Question about Dometic Rooftop RV Air Conditioner
Air conditioner will trip breaker when trying to cycle back on
My air conditioner will run fine until the desired temperature is reached. When it tries to cycle back on it trips the circuit breaker. If I turn the ac off, reset the breaker and then turn the ac back on it runs ok until the next cycle and trips the breaker again.
  • absiss Apr 22, 2009
    ac is a single unit roof mounted duo therm, 13500btu,
    breaker has 2-20amp levers
  • fougzki May 11, 2010
    what is power rating of your aircon?breaker rating?Is it window type or split?
    President:
  • 2,692 Answers
The compressor motor , once warm is grounding out due to wear and is going bad.Have the compressor replace while it is still clean is cheeper and easier that doing it after a burn out,which  will eventually happen,if the compressor is tripping the brreaker as I suspect..
Posted on May 10, 2009
I have a trane xl 1200 heat pump. It only heats after I trip the breaker. When it reaches desired temperature and cuts off. It doesn't heat again. Everything cuts on like it should, just no heat.
Maybe the breaker is opening prematurely. Over time breakers can and do go bad this way. Also check for power consumption of compressor to see if it is within specs.
Nov 18, 2015 | Heating & Cooling
What makes the condenser fan shut off but the compressor keeps running but not every time
Condenser fans cycle on and off to control the temperature/pressure of the refrigerant in the condenser. This is normal operation.
As to cooler weather start up and tripping the breaker; how cold is it when you are running it? If it is too cold you could be pumping liquid refrigerant back to the compressor, slugging it and causing it to trip a breaker. However, many things can cause an air conditioner to over-amp and trip a breaker but this tends to be more problematic as the weather is hotter.
Feb 20, 2015 | Heating & Cooling
My duo therm 13.5 btu rv air conditioner started making a popping sound and dimming the lights like it's trying to cycle to shut off. Well then it started triping the circuit breaker so I changed out the 2...
The best guess is that you have a bad thermostat. When the compressor shuts off it has to stay off for a long enough period of time for the low pressure high pressure to equalize. If it turns the compressor off and back on immediately it can't start against the heavy load created by these unequal pressures. If it will start every time after sitting for 10 minutes the thermostat is making it short cycle.
May 26, 2014 | Dometic Rooftop RV Air Conditioner
I have an Everstar portable air conditioner Model MPA-08CR but when it is working for 10 minutes...it is working fine cooling the desired space but the next 10 minutes it is only working like a fan...then...
The problem may be that you don't have the temperature set low enough and the unit reaches the set temperature quickly and then only the fan runs. Try lowering the set temperature.
Thanks for choosing FixYa.
Aug 05, 2011 | Heating & Cooling
Unit shuts off on hot days
It may be low on refrigerant. On hotter days, the compressor has to run longer to reach the temperature you have on your thermostat. Have it checked for the proper refrigerant charge and have them test how many amps that the compressor is pulluig as well. With the proper breaker installed, the unit should not be tripping out. Make sure that the breaker that is in there now is actually the proper one for your unit.
Best regrds, --W/D--
Aug 01, 2009 | Dometic Rooftop RV Air Conditioner
A/C unit turned off- didnt realize we had a mat covering the unit
If the breaker had tripped, you'd detect some looseness in the trip switch, even though it may not appear to be tripped. Once you have identified the correct breaker, trip it to OFF and then back to ON. Also check at the unit; it will either have a service disconnect, a fused disconnect or a circuit breaker at the wall. Compressor units have a thermal relay that causes them to shut down on high temperature. Let the unit cool down thoroughly. If this is the issue, and you are standing close enough, you may hear it reset when it cools. Usually, cool down occurs in 30 minutes or less. Try it again, but don't leave it unattended until it has made it through several cycles and you are confident that the unit is back to nornal. If any further issues develop from this incident, shut the unit down, trip the circuit breaker for the unit to off and call a serviceperson.
I hope this gets you going again!
Best regards, W/D
Jul 11, 2009 | Amana Heating & Cooling
Tripping circuit breaker
You probably have a dirty condenser coil or the con den ser fan motor is bad or the blades are jam that's why it overheat and shut off by overload.
Apr 20, 2009 | Dometic Rooftop RV Air Conditioner
Mach 3 RV a/c problem
I'm having the same problem tried a new thermostat and cleaning unit inside and out and still the same results. Seems like a control board not working.
Aug 17, 2008 | Dometic Rooftop RV Air Conditioner
Coleman mach 8333 kicks breaker
I changed out the startup and run capacitors. A/C runs fine now
Jul 22, 2008 | Coleman Mach 15 Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
612 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
