Question about Samsung HL-T5675S Television
Turns itself off after 5 seconds of run time. will not stay on, cooling fans work, lights up screen and shows picture, then shuts off. light flash on front right corner.
  • 48 Answers
Either lamp is failing (not covered under any warranty), or the ballast has failed. Or it may be a problem with the power supply, or even the fans... What is the picture next to the flashing light? If it's only the lamp light, then either lamp or ballast, if temp is flashing (the thermometer), it will be fans, temperature sensors, main board or power supply.
Posted on Apr 22, 2009
TV turns itself off, then on automaticlly
The fan should run for a few minutes after shut off to cool the lamp down.
If I read and understand correctly somewhere in the cycle you are getting 5 red blinks? that is an error code........
Either you or I can Google the model number of the set with 5 blinks.....or visit the Sony site to see what it means.....
Apr 24, 2012 | Sony KF-42WE620
Well my mom was watching tv and it just shut off so then my mom turned it back on thinking she might have hit the power button accidentally. But when she turns it on it started blinking the green light for...
The flashing light red power light should only stay while the fan cool down for about 1 minute after a power off (remember to always wait before unplugging the TV so the lamp can cool down with the fan). Does that flashing start right away after plugging back the TV after an hour of letting it without AC power.
The red light should flash no longer than 10 sec. This prepare the light to be turned on. If all is OK the green should stay (no longer flashing) and the sound and picture come on.
As for the lamp flashing, i bet it's only 1 time each 5 sec? Or do it group many rapid flash each 5 sec?
Things that can be wrong:
-the fan lamp
-the lamp is not proprely inserted (wait an hour before manipulating it to be sure it cooled down, and use glove to not put body oil on it).
-Lamps is defective and is not operating properly so you can't get to the usual on screen message that recommend to change the lamp.
Sep 02, 2010 | Panasonic PT-60LCX64 Television
I have a Phillips big screen tv and the front light is flashing red at all times and the picture will not come on the screen. This light is usually green when the set is on. What can I do to get it green...
I have the SAME issue and so far it seems to be an issue with the fan not kicking on.... I turn it on in the morning, as soon as you hear sound the red lights kick on and I shut it off... it takes a few seconds to shut down so stay close to your remote durring this process and as soon as the "red light" kicks in, turn it off, as soon as it's off, turn it back on... I have to go thru this about 30 times now before I can get the picture to stay on, but it eventually kicks in. Hope this helps!
Aug 24, 2010 | Philips GOGEAR SA6045 MP3 Player
No picture, siren type noise as restarting
My Toshiba dlp 62hm116 was used for 3 months then stored for 2 years, I turned it on yesterday and it makes a loud grinding noise which I think is probably from the exhaust fan area and the picture is black except white at both vertical sides. It worked fine the last time I used it 2 years ago. Any ideas?
Jan 13, 2010 | Toshiba 62HM95 62" DLP HDTV
Projector screen turns off after 10-20 seconds
Is the projector receiving a source signal? if not it will power itself down after whatever time you have it set to do so when no signal is present.
Just an idea?
Jan 03, 2010 | NEC NP-1000 Projector
55" TV keeps shutting off automatically
Green light flashes 5 and then red light flashes 6
Sep 14, 2009 | Sony KDF-E55A20 55 in. LCD Television
Standby LED flashes red 4 times with pause then 4 times
You either have a bad fan or one of the rotation sensors mounted on one of the fans has failed. Take the back off the set and see it the main fan slightly right of center is rotating. If it is, there are two more fans, one mounted right above the lamp and another on the optical block itself. You will have to pull the optical block to check those.
Oct 25, 2008 | Sony KDF-E42A10 42 in. LCD Television
Green flashes then tv turns off
or a new lamp. you could first replace the lamp.
the screen might work fine for a couple of seconds, but then it fades away or deteriorates. This means the lamp is going bad.
Aug 23, 2008 | Sony KP-51HW40 51" Rear Projection...
Samsung HL-T5675S Television Logo
203 people viewed this question
Henry  Thomas
Henry Thomas
