Question about Kenmore 63942 Dryer
Fabric looking belt came out of dryer. when i try to dry clothes it makes a loud noise and smells like something is burning and my clothes get twisted. how do i fix it? I have a kenmore 70 series dryer
  • 5,911 Answers
Stop using your dryer in its current condition. That fabric looking felt is probably your drum seal. They commonly wear out. I will need your dryer model number in order to confirm how your dryer is configured and give you accurate advice on part numbers and directions on how to replace. The model number should be listed on a name plate around the door opening.
Posted on Apr 22, 2009
GE DPXH46GA6CC gas dryer makes large humming noise in heat cycles and burning smell
Two things are likely going on here,1- something is dragging down your motor check for a twist in the belt, idler pulley bad, belt installed wrong or wrong belt. Also check your front drum felt and glides if the felt is bunched up that will drag down the motor. Now the smell you probably have some felt or lint in the burner clean it carefully you do not want to damage your igniter.
Aug 04, 2013 | GE Dryers
Frigedaire dryer front loader makes clunking noise
Hi kirst_alers2 - From what you have described it sounds like you either have a problem with the belt, front (and/or rear) bearing, or a loose connection with the motor or drum. Lint or something else clogging the vent could be causing the dryer to take a longer time to dry the clothing. If the dryer is taking too long to dry then the issue may lie with a faulty sensor. I recommend contacting a professional to accurately diagnose the issue, the part(s) may have to be replaced depending if they are worn, damaged or loose. You can often locate a qualified tech through the manufacturer website.
Apr 08, 2013 | Frigidaire Electric Dryer
Kenmore 80 series electric dryer. metalic sound/burning smell
When i put clothers in my dryer it does not move and it make a sound when i push the start buttom
Feb 24, 2010 | Kenmore Dryers
My maytag dryer is making a very loud noise near the area where the belts are, the belts seem to be working and the drum is turing, however after a while there is a burning smell.
Is the burning smell like plastic? If so read on. The belt runs on a spring steel plat tensioner with platic wheels of course. Plastic is on everything these days, huh? Well anyways the wheels the belt rides against has bushings inside them to make them last a long time which they do. It seems the plastic wheel will melt down in some spots and when rotating it makes the drum of the clothes dryer make a rumbling sound. I know you did not mention that problem although if the wheels keep on melting down the smell will subside but the noise will get loader as time goes on.
Jan 25, 2010 | Dryers
Burning Smell from Belt on Whirlpool Dryer
Hi, You need to check and see if the belt has slipped off of one of the pulleys. Was the idler the wheels style or a glide style?
Make sure the grooves in the belt are facing the drum and they are in the grooves of the motor pulley.
Please let me know if this helps and if I can assist you further.
Vic
Jun 01, 2009 | Whirlpool LER5636P Electric Dryer
The dryer smells as of something is burning and it is leaving a bad smell in the clothes
The dryer may be getting too hot. Check vent for obstruction from unit to outside.
May 25, 2009 | Maytag Dryers
Screeching noise and burn smell how do I open dryer to repair
Pull it out from the wall, unplug it and remove the back panel by removing the screws. The problem is most likely the belt around the drum which is either worn out or out of alignment. Take a look at it and decide if you can just straighten it on the drum or if you will need to buy a new belt.
May 01, 2009 | Dryers
Kenmore Ultra Care Fabric Series 80 dryer works sometimes
This sounds like the motor is bad. Hope you didn't pay too much for it. ;-)
Apr 01, 2009 | Kenmore 659 Electric Dryer
Dryer is making loud thumping noise.
Take off the back panel of the dryer and look at the motor and belt turning the drum. There may be something caught on the drum and is pinned in place causing the noise. The motor could be loose on the platform and needs to be tightened. It is probably something physical and seen causing the noise.
Jan 04, 2009 | Whirlpool LER4634J Electric Dryer
Kenmore 63942 Dryer Logo
171 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
