Question about Sony Playstation 3 (PS3) Console
Console starts up and I can hear but shows no picture.
I have a PS3 that I bought from a friend. I hooked it up to two different sets of wires and it still doesn't work. Everything will start up good, I can hear everything but no picture. Anybody have any ideas? I have another PS3 that works wonderful on the tv and wires that I was testing this one on. Thanks!
  • 83 Answers
Make sure video cable is plugged in all the way on back of ps3. the a/v cable is little tricky. it looks like its plugged all the way but its not. also if doesnt work, if u have hdmi cable use it then go to display settings, then connetions. set it up as av cable connection then it will ask about audio - av rca connetions. and save. now its set up as av cables and then when u use hdmi it will automatically set up hdmi.
Posted on Apr 22, 2009
My mic doesn't work
Go into your settings for the thing. Sometimes they will get changed. Make sure the output is set to your brand mic.
Oct 10, 2012 | Sony Playstation3 Ps3 98097 Bluetooth...
I have been trying to get online with my PS3 for a couple of days now. I just got it and it doesnt seem to be working. I know it works because my friend used to own it and it worked fine. I bought a cord...
hellol josh, try this This does seem to be a hardware problem it has happened to people when updating with version 2.76 software and version 3.0 , 3.01 . Try reseting your ps3 by turning the power off then on at the back, then holding the on/off button on the front for five seconds untill it beeps twice . Then goto network settings and go custom go along all the obvious untill dns then go manual. On your p.c, goto run on the start menu , type in cmd an press enter , a black dos window will appear type in ipconfig/all . This gives you all your network settings scroll down to primary d.n.s and secondary d.n.s servers put those two numbers into your playstation . Everything else auto . Test connection good luck
regards
shaun
Oct 05, 2011 | Sony Playstation 3 (PS3) Console
I plugged in my PS3 using an HDMI cable and i get no feedback
If you just bought the PS3 use your composite cables that came with the system. Turn the PS3 on and go to the video settings, set up video input to HDMI. After you've done that plug your HDMI back into your PS3 and try turning it on. If that works go back to video settings and change the resolution to 1080p. If that doesn't work make sure your T.V. is on the same input that the HDMI cable is plugged in. If it is and still doesn't work try switching to a different HDMI port. If switching to a different HDMI port doesn't work try a new HDMI cable. If the new HDMI cable doesn't work then there is a problem with the port on the PS3 which would require a repair.
May 03, 2011 | Toshiba 50HP66 50 in. Plasma Television
I just get a blank screen with no sound or anything when i turn it on
I once had this issue, the solution was hard to find(five hours), but fairly simple. (This works for HDMI cable set up, but I'm not sure concerning AV)
Note: Yes, the solution sounds ridiculous, but for this issue, it works.
1. Unhook your PS3 from the current TV/Computer screen you have it hooked up to.
2. Hook it up to a different TV/Computer screen that you have or a friend may have.
3. Power on the PS3 and it should have a screen and everything and work just fine.
4. Hook it back to your original TV/Computer screen and power on the PS3 and it should work fine there again aswell.
Jan 23, 2011 | Sony Playstation 3 (PS3) Console
Dynex tv works. bought ps3. when hooked up to
I would suggest you check if your PS3 is set up on going through the HDMI Cable.On your PS3's XMB scroll to settings -> Display Settings -> ANd from there go down to the one that says "Y Pb/Cb Pr/Cr Super-White (HDMI)" and hit X and select the option Yes... That sets the PS3 displaying through the HDMI
If you are already have done that I'm pretty sure you know you have to change the Input on your TV to HDMI... Take your remote and hit Input -> Scroll down to HDMI on the Input Source menu and hit Enter when you get to HDMI
If the AV on your PS3 works and not your HDMI sounds like Display Settings issue...
If you have done all that, that is strange if it still doesn't work.
There are some people that are having problems with the AV Cable with the PS3, I tried this and it really does work. I switched from HDMI on one tv to a AV Cable on another and when I did that neither TV would display content from my tv. The fix for this is resetting your PS3, like on a iDevice you hold the home button and lock button, for the PS3 you hold the Power off button and the Eject button for around 10 seconds. This resets your PS3 into default video settings. Until it Turns on, Beeps, and Turns off. This should work.
Jan 01, 2010 | Televison & Video
Cant get wired internet on my ps3
A cable modem & a router are two different things. You can pick up a "Cisco 'EtherFast' cable/DSL" (wired or wireless) router at Wal Mart for $35. But you need both a modem & router to get your PS3 up & running on the web. Once you get on, you'll need to set up a "PlayStation" account. Unlike the Xbox 360 Live network, PlayStation is free of charge. It's a very user-friendly interface, so you shouldn't have any problems there. Cisco will give you live customer service to walk you through hooking up your router. Please let me know you make out. If I can be of further assistance, please let me know. Good luck, bro.
May 09, 2009 | Sony Playstation 3 (PS3) Console
Denon avr-1907 sound from TV stopped working
Help with hooking PS3 to a Denon Receiver. It worked before, but I had to move everything to a different location and when I hooked it back up the PS3 has sound but no picture. I have it hooked directly to the receiver with and HDMI cable (the receiver is hooked up to our cable box which is directly hooked to the tv via HDMI cable).
Jan 03, 2009 | Denon AVR-1907 Receiver
My Ps3 wont start my game!
If all of your other games are working then it's probably just a software update for that game. If you are hooked up to the internet via your PS3 it should download the update automatically, but it may not do it unless the game is in the machine. Make sure that your interent connection is good to the PS3, slide the game in and leave it for a while. Maybe a couple of hours and then reset and try game again. Depending on your connection updates could take anywhere from 10mins to over an hour. Sometimes the server will time out too if the update it taking too long. Also, change your PS3 auto start game setting to off, once you do this you will have to slect the game from your PS3 menu to access it and play it. If you have a friend with a PS3 or go the store where you bought it and see if they have the same problem with the game, it could just be bad batch of discs. In that case buy it at another store.
Jan 15, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
76 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
