Question about Sport & Outdoor - Others
My johnson 115 hp motor is hard to start and hard to keep idle. Once warmed up it runs great.
  • ram4x4man33 Apr 23, 2009
    How do you boil them out?
    Problem Solver:
  • 5 Answers
Have the carbs boiled out.
Posted on Apr 22, 2009
2 Suggested Answers
SOURCE: Does an 85 johnson outboard motor 15 hp have
breaker/maker. set @ 020" @ the highest point but what is you're real problem. Run only champion spark plugs. We spenta dAY @ omc'S SERVICE CENTRE BEING SHOWN WHY. tHEY KNOW BEST!!
Posted on Oct 20, 2009
What is the idle timing for 1993 90hp evinrude
90 hp 1993 evinrude idle speed - MarineEngine
www.marineengine.com > ... > Johnson Evinrude Outboard Archive
Aug 3, 2008 - 2 posts - ‎2 authors
"How many rpm should the engine idle at,and where and how do you adjust it Thanks" 50 hp evinrude no idle and no top speed need assistance ...
Jul 6, 2013
1993 50 HP 2 cyl Evinrude stalls, runs at idle when ...
May 7, 2012
adjust carburators and idle speed 1993 48hp
Jul 29, 2010
90 hp stalls when going in gear
May 21, 2010
More results from www.marineengine.com
1993 Johnson 90-HP Runs Only At Idle Speed On Spring Start-Up
Johnson 1993 115 xflow Link and Sync - YouTube? 4:55https://www.youtube.com/watch?v=ReeuaVh8uZQNov 25, 2012 - Uploaded by Brian O'DellJohnson 1993 115 xflow Link and Sync. Brian O' ... Also if you can give me some details on how you got the ...DOWNLOAD Evinrude 90HP (90 HP) Repair Manual
Dec 14, 2015 | Boating
What will make a johnsonew 50 hp out board motor bog when under load
Evinrude 50 HP Bogs at WOT - MarineEngine
Aug 6, 2002 - 17 posts - ‎3 authors
83 50 HP Evinrude - sat out in weather for 4 yrs. Been cleaning ... At WOT, she bogsdown. Up to. ... Yes, this boat/motor is new to me. Actually ... Mercury 50 1987 bogs down when full @ full throttle
Sep 12, 2013
Motor Runs great bogs down under load.
Jun 23, 2011
1984 Johnson 70 idles but won't go
Jun 1, 2011
Johnson 70 hp no power under load Update
Oct 30, 2006
motor bogs down at full throttle Page: 1 - iboats Boating Forums ..
Dec 09, 2015 | Cars & Trucks
Johnson 115
find the bottom carb , see where the linkage from the remote cable moves the lever on the side of the engine then disconnect the cable from the remotes ! on the bottom carb there should be a screw to adjust the tickover where the linkage meets the carb linkage , turn it in 2 turns then with water attatched to water intake on gearbox turned on start the engine , it mite be slightly high or low pending ! set at 900rpm , rev engine several times back to tickover and if ok then refit throttle cable , cable should be pushing lever against its stop and then when you select forward gear it shouldnt move till you throttle up ! when in water start engine and select forward gear and tickover should be 7 to 800rpm and idle ok if not adjust till ok !
Aug 12, 2014 | Boating
Johnson oceanrunner 175
Outboards are finicky about fuel, probably don't like ethanol. Try some high test.
Nov 26, 2013 | Boating
115 hp johnson great difficulty to cold start,sometimes it even run the baterry flat but once it started there is no problem in starting again what could the reason for this be or do i just start the...
Hello vcd9,
When You Turn The Key On ,Press It In To Activate The Choke Solenoid And Then Crank At The Same Time,This Should Solve Your Problem, If All Is Fine With The Engine.
Cheers
Gordon
Feb 11, 2013 | Light Outboard Motor Boat Bass Fishing...
2007 Yamaha 115 Hp 2 stroke idle problem
Check the idle mixture. Sounds to me like it is too lean.
Mar 20, 2017 | Clymer EvinrudeJohnson Outboard Shop...
1974 Johnson 70 hp outboard, quits on acceleration.
It sounds like your motor is starving for fuel. At an idle, you have adequate flow to keep the engine running. When you call for more fuel...you sputter and quit. Could be a clogged filter or trash in the line or in a jet. Yes you will have some air in the bulb, but not a great deal. You could be sucking air at a hose connection (loosing some prime)...try this, start the engine and slowly accererate, have someone pump the bulb as you accelerate, see if the engine works properly while doing this test.
Aug 27, 2009 | RTO Oar Sockets
70 hp Johnson hard to start.
could be the choke isn't closed all the way for the first start. Then when warm the motor doesn't need to be choked.
Jul 25, 2009 | Sport & Outdoor - Others
8hp johnson, 1999,plugs good, wires good,have put in new gasoline 50.1 mix, runs great at higher rpms. When cold start, it will idle at slow rpm. Once warmed up or a hot day, it will not idle when the...
have u tried to adjust you timming linkage? its on the side of the motor where the shifter linkage is try to turn the bolt in or out while running you may get it to idle better if the power pack was bad the engine would cut out at all speeds
Apr 16, 2009 | Light Outboard Motor Boat Bass Fishing...
Sport & Outdoor - Others Logo
816 people viewed this question
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
