Question about Yamaha CDM-900 110-Disc CD Changer
I can't open my Yamaha CDM-900 110 cd changer
I tipped it backward and a bunch of cds fell out of the holders and back into the cabinet. Now I cant open it to pick up the mess. Is there a trick to getting it open?
Thank you!
techman
  • 3130 Answers
SOURCE: my CD changer's disk tray keeps opening up, refuses to play discs
You have a problem with the try control circuit. It could be the switch is leaking across itself. Could be a problem with the tray motor control IC, or the Microprocessor is not reseting the open tray line correctly, or theres a cam assembly inside the unit that tells the microprocessor where everything is by means of small micro/leaf type switches thats out of alighnment or broken. If its seven years old, you got more then it was designed for and I would'nt invest a dime or the time into the repair of this unit. Time to take a trip to the electronics store. Good luck
Posted on Jul 21, 2006
petraman7
  • 1175 Answers
SOURCE: yamaha cdc 555 5 disc cd player
If you trust yourself enough to open the case w/o breaking stuff, then open it up UNPLUGGED, locate the laser lens (small,clear,plastic) gently clean the lens with a swab of lens cleaner for glasses.
Also clean the chrome runners that the laser assembly tracks on.
Posted on Jun 26, 2008
petraman7
  • 1175 Answers
SOURCE: Disc door keeps opening.
The drawer belt may also lift the laser up to meet the CD . If the belt is bad , the CD player will kick out the CD.
Change the belt.
Try studiosoundelectronics.com
or
mcmelectronics.com
Posted on Jan 12, 2009
satavlad
  • 405 Answers
SOURCE: The changer does not detect CDs in it. After
Optical pick up replacement required to rectify this problem
Posted on Nov 28, 2009
  • 141 Answers
SOURCE: need drawer belt for Yamaha cdc-805 CD changer
Any decent repair shop should have a large supply of replacement belts. The Part number isn't necessary. Just take the old one in and get a new one just 2mm smaller than the original. Some repair shops won;t sell them because they don't want you repairing your own property but a decent shop should sell you one.
Posted on Apr 07, 2010
We just moved and the movers tipped it so it is jammed and you can see that the CDs in the back of the carosel are sticking out. What do I do to open it up and get them out?
Make sure it is unplugged, then remove 2 screws from each side (the only ones on the sides) and 3-4 screws from the back at the very top (where the metal cover folds over the back) that will allow you to remove the cover and the jammed discs, not to hard good luck
Jun 07, 2010 | Sony CDP-CX151 100-Disc CD Changer
Need drawer belt for Yamaha CDC-805 CD changer - the one needed that opens and closes the changer's door - not sure where to get it or the part number. I thought I ordered the right one and got the 'drive'...
Apr 07, 2010 | Yamaha CDC-745 5-Disc CD Changer
Yamaha CDC-765: sometimes skips when playing CDs
The problem is in the laser for sure. Try cleaning with a cd cleaning tool. It's the easiest solution because changing the laser is not always available solution.
Stelios.
Feb 21, 2010 | Yamaha CDC-765 5-Disc CD Changer
Jammed cds in a 6 cd changer ford ranger 2002
sounds like the tray inside was misaligned when the cd went in. and it probally sent the disc into a occupied slot. you will have to remove radio and disassemble to repair. also try just unpluging radio and plug back in. sometimes it resets the radio and will start ejecting the cds
Feb 05, 2010 | OEM Systems Car Audio & Video
Nov 26, 2009 | Yamaha CDC-697 - CD changer 5-Disc CD...
Onkyo 6 disc cd changer DX-380 has CD stuck under carousel
This has just happened to us. Often when the changer tries to select a CD on random play, it somehow knocks one CD off the carousel, usually on top of the other 5 CDs and then you can retrieve it easily. This time it knocked it down behind the carousel so the drawer could not close. We left the drawer open, carefully took the player out and tipped it upside down and then tipped it forward. We then closed the drawer while it was still upside down and then turned the player back up the right way. The loose CD fell onto the carousel and we could then open it and retrieve the CD. No damage to either CD or changer and we are now listening to music again!
Jan 04, 2009 | Onkyo DX-C380 6-Disc CD Changer
Cd tray stuck closed
open the cabinet and remove the magnetic lock placed on the top of the mechanism then u can remove the cd
Jan 02, 2008 | Yamaha GX-505 CD Shelf System
Cds stuck in sony cdxt69
Take power away for 5min then plug back up. Hit reset with pen head.
Sep 17, 2007 | Sony CDX-T69 6-Disc CD Changer
Yamaha CDM-900 110-Disc CD Changer Logo
169 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
