Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive Logo
Posted on Apr 22, 2009
I have a western digital hard drive
I have a hard drive that my lap top or my computer will find. It don't smell hot or doesn't sound like anything is loose. I have tons of pictures on this hard drive. I'm a photographer. Please help
Anonymous
Level 1:
Problem Solver:
  • Contributor 5 Answers
  • Posted on May 01, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
5
Questions
0
Helped
40404
Points
11
To save your data from a bad Wd Ebook you need to download UBUNTU and burn it to a cd. Boot from the cd. Do not install Ubuntu just click try it out. When it loads turn on your Ebook and iit should appear on the desktop. If not click the places tab on top and find it there. Right click the EBook and mount it. Now you have access to all the data on the ebook. If you have enough space n your cpu hard drive save it there, if not you will need another source large enough to copy the data to.. I have used this method to save many hard drives, flash drive and other unreadable media. if the drive is totally toast you are out of luck but this method works most of the time. Any questions drop me an email.
Shayne
1helpful
Western digital humming sound
I'm 99% sure the heads are seized to the platters on this. The buzzing, or humming sound you hear is the spindle motor trying to spin up, but it can't. This is also why the drive is not rotating. Definitely do not power this drive up any more if the data is important to you. If this is one of the smaller Passport style drives, it's pretty common for them to literally rip the read/write heads off as the drive tries to spin up. Professional data recovery is the only option in these cases.
1helpful
I'm running it on a laptop with windows vista home edition. All worked well until I dropped it. The pc doesn't detect it anymore, the blue lights don't flicker anymore, and it makes a ticking...
Dropping a hard drive is never a good thing. They are very sensitive moving parts inside a hard drive and they don't take well to falls. It sounds to me like there was some damage when you dropped it and it may no longer work properly. The clicking is the hard drive trying to read the data and failing. You mentioned that it seemed to come back to life a couple of times...try and recover the data if you can, and contact Western Digital Tech support if you are still under warranty. Hope that helps!
HI I HAVE A WESTERN DIGITAL EXTERNAL HARD DRIVE AND CAN'T GET IT TO WORK ON MY PC I HAVE WINDOWS 7 CAN YOU HELP ME
Just check in device manager...whether is detected by the computer.
you can go to my computer...right click on it...then click on manage.
if its detected there then go device manager...then go to disk management under storage...right click on the drive there with no name then click on change drive name letter..hit ok,,check in my computer you will see the harddrive there...else if you don't see anything in device manager...contact the manufacturer.
Hello...after moving pc and take of power of WD Elements 400, it didn't show up anymore in the My Computer screen and doesn't seem to work...no sound, just the burning blue light..what to do?
Disassemble the case, and remove the 400GB disk-drive.
Connect the disk-drive as a "slave" disk-drive to some desktop computer, and see if you can still access the files.
Get the serial-number from the label on the top of the disk-drive, and access Western Digital's web-site, to check if the device is still under warranty. If it is, W.D. will replace it, at minimal cost to you.
If the warranty has expired, W.D. has a "Customer Loyalty" program -- you can buy another external disk-drive from W.D.'s web-site, at a significant discount.
Lap top will not boot correctly when not connected to ext hard dr
First u check the laptop Display
if it has display, thn it might be problem ur windows
instead of it.
if computer does not give display thn u check the power adopter of ur laptop.
after all gonig through these steps.even u find all these above steps perfect.
it will mean,
it might be problem of ur hardware.
lets check out it by ur computer vendor.
Thanks
Danish khan
2answers
Western digital 1TB porable hard drive problem
a clicking harddrive means thats its dead, if you have a warranty still call up western digital and get it traded out. i wouldnt tell them it was dropped .
2answers
Cant find drive in my computer
western digital corporation(wdc) is probably the maker of the disk, and default name for their drive
open my computer, one click(left) on the drive, rename or open properties, and voila, you can rename it to whatever makes your clock wind up.
thankya for using fixya
2answers
Hadrive Making Knocking Sound, does not function
the knocking sound means that the 'arm' on the inside of the harddrive is going out. unfortunately there's nothing you can really do about it, you may be able to get your data off, but otherwise I'd say it's trash. sorry
Top Western Digital Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Sean Wright
Sean Wright
Paul Bade
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
