Most likely your hard drive is gone bad. Push "menu+find" buttons then turn on, you will get diagnostic screen, it will show if your cornice drive is bad. It will say"Cornice Dive removed"
Yes. There is one more mapset and then there will be no more for us using the StreetPilot 2620. You are looking for the disc set North American Navigator 2009. Make sure you do not purchase the NT version. I found the item on EBAY for $81and purchased it and it worked just fine. The 2009 is the last compatible map set that Garmin released for the 2620. Be certain that what you purchase includes that unlock key otherwise you will spend another $75 on that at the Garmin Unlock Site.
Here is the link that is good for a few more days, however, may relist it. The seller is yumelectronics and the search term is 2009 City Navigator.
You are caught in a loop most likely caused by a failed microdrive. Search Garmin 2620 cornice for a thread that is likely to provide the information about the failure you are experiencing. In short, if it is the Cornice drive that has failed you will find it very difficult to repair, if not impossible depending on your level of expertise and ability to find a used part for repair as the drives needed are no longer manufactured or readily available.
Do you have any unlock code for your unit? Delete this code "demo" from MapSource and put unlock code for your unit and try to download to unit a small part of maps.
I have a same problem, and I think I can fix it, may be not. Any how, I bought a cornice drive on eBay and as soon I will get it. I will load
my maps on to it with usb connector after that I take it a part and
remove it from its case. Then I will take my Garmin Streetpilot 2620
apart remove the old cornice drive and install the new drive. I suspect
it will work like a charm. To check your GPS at boot push and hold "menu-find" buttons simultaneously and you will get a screen to verify your problematic cornice drive.
There is no reset button. Every time you turn off your Garmin and turn it back on it reloads everything fresh. What is likely the cause of what you are experiencing is a failed Cornice microdrive. It is near impossible to fix with the parts available today (May 2010) and it is more time management and cost effective simply to purchase a working 2610 from a third party site, or to purchase a new unit from the store that is still supported. In addition to the parts issue Garmin discontinued Map support for the 2620 (and 2610) in 2009.
I would like to know the same thing! My father has the same unit and he updated his with version 4.80 & web updater (both free) on garmin and it solved his problem. I believe my problem is that my North America v8 did not install properly. ????? well see
In February I posted that I will replace the cornice drive on my 2620 because I had this problem Well I did that, but could not fix the problem. Garmin is asking $275 to replace my unit, I did not wanted to pay them that much. So I bought a 2610 at eBay for a $100 and don't have to worry about hard drives any longer. To get this screen on a GPS push "menu+find" and then turn on unit. It will show this diagnostic screen.
