Question about Western Digital 320GB MyBook External USB 2.0 Hard Drive
External USB Drives No Longer Detected
I am running Windows XP Home SP3 and I have two WD External USB drives connected to my desktop. I am using USB 2.0 cables (the light up kind) and the hard drives have their own power. They are both connected to a PCI USB 2.0 card with four slots total.
Everything worked fine until I disconnected the drives from the USB slots to move the computer and remove a stick of RAM I needed for another PC.
When I reconnected the drives and powered on the computer the drives were no longer detected. They don't show up in my computer, or when I use disk management. They both work fine on my laptop. They are seemingly connected properly, because the USB cables light up when they are connected, and the USB card is seated correctly becasue it detects my flash drives.
There are no problems showing in device manager like question marks or exclamation marks. I tried uninstalling the USB entries in the device manager, rebooting and letting it detect the drives again, with no success. It recreates entries for the USB controllers but still the drives aren't detected. I have a separate USB slot on the front of the computer, but neither drive is detected there either. I've tried connecting the drives separately, one at a time, with no other devices connected, and powering them up after the PC is on, before it's on, etc, etc, to no avail.
The only other thing that was changed was that I had 1 Gig of Ram and now am only using 768.
My PC is a Pentium 4 2.4 Gig. with a 750 watt power supply. Besides the two external drives, I also have 4 internal drives. 2 IDE and 2 SATA. Again everything ran fine before I disconnected the drives from their USB ports.
Any suggestion would be greatly appreciated. Thanks.
  • jwal97 May 04, 2009
    There are TWO drives that were just unplugged from the USB slots when everything was off, then plugged back in. They weren't "dropped" .The drives work fine. Everything else works fine plugged into the USB slots.
  • 19,396 Answers
There are two possibilities:
The Mybook USB/ATA controller board is faulty.
In this case you can simply take apart the enclosure and mount the disk into a new enclosure. WD Mybooks are SATA, but double check the hard disk connector to ensure.
The hard disk inside is faulty.
In this case repair may be expensive. You need to locate a data recovery facility with a 'clean room' , the cost is usually more than $800.
If this happened after a power surge, then the problem is most likely a faulty controller board.
If instead you have dropped the hard disk it is possible an hard drive failure, in that case repair will be expensive.
A replacement enclosure will stfrom art about $20 on Ebay or Amazon, and must not necessarily be WD .
Check if your disk is Sata or PATA (IDE) before buying the enclosure.
Posted on May 04, 2009
  • 2 more comments
  • Ginko
    Ginko May 04, 2009
    If the drive are not being detected, they may be damaged, as I told you, you need to test them on a different computer.
    If the drives are fine, then the problem is on the computer, test different USB devices, and leave computer unplugged for ten minutes.
    You say any help is welcome, you received help from a professional guy, then rated inappropriate, what is the meaning of this?
    I will be grateful if you can change the inappropriate rating inaappropriately given for the free advice.
    Many thanks.
  • Ginko
    Ginko May 04, 2009
    I read back your problem. You ar telling that the USB hard drives are fine on your laptop, therefore the problem is the computer.
    A common problem is accumulation of electrostatic charges on usb controller caps, this will prevent USB from detecting certain devices, to rule out this you unplug computer power cord for about ten minutes.
    If that does not work, then test the computer booting from a different system, this can be easily done using a boot disk. This will esclude possible system problems (no matter if you reinstalled USB and there is no yellow sign, this can still be a system problem).
    If you are using an USB hub or an USB PCI card, than that can be the problem , you need to test on computer USB or replace PCI card.
    Additionally if computer is Windows 2000 or earlier it may need additional drivers to use the external disk.
    The above is more or less what we would do at a repair shop.
    Let me now your opinion.
    Thanks.
  • Ginko
    Ginko May 04, 2009
    Well my solution kept going, and even if my first post was not precise, it was not inappropriate. Moreover I added more to the solution, are you one of our Fixya experts by chance?
    Thanks and goodbye.
  • Ginko
    Ginko May 04, 2009
    Well , capitals and the rest are not nice, no problem, I understand now, just sorry.
    When you spend your time helping others for free is is sad to face this kind of situation, but I got used to it.
    Sorry to bother you with my answer, nevermind.
    Goodbye and have a nice day.
    G.
I am using windows xp home edition (SP2), when I'm going to insert an external drive to my pc, the external drive is detected but I cannot open it rather it appears "the request could not be performed...
Good Day!
is your HD Fell? have you try to open it to another computer? try it first. if the computer you inserted is OK. there seems a problem regardless to your computer. try to reformat it and install Win XP pro. (SP3)
Thanks and God Bless!
Apr 04, 2011 | Western Digital Elements (WDE1U4000N) 400...
Not detected in xp
hi
go to WD site and get drivers for XP downlod and run that then try hopw fully it will work
May 25, 2010 | Western Digital My Passport Essential...
MY PASSPORT ESSENTIAL WD1600ME-00 is not recognized by plug-and-play in either of my HP Desktop Windows computers (One with XP, one with VISTA). Power light comes on when attached to any USB port. Device...
You run MS Windows Update to download and install the latest OS updates. Your WD external HDD should be detected after OS update.
For non updates system, try to connect WD to the USB Port where it worked before. If you have 4 USB ports for instance, try to connect it to these ports one try at a time. Windows XP might have assigned one USB port for your device before when it was working just fine.
Feb 02, 2010 | Western Digital WD Passport 250GB Portable...
I connected the external floppy drive to a USB hub which in turn is connected directly to a USB port on my Dell desktop which runs Windows XP Home Edition 64 bit version and the drive just runs and will...
Yes, the external floppy drive must be connected directly to a USB port on the computer instead of to a USB hub.The PC can't see the drive thru the USB hub. Applies to both 32 and 64 bit.
Sep 07, 2009 | Computers & Internet
WD Caviar SE16 WD3200AAKS 320GB 7200 not recognized at install
Windows XP does not have built in SATA drivers. You will need to download the XP drivers from Western Digital's website and install before the computer will allow you to format and use your new drive. Hope this helps.
Jul 18, 2009 | Western Digital (WD3200JS) 320 GB Hard...
I havea seagate 500gb external hard disk, when i connect it wth the laptop the hard disk is not recognised on my laptop. i have windows xp professional installled in my laptop
Click on the link below and then click on the "Fixit" button. Windows has a patch for all external devices not recognized by PC's including HD's. This is especially an issue for those who've recently installed SP3. Best of luck with your problem.
Greg
http://support.microsoft.com/kb/925196
May 25, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Maxtor 3100 will not work on Desktop with Windows XP Home version
actually telephone numbers are not available through this service...perhaps you will consider a premium or chat investment of your resources.
Oct 20, 2008 | Maxtor Personal Storage 3100 (M01E100) 100...
Won't recognize on windows XP(SP3)
try other usb port, or other computer and see whether the hdd is detected. If still not, try to go to device manager ( http://www.computerhope.com/issues/ch000833.htm ), and then assign a drive letter to the hdd. After that, try to access it from Computer, if not able to access it, format it (use quick format) and then use asoftech data recovery program to recover your files.
http://www.asoftech.com/adr/
Aug 10, 2008 | SmartDisk 160GB FIRELITE PORTABLE FIREWIRE...
Western Digital 320GB MyBook External USB 2.0 Hard Drive Logo
561 people viewed this question
Top Western Digital Computers & Internet Experts
Marcin
Mike
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
