Question about Canon PIXMA MP830 All-In-One InkJet Printer
I NEED HELPPPPP! MY CANON IS TELLING ME IN ORDER TO PRINT I NEED TURN OF THE LOCK SWITCH AND THEN TURN THE COMPUTER OFF AND THEN ON AGAIN. WHAT THE HECK IS A LOCKSWITCH?
If you lift the automatic feeder, the scanner lock switch is located in the front left corner of the scanner glass.
please rate me :)
Posted on Apr 22, 2009
So far answers don't coincide with the directions I've been given, which is "Press the WSB Button for 5 seconds."
The print queue is what is locked up. Try deleting the items in the print queue.
Start by pausing the print queue. Then delete the items in the queue one by one.
When you have the last print job in the queue it will probably be jammed up in the transition between the computer and printer. Switch off the printer. This should cause the printer on the computer to become offline.
Try deleting this job abain. If it dissapears then turn the printer back on making sure the computer understands the printer is back online. Then try printing again.
If it does not dissapear then you will need to restart the computer to free up this job. When the computer is back up and running check the print queue again. If the job is gone then turn the printer back on and try printing again. If it is not gone then try once again to delete the print job and it should dissapear this time.
Once the job is gone and the print queue is empty turn the printer back on and make sure the computer understands it is back online again.
Oct 14, 2014 | Canon Office Equipment & Supplies
How do i reset the fuser code on a canon image runner 2200
Here's what another tech on here suggested:
Best Solution posted on Dec 08, 2008
noavatar_s.gif andzulisv
Rank: Guru canon.gif Expert
Rating: 89%, 129 votes
thats a fuser error do this in this order additinol function key then the 2 and the 8 key and the same time then additional func key again screen should change to service mode then touch in this order copier function clear err ok turn off with main switch turm back on if it doesnt clear you have a bad fuser Good luck, hope this helps.
Jun 28, 2010 | Canon (6981A002AA) for imagerunner 2200,...
Canon MP510 wont print. Error message B300 or
May I know the exact error messages in the printer screen. If it's green and yellow lights that are flashing you need to push more the two cartridges that you replace....also try to clean it using the printer program installed in your computer....good luck and hope it will help....
Mar 31, 2010 | Canon PIXMA MP510 All-In-One InkJet...
Canon i9900 - have to restart every time in order to print
reinstall the printer driver and restart the printer spooler service also . make sure that c drive have more then 3GB memory to run the services .......
Oct 23, 2009 | Canon i9900 InkJet Photo Printer
There is an error code E007. I cant print from my computer
there is an error code E007. I cant print from my computer
can you help easy to do this problem please help me
Oct 09, 2009 | Canon imageRUNNER 2018 Copier
Can I download the easy print software for my Canon 1610 printer"
If you do not have the software, you need to download the software from one of the following locations:
Official Canon Drivers and Software
Canon USA:DRIVER & DOWNLOADS
Canon UK - Easy Printing
Download Library - Canon USA
After downloading is finished, unplug the printer USB and run the software that you downloaded.
The software installer will tell you when to connect USB.
Mar 16, 2009 | Canon Axis 1610 Print Server
Canon clc 5100 problem
try a clear server on the Fiery. shut down/re-start
**Warning if u need your job log saved do so before clearing Fiery server.
Mar 09, 2009 | Canon CLC 5100 Copier
Canon pixma 1200
well with canon ip1200, its very easy to solve.And here it goes -- turn on the printer and place the paper to the feeder in order to print.now try to print a file by giving print command.now it will show that "waste ink absorber full" error.At this situation,disconnect the power cable attached at the back of the printer.Keep holding the power button for 5 to 10 seconds.without releasing,turn on the printer and when the power lid glows then on release the power button.turn the printer on again..now the error does not appears again.you can print your file easily.
                          but this is not a complete solution bcoz everyday in order to print, you have to bear the same procedure.
Aug 25, 2008 | Canon i80 InkJet Printer
CANON PIXMA IP1200 resetting
My converted iP1200 is currently blinking green, yellow, green, yellow on the power lights after start up and print request. The pop-up prompt suggests turning off the printer and turning it back on. Error 5100 is always seen.
Please Help Me...
rakibfuture
Mar 30, 2008 | Epson Stylus Multifunction Inkjet Printer/...
Lock switch
Hi muffin, Turn off the machine, open the document cover, and then release the scanner lock switch. You'll see it. Any other problems let me know. Peace, Dude
Nov 24, 2006 | Canon PIXMA MP830 All-In-One InkJet...
Canon PIXMA MP830 All-In-One InkJet Printer Logo
74 people viewed this question
old marine
old marine
