts. There is often an allen wrench provided with the gun just for the purpose of taking the plate off so that you can remove the jammed nails.
If all else fails, you could check with the place you rented or bought it from.
Patience, curiosity, and safety. Keeping tools working is an adventure!
May 14, 2015 | Senco Shf50 Pneumatic Hardwood Flooring...
How to remove a stuck slide from a pistol
most slides work the same on automatic what gun are you working with you are allowed to say on here ,
Nov 03, 2014 | Optics
How do I load the ****** Marksman 177 cal repeater
hold in right hand, depress cocking release with thumb, pull back cocking slide (takes some effort) till it locks out, push in on the lower front of barrel to rotate loading port to the up position (this won't move unless the cocking slide is pulled back), load BB in the top hole that is exposed (or a pellet in the lower hole), push loading port back down flush with barrel, push cocking slide forward. Marksman is now loaded. push safety button in so it is engaged. When in an appropriate place to shoot a target, push safety button back with your right finger (safety is off) and squeeze trigger.
Oct 17, 2014 | Optics
Parts schematic marksman repeater pistol
http://www.pyramydair.com/manual/marksman-1010
This is easy to disassemble but take careful notes/ pictures as you go because the springs have to be in the right places.
Oct 21, 2013 | Sport & Outdoor - Others
How do you load a Marksman .177 BB pistol & does it require a co2 cartridge and if so where does it attach to the pistol?
most dont i have one but pull down the barrel and put a bb in it then pull it back up take saftey off then u should be able to shoot
Nov 26, 2012 | Marksman 177 Cal, 5.1 Grains, BB...
How to put in co2 cartrige in a.177 cal 4.5mm
Hi wendyavery...
The Marksman 2000K does not use CO2 cartridges, it uses a spring to act as the "power plant"
Go to the following webpage and check it out
Please rate me
Bud
http://www.pyramydair.com/s/m/Marksman_2000K_Air_Pistol/644
Oct 06, 2012 | Marksman 2000K Air Pistol - 0.177 Caliber...
How do i load my marksman repeater .177cal?
If it is a pistol, **** the gun, put it on safe and then push on the button just below the barrel at the muzzle and it will flip up. The top hole is for bbs and the bottom for pellets and darts. Do not load both.
Dec 04, 2010 | Sport & Outdoor - Others
How do you load BB's in Marksman repeater 177 cal pistol (hand gun)
1) If you have sucessfully released the safety lever, grab the textured black grip of the cocking mechanism and pull it back until it locks into place.
2) In a safe manner, hold the pistol by the handle with your left hand and carefully grab the black plastic sighting mechanism at the end of the barrel with your right hand and pul this black tip end of the pistol downward. You should find that the other end (which lies more mid-barrel) will pivot upwards, giving you access to the loading tube.
Feb 03, 2010 | Marksman X7 Extreme 3-Channel Remote Start...
Crosman 1377 air pistol
the seal must be broken. send it back to whom you bought it from and get an exchange
Oct 22, 2008 | Crosman (4032)
Marksman 1010C repeater air pistol
Sep 08, 2008 | Sport & Outdoor - Others
Sport & Outdoor - Others Logo
219 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
