Question about Acer Aspire E500 PC Desktop
Computer keeps crashing on startup
My system continues to freeze up at some point during startup. When I power up the system, I will get as far as the desktop with icons, but am unable to actually start any programs. The mouse pointer (with the minute timer) won't move. I did not make a rescue disk and I cannot even format my harddrive because the system will not stay on long enough to do anything. I considered putting the harddrive in another of my computers but this harddrive does not use the usual ribbon cable and I don't have the proper connectors in my other computer.
  • tinamhiscock Feb 15, 2009
    I have the EXACT problem! Curious how do I know which registry I need? Or do I just google the type of windows?
    Thanks
    Guru:
  • 55 Answers
Ok thats not a problem ..open the towre...first locate the two silver colour screw on the back panel of the tower and then u will see the knotch pull that towards urself to remove the side panel....and locate the ram the ram will be in a slot beside the processor with two white colour knotch reseat the ram and boot the computer and repeteadly keep tapping F11....and it will take u to the recovery manager and select advanced option .......and select system recovery....and click on next ......and it will format ur windows ...use F11 if u have vista and F10 for xp...if u r not abl to go to the recovery manager try doing a BIOS default first?(IBY tapping F10 in vista and F1 in xp...then after u see the cmos and BIOS setup hit F5 it will say "load default"..select yas and hit enter and then HIT F10..now it will say " save configaration and exit now" select yes .......ten try to go the recovery manager by tapping F11 or F10.......if nothing comes up mail me ur query at [email protected]
Posted on Mar 18, 2008
    Scholar:
  • 68 Answers
I am not sure what OS you have. But what I would do is download a registry repair program on your other computer. Then force your problem computer to go into safe mode. Once in there download the registry repair program and run it at least 2 times. From the problems you are talking about sounds like a serious windows registry problem. Best way to force into safe mode is either hit F8 or F2 as soon as the bios screen comes up. When in there download your registry repair. Once you have it up and running. Run defrag hard drive and also use the scandisk feature to make sure there are no errors. This should get you up and running again. If not contact me and i will further instruct you.
Posted on Sep 23, 2007
4 Suggested Answers
SOURCE:
  • 1226 Answers
SOURCE: "this copy of windows must be activated..."
Hello!
Im affraid to answer this question because im sure that you rate me 'thanks for trying" but its ok as long as i can help.
well, In most cases, that problem will be resolve by directly going to the insternet and activate.
this statement is also correct" boot from the CD/DVD." Are you sure that the cd/DVD is ok. ? If the original CD is a bootable disc then you have no problems . You should reinstall using the original CD.
1. at frist boot, press'F2" of "Delete" to enter the bios setup.
2. find the first boot setting and change it with CD rom and then pres "F10" to save and exit the setting.
the sytem will restart automatically. then press any key to boot from cd rom.
You are done.
please tell me the problems if this solution won't apply i will give you further solution.
best regards, melnavz
Posted on Mar 07, 2008
  • 49 Answers
SOURCE: computer shuts down for no discernable reason
wow........wish i would have found this site a week ago. i have been working on one of these acer L100's for a relative and these are some things i have discovered.
1-the connection on the back of the CD drive is week. if it lose its connection , the computer imediately shuts of.
2=heat management is controled by advanced power controls related to temp sensors fan speed and poprocessor voltages. if the bios, cmos or os power management is not working properly lots of weird things happen to the computer like inconsistent boots, graphics glithes and failures and just plain old overheating because the smart fan does not ramp up the fan whenever it gets hot or is using more power.
i was able to fix this one by resetting the cmos. you do this by unplugging the power and removing the 3 volt battery on the motherboard. unfortunately it requires quite a bit of disassembly like changing the cards.
i plan on looking for other solutions like flashing the bios or a way of resetting it in the operating system.
i hope this is some good info and another suggestion is bios updating. i finally found some info on that at acer, but still do not know if this version has an update.
doug
Posted on Sep 29, 2008
  • 184 Answers
SOURCE: Acer Power FH will not boot Windows XP Pro
Well your explanation was clear but your should've not ruled out the hardware issue. if both computer suffered the same problem at the same time the problem could be within the Desktop itself. I have experienced the same problem with my HP when I move to my new house after 5 years. What happend is that during transportation the vibration lossened up the parts inside your computer. So what I did was I reseated all the parts inside the desktop and reinstalled Windows XP. Till now I have never had any problems yet.
