Question about Hitachi 51SWX20B 51" Rear Projection Television
No Sound, No Picture
Moved the TV out of it's normal place by 4 or 5'. When we moved it back 3 days later, the red power light comes on but no picture or sound. Also, the TV will turn on, but not off w/the remote control. Prior to this minor move, the TV has had zero problems! We bought it new in 8/02. Can a TV die so suddenly or is it something I did that can be easily fixed? Booie
    President:
  • 4,402 Answers
Loose connection inside i would check the convergence amp area.
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Posted on Jan 28, 2008
SOURCE:
Moved playstation to friends tv played fine. Connected back to my tv power lights come on but No sound or picture yet all cables are ok
You need to reset the display, follow these steps :
Step 1. Turn the PS3 off into standby (red light on)
Step 2. Press and hold the power button. It will beep when you first press it then beep again 5 seconds later. Release the power button when you hear this second beep.
Step 3. Wait for the PS3 to start up with normal display settings. If you are using HDMI make sure only the HDMI cable is connected when doing the above steps.
Hope this helps and thank you for using FixYa
Nov 14, 2010 | Sony Playstation 3 (PS3) Console
We just moved the tv into our new home, when we plugged it in and turned it on nothing happens.. no picture or sound, the timer/standby red light blinks 11 times then nothing. We have tried powering it on...
Well I think what has happened is that the move has caused a failure, it well may have been bumped or jostled, these units are VERY delicate, and should NEVER be moved without using the protective crating, they came that no-one keeps, for any transport, (It is absolutely imperative that you keep your packaging these days as it should NEVER ever be moved without putting it back into that packaging for travel) they really do NOT travel well at all. This what you describe is a classic situation, we see it all the time in my shop. You have little option but to get a "Quote" for a repair. this is indeed unfortunate, but all too common from "shifted" item. Especially TV's.
Mar 22, 2010 | Televison & Video
Tv tunrns on then goes to stand by flashes 4 times & repeats
turn tv on picture comes up 2to3 seconds later tv blacks out then stand by red light flashes 4 times in a row repeatedly..can not turn on or off when stand by light starts flashing but before tv blacks out you can turn tv on and off repeatedly and picture and sound work.You have to unplug power cord for 30 seconds after stand by light comes on to get tv to turn on.
Mar 13, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Rear projection TV! HELP!
Try looking over the tuner solder joints as well as the pins where Input board feeds to the singal board. Sounds like a solder issue or a weak capacitor. Check the solder with a good quality magnifying glass. Let me know how you make out and I will try to help you through the process to nail it down.
Mar 16, 2008 | Akai PTH5498 54" Rear Projection...
No picture, but power light is on
THE POWER SUPPLY OF YOUR TV WAS THE PROBLEM,YOU COLD SOLDER THE MAINBOARD OF YOUR TV,AND THE CRT SOCKET CONNECT TO THE TUBE IS ALSO COLDSOLDER,.
Mar 13, 2008 | RCA 27F530T 27" TV
AKAI Rear projection TV
Try using different inputs besides the RF input. Connect your PS2 and DVD player using component inputs. With two component inputs, there's no reason in the world not to do this.
Feb 28, 2008 | Akai PT4298HD Rear Projection Television
No picture on tv but have sound
how many times it flashes?? if its more than 6 times you have a problem. just lick the red wire that goes to the picture tube.if it does not kill you, you are lucky
Jan 07, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Red power light comes on and no picture
Sometimes after a move,a bad solder connection causes a
part failure,maybe just a fuse device....have it checked by a
qualified technician.............T.
Nov 30, 2007 | Hitachi 43FDX01B TV
Blue Color spots on all pictures
Call a technician, sounds like an Integrated Circuit problem and would cost you about $250.
May 07, 2007 | Philips 60PP9202 60" Rear Projection...
Sound fine, but absolutely no picture?
it seems that your tv has a problem in horizontal circuit (with sound but no pictures). since you moved your tv from one place to another, the tv might have shaken causing to loose some soldered components particularly in horizontal circuit. if u have exprience in this stuffs, try to resolder the circuit, if not, bring it to a service technician.
Jan 09, 2007 | Sony KV-36XBR250 TV
Hitachi 51SWX20B 51" Rear Projection Television Logo
74 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
