Question about Bosch Axxis WFL 2060 Front Load Washer
Washer will not start
I have a bosch axxis and the water is on and the doors lock and the lites come on but nothing happens
    Problem Solver:
  • 14 Answers
Your wahing drum is broken. It is very complicated to fix it by yourself, so I reccomend hiring a professional to do it. Also,
  • The belt may have broken. The drum may be jammed by an item of clothing.
  • The main motor may be faulty.
  • There may be a broken wire to the motor.
Posted on May 03, 2009
Washer won't start
Sounds like the door lock may be faulty or it isn't closed fully. If it has a child lock check you haven't set it by mistake, you have to hold the start for 5 secs+ to override it.
Mar 07, 2013 | Bosch Axxis WFL 2060 Front Load Washer
Bosch axxis washer fills door locks then nothing no agitate or spin it dose drain when the control is set to spin
The timer/controller is faulty.
Replacement is the only fix.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 25, 2009 | Bosch Axxis WFL 2060 Front Load Washer
When I start my Bosch Axxis machine - I purchased it used - I do not hear the water start and the cycle isn't starting.
When you close door properly and press start does the door latch? If not possibly the latch is the problem. If it doesnt give a normally closed condition, the micro processor wont continue.
Sep 21, 2009 | Bosch Axxis WFL 2060 Front Load Washer
Lights come on,door locks ,nothing happens on my bosch 2060 uc washer, sweetie says "it was making a funny noise the last time it was working" while it was spinning . thanks!
the engine maybe has no connection or motor is bad thats why wont start up,check if it belt is good ,if need more info let me knw,if my info was of any help to you please comment me ,thank you.
Sep 02, 2009 | Bosch Axxis WFL 2060 Front Load Washer
Bosch Axxis WFL 2060 washer leaks
Hi. Check the doorseal by lifting the folded lip which faces toward the drum opening. Use a torch and carefully examine the doorseal. It may have a small hole which is hard to see at first.
If door seal is ok remove top of machine and check inlet valve. Turn power off and with your hand examine the inlet water valve. If it feels damp on the solenoid then it leaks from there and finds its way around to the front of the machine though the frame work. This leak happens due to to much water pressure at your laundry taps. If so install a pressure reducing valve before the water inlet hose and replace the water inlet valve in the machine as it is now faulty.
0417362396 Melbourne metro area
Regards Sam
Mar 08, 2009 | Bosch Axxis WFL 2060 Front Load Washer
Bosch axxis wtl 5400 dryer
I found that the dryer will not start because the door isn't fully closed. My wife has basically split the plastic door a bit, but if you firmly close the door, it will start.
Jul 25, 2008 | Bosch Axxis WTL 5410 Electric Dryer
Bosch Maxx lights on, hit Start as normal but nothing happens. After a while it goes back from Active to Ready flashing.
First question is does the display light up? If so then does the door lock? If the door is locking then the fuse for the washer that is on the back of the dryer hasn't blown. However if door won't lock, then check the fuse to see if it is open. This is a 208/240 volt washer and the display is the only part that doesn't need 208/240 volts. If fuse if find, then check the water screens in the fill hoses and clean them. This may be more of a control unit issue having failed, Hard to tell without knowing age of unit. Hope this helps
Jan 28, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Bosch Axxis WFL 2060 Front Load Washer Logo
352 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