Posted on Mar 26, 2009
Delete freeze
Depress the power button for a few seconds till the computer turns off. Wait a few seconds and restart.
Where does it freeze, during startup, or once within Windows? If you make it somewhere into the Windows operating system, restart, and during startup, peck on F8 key till you get to the B/W Startup options. Cursor down to "Safe Mode with Networking", and press the Enter key. If it makes it to Safe Mode, use "System Restore" (SR) to back up to a date before the problem occurred. If SR isn't available, or doesn't work, enter Safe Mode again, use your IE, Firefox, Google Chrome, or Opera browser to go to www.download.com. In the right-hand column of Most Popular Downloads, you'll find Malwarebytes. Download and run that program to see if the problem came from a malware infection. Follow the instructions to scan, and afterwards to remove the infections, then restart the computer.
Oct 31, 2013 | Computers & Internet
Tip
How to powering back freeze computer
<p>The computer freezes for programs, many processes running in the background react and install third party software on your computer. If you do not take steps to avoid this problem, the computer will probably freeze continues and possible problems with hardware and software that may result in loss of important documents and files. Start the computer from sleep can also lead to paralysis of the computer as different programs simultaneously loaded in the background. <br /> <p><br /> <p>1. Turn the computer off and restart it from sleep. Note that your computer crashes at startup. <br /> <p><br /> <p>2. Close all third party software (software not written by Microsoft) before the computer is idle. Programs running in the background are often the reason why a computer freezes during startup. <br /> <p><br /> <p>3. Take your anti-virus program on the hard drive of your computer from viruses and spyware in the treatment of the computer and the record so he could slow down and freeze for scanning. Will remove all possible threats to your anti-virus program. <br /> <p><br /> <p>4. Press' Ctrl + Alt + Del "to open Task Manager on your computer. Close all programs that are shown as "not responding ". For unknown processes running in the background and check the registry of unnecessary memory. <br />
on Jun 22, 2011 | Computers & Internet
When i turn on the computer the windows xp load screen comes up as always but this time it keeps freezing so i cant get into my computer
Try to boot in safe mode and check wether its entering in the windows, if its work then choose privious restore point & restore your pc. also remove any unwated software, keep the HDD free from excessive fragmentation, as this may help prevent startup problems, freezeups, crashes etc.
Jul 20, 2010 | Computers & Internet
My macbook pro OS 10.6.4 either freezes or crashes on startup. Crashed when trying to startup with Drive Genious 3, TechTool Pro 5, System Disk or Disk Warrior. Not sure what to do next. Tried holding ...
Restart your mac. As it's restarting/booting up, hold down the command, option, R and P keys simultaneously. As it's booting up and you're holding these keys, you should hear the startup chime, continue to hold the keys down, it will cycle and you'll hear the startup chimes again. Let it go thru this cycle 7 (seven) times before you let up on those keys. Once it's cycled 7 times, let it boot up normally.
If that doesn't work, then reinstall the original system software that came with the Macbook. You may have to reformat the hard disk and do a clean install.
Jul 05, 2010 | Apple MacBook Pro Laptop Computer with...
My Travelmate Laptop will not power on. During an automatic update the server went down and the system crashed I had to turn it off when I tried to startup the power button comes on but the power light...
boot into Windows' Safe Mode; press F8 before the Windows loading screen appears to get this option.
