Question about 3M Polygun AE II Hot Melt Glue Gun
I am having difficulty glueing PVC together. I
I am having difficulty glueing PVC together. I have tried roughening the surfaces and cleaning any residual oil off the surfaces with detergent. One particular type of hot glue (for use with a 3M polygun definitely works, but I do not know the product number. Do you know what type of hot glue i should be using?
  • 3 Answers
3M Hot Melt 3764 is the correct adhesive for PVC.
Posted on May 21, 2009
  • 4 Answers
That product is very expensive, I would try Power Adhesives 246. It is a high performance hot melt for dent pulling. Acrylic hot melts also work very well for bonding plastic. Both can be found in a 1/2" stick for the 3M AE II at about half the price of the 3M 3764. Hotmelt.com, Gluegun.com, Amazon, etc.
Posted on Mar 31, 2013
  • 68 Answers
They sell PVC cement at home depot, does it need to be hot glue?
Posted on May 09, 2009
What can I use to put a frame back together
Try a 2 part epoxy resin based adhesive and build a layer over the join at the back as well as putting it between the join surfaces, make sure surfaces are clean and rough all glued areas up with sand paper, do not clamp, and don't disturb for 24 to 48 hours.
Oct 19, 2014 | Cars & Trucks
How to install condensation line on residential AC
Just get PVC 3/4 MIP fitting and enough pipe and elbows to run to drain. Glue together with PVC primer and PVC Glue.
Aug 04, 2014 | Carrier Comfort 3.0 Ton 13 Seer Ac Only...
Pvc line leaks
If you are comfortable using pvc cleaner and glue, cut the line right where the leak is and use a proper size coupling. Cleaning the inside of the coupling and each piece of the pvc pipe. Apply ample amount of glue on each piece of pipe and inside the coupling, insert each piece of pipe into the coupling.
Jan 21, 2013 | Refrigerators
A pin hole in pvc pipe under jacuzzi what can i use
Self amalgamating tape wrapped several times around and well over lapped would probably do it. Just to be sure I would secure it in place with one or two 'jubilee' type hose clips (the sort used to secure radiator hoses on cars) would probably make a quick fix.
For a longer term repair you could try using fibreglass car body repair paste (the sort with fibres in it - not the smooth filler paste). However it will not still to pvc very well. The surface needs to be rubbed with a bit of glass paper to roughen it slightly and then degrease by wiping with a cloth moistened with acetone (nail polish remover would do) before fibre-glassing.
Feb 26, 2011 | Home
Emerson pool pump, pvc pipe between impeller and strainer snapped, how do or can you replace the pvc pipe, it appears both ends are glued
You can buy what is called an internal connecter that fits inside the pipe and glues the two halves back together. It is a specialty pvc fitting not found in home improvement stores. You will likely find them at a local pool service company.
They look like this. They are on the top right with part numbers like S0302-15 for 1.5" pvc pipe.
John
Nov 28, 2010 | Emerson Pool & Spa
Rear break sticks to drum when i tap the brake
replace the shoes with the newer updated shoes that have a new material that is less prone to this problem, sand the brake drum to roughen it up and remove any type of oily residue that may be on the drum surface, spray off everything with brake clean before putting it all back together.
Oct 19, 2010 | Honda CG 125 Cargo Motorcycles
Broken jet line
If the break is in the flexible tubing that connects the nozzles it is most likely spa-flex. This is the same size as nominal schedule 40 pvc and can be repaired with standard pvc fittings, primer and glue. Make sure the surfaces are clean and dry before repairing them and also allow at least 24 hours cure time on the glue.
Mar 10, 2010 | American Standard Home
Chevy S10 Rearview Mirror glue sticks, but temporarily
At this point, I'd take it to a glass shop that does windshields and let them try the commercial adhesive.
Jun 16, 2009 | 2004 Chevrolet S-10
Any way to take apart cemented pvc drain pipe
if the drain is slow or stopped up, i use a high powered drain opener from ace hardware called "liquid fire" it is different from drano and all that other ****.
Apr 12, 2009 | SAIT Portable Saw Cut-Off Wheel TM 12 x...
3M Polygun AE II Hot Melt Glue Gun Logo
884 people viewed this question
Top 3M Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
Debbie
Are you a 3M Craft and Hobby Expert? Answer questions, earn points and help others
