Isuzu trooper gearbox problems
You need to be a bit more specific when describing your problem. By "not getting any gears" do you mean (A) the shift lever will not move into position to select a gear?, or (B) shifts into gear position, but does not move? For (A), try reverse (it is not synchronized); Do you get a grinding of gears sound when you try to engage it? If so, this sounds like a problem with the hydraulic clutch release system. If it gets low on fluid, it will not release enough to let you put it in gear. top off the reservoir(tiny 1/2 cup sized one on driver side fender under hood below and to the right of the brake master cylinder) and frantically pump the clutch pedal about 100 times (that\'s right, 100!)
If the tranny goes into gear but the vehicle won\'t move, this sounds like either the clutch disc is worn too thin to grab, or something is broken in the driveline. Try locking the hubs and putting it into 4WD and see if it moves then. If so, then the rear wheel driveline or driveshaft has a problem. Good luck!
<Splinter, LA, CA 1990 Trooper >352,000 miles>
