Question about Sony HT-7100DH System
Picture problems We installed the system to our Sony Bravia TV and now the top and bottom of the picture is cut off. We have tried using the remote for the Bravia and have not been able to fix this problme.
  • 1 more comment
  • Mike001005 Dec 10, 2007
    no sound when i use the HDMI ports.
  • Distanceluke Dec 11, 2007
    Should I shut off my subwoofer in the back, when I'm not using the stereo?
  • taylorcj71 Sep 01, 2008
    Have the same problem. Haven't been able to fix it yet. Very frustrating.
I noticed that the "wide screen" button has 4 different options that should remedy this.  I think some of them are, "full scree, zoom, zoom wide, and normal".  hopefully this will help you out
Posted on Feb 24, 2008
SOURCE:
I have a Sony Bravia TV and the screen seems to be locked on AV1 I can here the cable channel but can't see the picture. Is there any way for me to unlock the setting so I can see the picture?
Please try this:
With your remote set on AV1, push the input button and try to change the input using the up and down arrows. You want to set it on cable or whatever your TV input normally says. I have Satellite TV and mine says satellite. You should be able to easily change it with the input button. If you can't do it, change the setting on your remote to TV and then try the same procedure. The Sony Bravia has manual controls on top of the set as well. If you are unable to change your input using the remote, try the manual controls, however, your remote does need to be reset for the correct setting as well. Using the manual controls will just help you check to see if there is actually a problem with your TV. Is this a new TV, new problem?Have you changed batteries in your remote recently?
I hope this helps you. If not get back to me, and let me know.
Thank you for using FixYa.
Dec 26, 2010 | Sony Bravia KDL-32V4000 32 in. LCD TV
The picture is to ig for the screen in any mode - i have it on full and it cuts everything off teh top and bottom sony bravia
try checking the aspect ratio settings on the device feeding the tv if applicable, i.e set top box, DVD player, etc
Ensure the settings match the tv type, e.g, 16:9 for a widescreen tv. 4:3 may cause cropping of the top/ bottom of the picture if this is set
Jul 02, 2010 | Televison & Video
Picture too large for screen
Press "wide mode" on TV remote until it is on "full". Check for same on set-top box.
May 02, 2010 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
My sony bravia tv's picture is so wide it cuts off certain things on the top and the bottom, like when there are words on the bottom of the screen i only see half
change picture format to 16.9 in the menu or if there is button on remote ( aspect / format or zoom ) or a picture of a square with two lines in it press until picture look ok
Dec 14, 2009 | Sony BRAVIA KDL52XBR2 Television
Part of the picture is being cut off, how do i
Just called Sony about this same problem...taking your CABLE BOX remote, push the # key on the bottom right of the remote (it also says HD Zoom on mine). You can cycle through 4 or 5 zoom options...make sure you are on an HD channel to see the changes. :)
Nov 27, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Vertical needs adjusted. both bottom and top of screen are cut off
On the remote look for a button labeled aspect,zoom or picture size. Press that button repeatedly until the picture is the desired size.
Nov 21, 2009 | Sony BRAVIA KDL-40XBR2 40 in. LCD HDTV
The top of people's ehads on the screen are cut
Is your zoom function on, making the picture too close? Check the zoom function on the TV AND the cable remote.
Sep 27, 2009 | Sony Televison & Video
Sony bravia loosing the top and bottom of picture.
Try the aspect ratio button on the remote or it is possibly an on screen aspect adjus
Aug 08, 2009 | JVC LT42P789 42 in. LCD TV
Black frame around picture
Toggle through the "Picture Format" settings from your tv remote.
Flip through cinema mode, too standard....etc
Jun 12, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Theres no picture on my sony bravia KDL-40S4100
Try pressing the TV/Video button. The problem could be that the TV is set to an input with no source.
Feb 11, 2009 | Sony BRAVIA KDL52XBR2 Television
Sony HT-7100DH System Logo
248 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Ekse
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
