Wiring diagram Hello. I have a sentry marine development corp battery charger. Model c120-3n. serial f60075. Input 4 amps/150volts output 20 amps/12volts. There is a white, red and a black wire. Can you tell me where they go? I have two sets of batteries. Starting and house. Thank you. James.
James,
Is the charger you have new or used?
If it is new or in good condition used, I might be interested in buying it from you if it is for sale.
cedmunds@tampabay.rr.com.
Posted on Jun 21, 2009
Has anyone a circuit diagram and possibly information about the transformer output voltages for a Pihsiang mobility charger model MB-24/3 battery charger?
Hi again i have no data on Ac voltage output AT A GUESS I WOULD THINK IT WOULD B APROX 35 TO 38 VOLTS one thing i did find u can still buy them at MONSTER SCOOTER PARTS ITEM NoCO4-1179 PRICE $183-99 PHONE NUMBER 800-798_0325 GOOD LUCK. input : 100-120 VAC, 50/60Hz 1.5 AMP. U CAN BUY NEW ONE'S ON E/BAY,,..hi output is 24 volts 3.0 amps hope this helps..........
Dec 11, 2015 | Health & Beauty
What specifications do i use to get a replacement charger for a Peak Charging Adapter . . . . . . . . 120 volt AC (700mA, 12 volt DC Output
Just as your information says ask for a 12 volt 700 ma charger..but seeing that yours is a 450 amp jumper..any 12 volt that fits your ac input will do the job...one more thing if you do not have a charger..just connect it to your battery and run the engine for 20 min or so it will recharge the car battery and you jumper..also you can get a lighter wire with two lighter plugs and charge it through you lighter..good luck
Oct 22, 2014 | 450 Amp Jump-Starter with USB and 12 Volt...
Appears to not be charging but does produce 110
Anytime external AC is being applied, the unit passes that AC input through to the output, independent of inverter/charger status. If external AC power is available but the unit is not charging (i.e. the Charge light is lit, but the batteries are not charging up as they should), then there is likely a problem with the AC sensing circuit card inside the unit, with a 1/4 amp fuse and/or the AC transformer the most probably culprits. Without external AC, the inverter will function all the way down to 10V, but then will shut off, so as long as your batteries have not been totally depleted,the unit will still be able to produce 110 AC after a brief charge cycle, but it won't for long.
Sep 17, 2010 | Xantrex Technology Heart Freedom 20 12...
Hello , i got and old MAXI MOUSE PORTABLE SPEAKER/AMP and i lost my CH-40 charger, do you know how i can get a new one or something similar. i live in Sweden
hello, if you also have 230V in sweden then look at your electronic supplier for a: Input AC 230V/50Hz/90mA/21VA Output: AC 22V/520mA/11,4VA
that's written on the charger.
Sep 23, 2009 | Audio Players & Recorders
Don't have wiring diagram
This was taken from the manual that I have.
Yellow - Serial data 1 output
Green - Serial data 1 input
Red - Batt (+)
White - Serial port Ground
Black - Batt (-)
Grey - Serial port Data output
Jul 15, 2008 | ICOM Informatique GP-270ML GPS Receiver
In car charger
To see if it's compatible, you will need to read on the machine to find out the input range, or output on the charger. If the input/output levels are within 1 volt they are compatible.
Car chargers are expensive, around $125 to $185. You can get in inverter that plugs into a cigarette lighter that has two regular sockets from Walmart for around $20. The inverter is made by Black & Decker, you just plug the regular charger into it, and it's considerably cheaper than buying a car adapter. Make sure the inverter is 100 watt continuous.
This is for the US. If you're not in the US there are companies that make international inverters, however, with me being in the US I've never had the need for one, so I couldn't tell you what company exactly. You will have to Google it to find out.
Jul 08, 2008 | Computers & Internet
Heating & Cooling Logo
257 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
