Dell Dimension 2350 Won't Boot
Have helped with a friend's Dell Dimension 2350 before. When it is unplugged & moved, it won't power up. In the past, unplugging it until the motherboard light completely stops blinking has worked. This time their grandson visited & downloaded some games, so it was veeerrry slow. Our schedules are opposite, so I had them drop it off at my place again. Won't power up at all, even with the power cord trick. Have also tried unplugging it and: 1) Holding the power button in for a minute or longer 2) Crossing the prongs on the wall end of the power cord, +/-, then each power to ground separately, to discharge caps, etc. 3) Plugging it directly into the wall (Dell web site said that too many items on a power strip may interfere) The light blinks so it's getting some power, but where do I go next? A new power supply? The power button itself (current power supply does not have a separate power switch)? Motherboard problem(s)? Thanks!
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 166 Answers
I would try another power supply first. Use one that has the same or greater output watts. I keep several old ones around for this purpose. If that does not solve it then you may have a failed motherboard. Failure of motherboards is usually due to breaking capacitors. A few years ago a capacitor company stole the "recipe" for making capacitors from another company and tried to make their own, unfortunately they did not get the ingredients right and the capacitors started breaking after 2-3 years of use. They sold these capacitors at very cheap prices and a lot of computer companies and power supply makers bought them. This is easy to diagnose. Look for capacitors (caps) (they look like little tiny soda cans) on your motherboard (mobo). They should be perfectly flat on top and not bulged or swelling or leaking anything. Be sure to look under the fan shroud also. The dead giveaway will be the fact that you are not getting anything after you change the PSU. There are a few companies that will repair broken capacitor issues. Also if you add a bunch of extra components without upgrading the power supply you can suffer underpowered situations and that can cause internal parts to fail.
To eliminate some other stuff you could remove the memory and disconnect all the power plugs from the drives and then try to start it up. If it does not change the behavior at all (no beeps, no change in flashing lights) then you probably have motherboard issues. Make sure when disconnecting the memory chips (sticks) that you touch the metal on the inside of the case first to discharge static electricity. If it does change the behavior add 1 component or item back at a time to see what you can find out. Post back with what you find. And remember a bad PSU does not always mean no power, just not enough to run the computer.
Posted on Apr 30, 2009
Hard drive boot failure
what is the error message? If operating system could not find, try you original windows installation CD, during you boot from the CD there is a repair option, follow the wizard to complete.
Sep 03, 2012 | Dell Dimension 2400 PC Desktop
Dell dimension 5150 wont boot past post. I've tried afew things but nothing works. can you help? thanks
If it won't go past POST then there is a hardware error. Try removing the hard drive and RAM. The mother board should complain at power on giving messages. If it does, try fitting the RAM module by module, then the hard drive.
Apr 17, 2011 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell Dimension 2350. After I shut it down and try
Check that the computer is not hibernating rather than shutting down. It will be in the power settings.
Mar 06, 2010 | Dell Dimension 4600 PC Desktop
Dell Dimension 2350 reboots every 3 secs
Could be a couple of things.
Disconnect the C drive and see if the computer will stay turned on. If it does (you'll get an operating system not found error), then reconnect the c drive and see if you can get into the BIOS. If not, you'll need to replace the hard drive.
Could also be a faulty power supply. As soon as it tries to boot off the hard drive, it puts too much strain on the PS and causes a reboot.
Finally, if neither of those fix the issue, then the problem is motherboard and at that point it is more cost effective to replace the computer unless you can find a cheap, used motherboard. Good luck!
Jul 05, 2009 | Dell Computers & Internet
Dell 2350 Won't boot up without cd
Check the jumper on the back of your drive. Chances are that the jumper is either on "slave" or "cable select". Change the jumper to master, and try rebooting.
Mar 11, 2009 | Dell Dimension 2350 PC Desktop
My Dell Dimension 2350 no longer powers on. Yesterday it powered on ok and powered off ok. My guess is the power supply is bad. Checked the power cord (with a voltage meter) and 117 VAC is at the end...
Dell has this great tool where you can troubleshoot an issue in a methodical way, step-by-step.
Here is the link to troubleshoot No Power, No POST, No Video [Dell Dimension 2350 Desktops] Just follow the steps and choose the option and continue. Remember not to skip any step since each of them has a purpose.
http://support.dell.com/support/topics/global.aspx/support/dsn/en/tree?c=us&l=en&s=gen&journalid=6445B6E320AC44A4E040AE0AB8E12519&treeid=4F62A0ECE60449EE8150A94E91B6BD27&Query=bm8rcG93ZXI=&SystemID=DIM_PNT_CEL_2350&ServiceTag=&contenttype=-1&os=-1&component=-1&lang=-1&doclang=en&toggle=true&dl=
Below is also a link to the Dimension 2350’s user manual.
http://support.dell.com/support/edocs/systems/dim2350/
Hope this helps. Please rate your feedback!
Thanks,
VJ
Mar 04, 2009 | Dell Dimension 2350 PC Desktop
No sound on my dell dimension 2350 pc desktop
Go to this Dell link and download the Audio driver:
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=DIM_PNT_CEL_2350&os=WW1&osl=en&catid=&impid=
You may have to copy and paste the link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 02, 2008 | Dell Dimension 2350 PC Desktop
Dell Dimension 2350 - Computer Crashing
try boot in safe mode and restore to an earlier date when your pc was working nicely
May 08, 2008 | Dell Dimension 2350 PC Desktop
Computers & Internet Logo
808 people viewed this question
David Payne
David Payne