Once signed in, you'll be prompted to a) continue in Safe Mode, or b) Restore a previous install point.
Choose option b) and then follow the instructions. If the same problem (black screen after Windows has started up) persists once you've rebooted, sign in with Safe Mode again and restore to an earlier install point.
change the Automatic Update to notify before installing.
Aug 13, 2009 | Acer Computers & Internet
Machine freeze up randomly. Must do a hard shutdown. Seems like a motherboard failure
Freezes and crashes are generally caused by some sort of instability in the computer system.
The following is a list of specific problems that can cause instability along with what to check when troubleshooting each.
Viruses can cause instability.
Run a virus check on the computer to look for a possible virus.
Conflicts can cause instability.
Check the Windows Device Manager to see if there are any yellow exclamation marks or red Xs beside the listings for device classifications. If there are, contact Tech Support.
Buggy or damaged software applications can cause instability.
If the system is less stable when certain software programs are running, shut down those programs and see if the problem continues to occur. If the problems stop, chances are that those software programs are causing the problems.
Buggy, outdated, or conflicting drivers can cause instability.
Check manufacturer web sites for updated device drivers for the various devices installed on the computer system, such as: printer drivers, modem drivers, video drivers, sound drivers, USB device drivers, etc.
Update one driver at a time and see if the system stabilizes. If this doesn't work, it may be a hardware problem, so contact Tech Support.
AC problems can cause instability.
Check to see if the computer system is plugged into an overloaded outlet.
Make sure the computer system is plugged into a surge suppressor.
The installation of new devices can cause instability.
There are three typical symptoms that point to this problem:
The computer system fails to boot, freezes during a boot, or freezes during an operation for no apparent reason.
The system fails to recognize the newly installed device.
One or more software applications fail to function as expected after an upgrade.
Hardware failure can cause freezes
Fan failure, cpu failure, memory failure, could be also a cause of freezing.
Keep track of the hardware and software that is added to a computer.
The addition of new hardware and software can often cause problems to occur.
Nov 07, 2008 | Computers & Internet
Antivirus 2008
Some Tips for Dealing with Freezes and Crashes
Research the compatibility of new hardware and software with the existing computer system before purchase and installation.
The older a PC, the more likely it is to crash.
When a computer freezes or crashes, chances are that changes made after the last save and when the freeze or crash occurred will be lost.
Oct 18, 2008 | HP Compaq Presario v3000z Notebook
Desktop freezes and can't do anything!!!!!
I suggest to you do the follow:
Start up your computer and before windows load hit F8, then select SAVE MODE
On SAVE MODE, uninstall all innecesary programs or recently installed, Clean your computer, and be sure that your computer is not virus or spyware infected.
After that reboot and work normally
This will be fixing your problem.
If the problem after that continues is probably then that your have some hardware issue.
Thank you for using FIXYA
Don't forget to rate my help!
Pablo :-)
Oct 14, 2008 | HP Pavilion dv1000 Notebook
SONY VAIO notebook freezes on xp splash screen every 2-4 mos.
first, ensure your system restore is turned on and make a restore point right now!...assuming you have run a thorough disk check and de-frag. then, trust the system restore. I have used it with success 100% of the 20 or so times I have used it. Next, start using the "Hibernate" power down mode. I have found this to work wonders with third-party driver problems. It seems that once a good startup happens, then freeze it (and continue to get a good startup) with hibernate from then on. Last, check about every month for the quantity of restore points that have taken place automatically by Windows. Sometimes, depending on the size of the hard drive, too many points can begin to encroach on your free space that you want for virtual memory or data. So for example, I see 15 restore points in the last month, I will dlete them all by cancelling system restore. Then I use "clean disk" scandisk and defrag. Then I turn restore back on.
Jun 12, 2007 | Sony VAIO VGN-FE790GN Notebook
Acer Aspire E500 PC Desktop Logo
1,939 people viewed this question
Ekse
Alun Cox
