Question about Mitsubishi XL8U Multimedia Projector
Mitsubishi XL8U LCD Projector ALL BLUE screen after lightning
I have a Mitsubishi XL8U projector that went all blue when booted after lightning struck behind our home. The strike took out several computer items, laptop and this projector. Is there a simple fix ? Worth sending to a repair shop? The bulb is still working just all blue screen.
5 Suggested Answers
marsrover
  • 682 Answers
SOURCE: mitsubishi xl8u projector
go to menu and press it---press right or left arrow button and go to installation press enter.
--go down by down arrow to image reverse- use left and right arrow to adjust the image to the correct position.
Posted on Mar 17, 2008
Marrie
  • 563 Answers
SOURCE: Mitsubishi XL8U Projector
Hi terry2421
No this is not the bulb. You will have to get the Mainboard repaired at a service provider. Losing signal and a discolouration showing up is a clear indication of a faulty Mainboard.
Get a quote first , because some service providers overcharge on these sort of repairs. The most you should pay is $150.
Posted on May 22, 2008
  • 32 Answers
SOURCE: Yelloy spot
Yellowish colorization on center of displays is not a prizm issue. It is generally a need of cleaning factor. Even with the filters clean, the LCD's can and acquire heavy dust build up on the panels. This is not limited only to the LCD's it also applies to the polarizers and spectrum filters. Your unit most likely requires deep lens and panel cleaning. This is done by trained professionals, as they can be permanently damaged if the proper tools are not used.
Posted on Jul 10, 2009
projdoc
  • 2237 Answers
SOURCE: Infocus projector power supply parts
you won't find schematics for them. infocus had their boards made by someone else who now no longer makes boards. it's usually the caps drying out that causes power problems.
Posted on Sep 04, 2009
Why will my mitsubishi lvp x300 projector only project a blue screen when I turn it on?
Blue is probably the default "no signal" screen. It means that the projector is getting no signal.
Sep 06, 2014 | Mitsubishi LVP-X300 Multimedia Projector
Why will my mitsubishi lvp-x300 projector only project a solid, blue screen?
Blue is probably the default "no signal" screen. It means that the projector is getting no signal..
Why does my Mitsubishi hc5500 projector only display a blue screen but still play sound?
The unit may need cleaning. The lamp will shut off if the air flow is blocked by dust.
Aug 31, 2014 | Mitsubishi HC5500 LCD Projector
When I turn the projector, i hear clicking from my AV receiver, the MITSUBUSHI screen then blue screen shows up on the wall, but then it says no signal: then the projector goes to standby without me doing...
The problem is most likely a warped plastic housing around the color wheel. When the wheel is forced to stop, the projector will go to standby and the lights indicate a problem.
Apr 23, 2017 | Mitsubishi HC5500 LCD Projector
Why is the Status Light on my Mitsubishi XL8U flashing red? My projector is still working but the status light flashes red.
With out knowing the state of the power LED, my best guess is the Status light is solid red and telling you to purchase a replacement lamp before the current one dies. Attached is a chart that will show you the errors possible depending on the LED statuses:
Mar 11, 2011 | Mitsubishi Lamp For Mitsubishi XL8U...
Yelloy spot
Depending on what it is if it looke like a scorch mark the it is not the Optical Engine (prism) it is more likely to be the polerising filter most are quite esly changed and would cost about £15 ($30) for parts and about twice that to get them fitted at a service center, if it is pixel dots then it is a LCD replacement and not worth doing.
Marc Engineer
Jan 06, 2009 | Mitsubishi XL8U Multimedia Projector
Hi terry2421
May 20, 2008 | Mitsubishi XL8U Multimedia Projector
I have a Mitsubishi xl8u projector, with approx 2000 hrs max on its first lamp. Of late, the projected image has attained a blue tinge to its edges which is getting progressively worse and seems to be...
Hi Bob
This most definitelly NOT the lamp.
It is unfortunatelly your Mainboard that is at fault , and will either need repair or replacement as this will only get worse as time passes.
Hope this is of help !
Apr 20, 2008 | Mitsubishi XL8U Multimedia Projector
Mar 15, 2008 | Mitsubishi XL8U Multimedia Projector
Mitsubishi XL8U Multimedia Projector Logo
288 people viewed this question
Top Mitsubishi Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Mitsubishi Office Equipment and Supply Expert? Answer questions, earn points and help others
