No monitor on screen but when plugged in external monitor it works but sometimes getting automatic standby mode
My n620c loptop does not have monitor but when i plugged in a external monitor its working but sometimes its turning on automatic standby mode. can you help me out of this? thanks a lot!
  • 374 Answers
take that oppurtunity when your on safe mode,goto system restore and have your system back when it was on normal operation,try it other than reinstalling your system,i think this is not a hardware problem from your monitor,doing this in all program,go to accessories,then system tools,then go to system restore click it and have select a previuos date that your computer work normal say" on april 1,then click it have it process just keep patience there a couple time to process this until the computer will tell you it was finished,just follow some instruction,maybe some file are missing on your vide card to hook up the monitor.have a nice day
Posted on Apr 22, 2009
Laptop broken screen... plugged in Dell monitor,still doesnt work
You can switch to an external monitor or data projector by two methods. 1. Connect the external monitor to the laptop's video port, power up the external monitor first and the laptop. The video information will automatically switch to the external monitor. 2. If you power up the laptop first then you can switch the video output to the external monitor by pressing the Fn key and one of the Function keys, depending upon your make and model laptop. You can also toggle between the external monitor or both LCD screen plus the external monitor or back to LCD screen only by pressing the Fn key plus one of the function key. Here is a list of key combinations for some of the laptops :- IBM ThinkPad = Fn + F7 HP and Compaq = Fn + F4 Toshiba = Fn + F5 Dell = Fn + F8
Sep 03, 2012 | Computers & Internet
Windows won't start at bootup. Instead the fan turns on.
It sounds like your operating system has failed. Your best bet would be to use a working computer to burn a new install disc / backup disc / repair disc and then reinstall your operating system, or if possible repair it.
Have you tried plugging the VGA output into an external monitor and turning it on? Maybe your screen has just failed, if it does output to an external monitor.
You can get it into external mode if you boot it up with an external monitor connected, a USB mouse connected, and a USB keyboard. Boot up the machine (plugged in!) and close the lid right away, and it should automatically kick over. If not, try windows key and P at the same time, once the machine is "running"
Aug 14, 2011 | HP Compaq 2530p (KS094UA) PC Notebook
Screen goes into standby mode after a few seconds. Screen will not stay on. Started after the computer was on and coming out of standby mode. Computer works fine on external monitor.
Depending on the options you purchased the laptop with, it either has an integrated video circuit into the motherboard or a plug-in video card to the motherboard. If the laptop works fine with external monitor, your motherboard or video card is defective. Your LCD display is probably O.K.
Jan 04, 2011 | Dell Inspiron 710m Notebook
THE SCREEN IS DARK. tHE LOPTOP TURNS ON BUT HAS NO DISPLAY. IT WILL NOT WORK ON EXTERNAL DISPLAY.
Your video card is bad. A bad LCD or backlight lamp would not prevent an external monitor from working. Even without a hard drive or Windows installed you would still get a text display on your screen. Some laptops have replaceable video cards but some are soldered to the motherboard and can't be replaced. This is a job for a repair shop, not a DIY project.
Sep 17, 2009 | Gateway Computers & Internet
My Compaq N620c powers up but only shows only a black screen
may be faulty processor, loose memory stick or a faulty power supply.
Jul 13, 2009 | Compaq Evo N620c Notebook
No monitor n620c loptop
To switch between monitor modes (internal/external) you have to press the key combination Fn+F4 (or F8) or the F key with a dual monitor icon printed on it. This happens when you use the laptop with an external monitor or projector, and you forget to return to the internal monitor mode.
Apr 22, 2009 | Compaq Evo N620c Notebook
ACER cracked screen..external monitor???
Hi there.
The keyboard toggle you are using is the correct one.
Sometimes you have to hit Fn + F5 a couple of times to stay on there is no real set time. Make sure Fn + F6 is on so the laptop screen stays on.
Good luck and thanks for using FixYa!!
Apr 21, 2009 | Acer Aspire 5500 5570-2609 Laptop
Powering
This is usually a sign of bad ram. remove the ram cover underneath, pull aside the pop out clips and remove the ram. hold the ram by its side and try not to touch the 'gold fingers'. Clean it / them with a soft clean paint brush along with their holders and re-insert. If this does not work and you have 2 sticks of ram then try each one on its own in one slot,then the other slot, turning on each time to identify the faulty module.
If this is no joy I would suspect the CPU. It could also be the motherboard video chip which is not repairable without a new motherboard but this is doubtful as it is not a common fault on this laptop.
Hope this helps some.
sparkyuiop.
Nov 21, 2008 | Compaq Evo N620c Notebook
Using IBM T34 with docking station and external monitor
hi all u need is to adjust the power management settings in the control panel, let me know
Jan 02, 2008 | IBM ThinkPad T43 Notebook
Computers & Internet Logo
47 people viewed this question
David Payne
David Payne
