Question about 2wire Computers & Internet
Problem getting to internet through 2wire 2701hg-b router
I am unable to get to internet using my dell pc desktop. worked with dsl support (att internet) and even purchased connectech support. no one able to get me connected. modem works fine, can access their system support, able to ping it, unable to ping web addresses. tried setting up router on my laptop. everything works, fine, even wireless, but cannot get my desktop to see the internet. last tech worked with me on safemode, disabling mcafee entirely, nothing works.
How can I connect a 2wire 2701HG-B router to a motorola SB5101modem?
Posted on Sep 09, 2009
3 Suggested Answers
SOURCE:
  • 82 Answers
SOURCE: 2wire 2701HG-B gateway can't connect locally
Have you got MS CLient loaded in the network settings. If not run network wizward on each machine and then try again. hope this helps Mark
Posted on Aug 18, 2009
Ezrahite
  • 2632 Answers
SOURCE: i need to find my att dsl internet security key to
Hi rob,
The Internet Security Key that you're referring to is the Wireless Network Key or Wep Key. The Default Wep Key is the 10 digit key located on the bottom Sticker of the router. It is near the Bar Code. You can also personalize the Network Key by simply accessing the router. I've listed the steps on how to access the router in case the Network Key on the sticker is not working.
  • Open a Web browser and type http://gateway.2wire.net or http://192.168.1.254; the 2Wire Home page opens.
  • Click the Home Networking tab at the top of the 2Wire Home page.
  • Click on Wireless Settings. then click EDIT SETTINGS located on the right panel.
  • Here you will be able to fine the setting for your wireless connection
  • You can change the SSID, Wireless Channel, Wireless Security, and Network Key
Rate me if this helps so I can help others. Thanks for using Fixya.
Posted on Feb 05, 2011
I have an at&t 2wire 2701hg-b but i dont have at&t internet i have charter and i am not able to figure out how to get my internet to work with this router please help
att 2 wire is a Adsl Modem (Requires a telephone line jack to get the signals) but charter communication is a cable internet service (not DSL) , Requires a TV cable service for internet .
These two jacks differs and there working differs ..
Means : Att works with the username and password type of authentication but charter requires the MAC address of modem for authentication .
Therefore for a cable internet 2wire 2701hg-b modem cant be used . But yes in case charters has username and password authentication and works with the telephone jack in house then its possible to use the same modem.
Aug 19, 2011 | 2wire (2701HG-B) Wireless Router
I want use my 2wire (2701HG-B) Wireless Router without the dsl line
Modem and routers are considered only as access point you computer may be able to connect to your router but if you dont have a DSL line you will not be able to go on line... if you dont want a DSL line there are service that concentrates on wireless alone... in this DSL line are not required nor router but may provide you a USB wireless adapter that has their wireless service then again try calling an Internet Service provider for this options...
thanks... Roger
Jun 11, 2011 | 2wire (2701HG-B) Wireless Router
What steps do I take to configure my 2wire 2701 hg-b to connect directly by ethernet cable to my Directv HD DVR and pick up the dsl signal being transmitted by my primary westell router? Both are wireless...
Connect the cable at both ends and do a red button (inside card door) reset of the DVR. To test the connection, do thus: Menu -> .....setup -> system setup -> network setup -> test connection. If it shows not connected then "reset defaults" and run "connect now"
As a basic security feature the ATT DSL 2Wire 2701HG-B router/gateway requires you to enter its pre-assigned WEP key to connect beyond the unit itself and then to the internet. Since the Direct TV DVR HD24D only does a basic connection without having a place to enter the 2701HG-B WEP key it never actually reaches the internet.
The 2Wire 2701HG-B has the ability for one attached unit to "pass through" its firewall and internal security settings using a so called "DMZplus" mode. I set the HR24D DVR to such a mode within the 2Wire unit and the DVR connected with the internet flawlessly.
Dec 30, 2010 | 2wire (2701HG-B) Wireless Router
I have recently configured a 2wire 2701HG-B router connecting my home LAN to the internet (ATT-DSL). One of my machines is a linux box running SUSE 11.0 . Two other machines run microsoft XP. Although...
I use ATT as well, but I am running ubuntu. for some reason in order to connect to the internet I have to restart networking after boot. I just use networking helper scripts, otherwise, for some reason it does not key-in WPA through the manual config properly.
Aug 14, 2010 | 2wire 2700HG-B Router (2700HGB)
I have a 2wire 2701hg-b router....I can connect to the internt through wifi on my laptop but when I try to connect through ethernet on my desktop it says it accuirring signal. I tried to reinstall the...
First look in device manager and verify that the network adapter is enabled, if so you can try disabling it then shut down and reboot the PC.
Once booted, go back into device manager and enable the network adapter.
Run the software that came with your router and follow the steps provided.
Make sure your network cable from your router is NOT connected untill instructed to do so.
You will need to have the network cable from your modem connected to your PC for the router software to detect network connection.
Good luck, I hope this helps.
Have a nice day.
Jun 01, 2010 | Computers & Internet
Cannot login to paypal and banks
Possible the power adapter is bad, know problem - check ebay.
Aug 15, 2009 | 2wire 2700HG-B Router (2700HGB)
Can I use AT&T 2WIRE 2701HG-B DSL to ant ISP?
look if u wish to go for verizon service,,they will provide u with a wireless modem as well,,but if u tell them that u hav a modem then they might configure this modem only,,both ATT and verizon are DSL service providers with PPPoE connections.the only thing u need is the username and passwrd from verizon which u have to setup on the first page of the 2wire setup page,,both the connections are dhcp based.so no other connection settings change required.But when u talk with verizon make sure u tell them of the 2wire modem
Moreover verizon has wireless broadband service which is actually a express card tat u have to put into your computer and u can go online anywhere u go within ur country{it works like a mobile phone}
best of luck,,keep me posted
May 14, 2009 | 2wire Wireless-G 802.11g ADSL Gateway
Att2wire 2701hg-b to replace peoplepc dsl Zyxelp-600 series modem
do you also have AT&T? att2wire 2701hg-b gateway is configured to work with AT&T only that's why if you have a different ISP, it will not work for you. Most ISPs provide modems that are configured solely for their service.
Apr 26, 2009 | 2wire 2700HG-B Router (2700HGB)
2wire 2701HG-B: how do I extend it's range?
I purchased Netgear's Wall-Plugged wireless bridge (WGX102 ). Worked very nicely.
Apr 04, 2009 | 2wire 2700HG-B Router (2700HGB)
Computers & Internet Logo
493 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Ron Stone
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
