Question about Astoria Argenta AEP-4 Coffee Maker, Espresso Machine
Need wire diagram for older 3 lever Astoria. Someone hooked up a 3 wire cord for 120v. and the way they hooked up the elements makes no sense or heat. I can't find a model # anywhere butit is older
  • mikl7273 Apr 25, 2009
    Thanks for the reply. There are two wires going to the elements. One to the top and one to the bottom. That leaves an element post on the top and bottom that is not connected to anything. Can this work on 120V ? For sure not the way it is wired up.
  • Ernest R
    Ernest R May 11, 2010
    Question; how many wires are on the element?
    Sometimes they have a small bridge wire connecting the top and bottom elements depending on the model you have.
    The other cord the is the 120v actually connects to the external pump and motor that came with your machine, you can also use the wiring diagram from the SME model its virtually the same thing.
    President:
  • 1,618 Answers
No the machine is made for 220v. If you check the element closely there will be some markings on it with the voltage.
The other two terminals need to be connected to each other(check diagram below)
The two wires one at the top and the other at the bottom are each connected to one leg of the element, there should be a some kind of bridge connected to the other bolts on element.
Hopefully you can make out this drawing:
T-1 T-2
I
U-1 U-2
Use a 10 gauge copper wire or a bridge terminal and connect T2 and U2.
T is one leg of power for the element and U is the other Leg. If you open the cover on the pressure stat (rectangular box with 4 wires going to it), you will see the wires, two from switch and two to element.
Make sure there is water in the boiler and test machine (connect to power).
Posted on Apr 27, 2009
  • Ernest R
    Ernest R Apr 27, 2009
    Here is a better image
Need diagram for wires that hook up to heating element on fridgeidaire model LAQE 7011KWO Dryer
Hello. There are black and yellow wires that connect to the heating element. The black comes from the inlet thermal limiter fuse, the yellow comes from the main drive motor. There is always 120 volts at the element. When the dryer is initiated, the motor, using a centrifugal switch, connects another 120v supply across the other side of the element which totals 240 volts and causes the element to heat. This is done intentionally as a safety feature--the element can't heat if the motor isn't running.
Aug 18, 2015 | Frigidaire Dryers
220 stove has nothing hooked up to the neutral
TURN OFF POWER TO THE STOVE OR UNPLUG IT IMMEDIATELY BEFORE TOUCHING **ANYTHING**. I need the make/model of your unit to help you accurately. HOWEVER, the first thing you need to do is(and this applies if I'm interpreting you correctly)replace the power cord--it will be connected to the terminal block--on the vast majority of ovens, you have a left-hand terminal, generally known as L1(a power wire), a center terminal(*normally* the neutral connection), and then the right-hand terminal, generally known as L2(2nd hot supply wire). Take a picture of the AC outlet so you can purchase the correct power cable for your stove. Also, take a picture of the terminal block in the rear of the stove just to make sure. I'm assuming that the wires are all connected in the stove but the neutral wire is either broken or missing from the power cord. Due to how most ovens operate, THIS IS A VERY DANGEROUS CONDITION. When the unit is plugged in, even though the oven is off, there is still 120v applied to the heating elements. When you turn on the oven, instead of being connected to a ground, the other side of the heating elements are simply connected to 120v from the other side of the panel, adding up to 240v and the elements heat up. I hope this helps you!
Aug 13, 2015 | Kitchen Ranges
Kenmore 80 series electric dryer by pass thermostat
Yes,but you really need a great grasp of the danger of doing so!
If you are not terrific with electricity, here is an easier way to test the heating element safely.
Unplug the two wires that go to the heating element (with the machine unplugged of course).
Go and get a good a 9-volt battery like goes in a smoke alarm, a short piece of wire, (like doorbell wire or a piece of an old electric cord a couple of inches long will do) and a car tail light bulb.
The older bulbs work great.
You want to make a circle.
You want to touch the battery to one contact of the heating element. You want to touch the wire to the other contact of the heating element, and you want to touch the other end of the wire to the side of the bulb.
Then touch the bulb tip to the other contact on the 9-volt battery.
It should light if the heating element is good.
I hope this makes sense!
Be blessed.
Mar 06, 2013 | Dryers
Intermatic T103P Timer (120V) Wiring Guidance
Copy following link for T103 timer wiring options:
The clock motor is 120Volts, but clock motor can be changed from WH1570 to WG1573, and this action changes 120V T103 into 208-277V T104 timer:
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T103
Jun 08, 2012 | Intermatic Hardware & Accessories
I need a wireing diagram for two elament electric water heater. Mine runs on 220 volt, my question is what about the common or white wire where do i hook it to or do I not need it when running a 220 circut
Links below show specific wiring diagrams and explain 240V with two hot wires vrs 120V with hot and neutral wires.
Then if you have more questions, add a comment and I will fill in blanks:
http://waterheatertimer.org/How-to-wire-water-heater-thermostats.html
First diagram will be for your water heater.
http://waterheatertimer.org/B220C.html
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you via e-mail while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 17, 2011 | Reliance & 40 Gal Electric Mobile Home...
Is it possible to turn my Bosch oven in to 110 volt? Model number HBN58T650A Thanks
I did a search for this Bosch oven-
It sounds like the oven is not a conventional Resistance heating oven-
So it might be possible--
Do you have the manual for it?
I tried this web site: visit the website: www.bsh-group.com.
But It was not much help
Perhaps you can look in the phone book, and contact your local BOSCH appliance dealer, and have them look up the model in their Model catalogs?
Or-- You could pull the oven out, and check the wiring harness--
No doubt it will tell where the main cord comes in, -- if there is a hook up diagram for both 110 Volt,and 220 VAC connection diagrams-
When you get it out, tell us what you find-- maybe we can help further..
MackB
Jan 29, 2011 | Ovens
How do i hook up the electrical cord properly?
May 08, 2010 | Whirlpool WGD5300S Dryer
How to switch 3 prong cord to a 4 cord prong.
remove cover plate and observe your old cord has 3 wires the the 2 outside one are the power/voltage 120v each one and the center is neutral...........you 4 cord has 1-black 1-red 1-white 1-green put the black and the red to the outside connections on the block white goes to the center and the green just attachs to the metal casing on the dryer if you are not completely sure get someone who is because if wrong it could cause a fire or burn something in dryer as always in all my advice if you are not sure get or pay someone who is...............fixrguy
Aug 21, 2009 | Maytag Dryers
I need help hooking up my Maytag Dryer
here's a link you can try that explains both the 3 and 4 prong dryer cord configurations.
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
If this is an older home that already has a 3-prong receptacle installed, you can still use a 3-prong cord. However, if this a newer home, or if you plan on relocating the appliance, or making any repairs to the existing receptacle, you need to use the 4-prong. I hope this helps you.
If you weren't talking about the dryer cord configuration and need assistance with something else, please let me know.
Jan 09, 2009 | Dryers
Astoria Argenta AEP-4 Coffee Maker, Espresso Machine Logo
356 people viewed this question
Top Astoria Coffee Makers & Espresso Machines Experts
Charles T Nevin
Charles T Nevin
J.D. Browning
J.D. Browning
NOEL
NOEL
Are you an Astoria Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
