I can't figure out how to switch from envelope A to B etc. I hold downthe display menu but can't get an option. Thanks!!
How do I switch from one envelope to another, A to B etc.? (On theICDP620 recorder) Mike
  • go-osu Apr 22, 2009
    Yes Folders A B C D etc. THX
  • OnlyOneN
    OnlyOneN May 11, 2010
    Are you referring to the "folders" where your recordings are stored?
    Sniper:
  • 86 Answers
Thanks for the clarification. To change the folders:
Press DISPLAY/MENU for more than 1 second until “MODE” appears in the display window.
Press –<< or >>+ to select “FOLDER” and press PLAY/ ENTER.
Press –<< or >>+ to select the folder you want and press PLAY/ENTER.
Press (stop) to exit the menu mode.
Here is the link to the manual for your recorder. Please turn to page 17 for more detailed instructions.
http://www.docs.sony.com/release/ICDP620.pdf
I'd appreciate if you indicated that I solved your problem. If there's more information you need, please ask!
Posted on Apr 22, 2009
Hi this has a blank white screen, clicker sounds, but no menu etc. Did sync (displayed do not disconnect etc), but now gone to all white again! Thanks
Welcome to Fixya
Looks like the software just hanged-up on you. Try to reset the Ipod by following the procedures below.
1st option:
Turn the Hold switch on, then back to off.
Press and hold the Menu and Select buttons for 10 seconds (until the Apple logo appears).
You may need to repeat the reset several times.
If the reset doesn't help, then put the iPod into forced disk mode.
2nd option (Disk Mode):
Plug the iPod into a high-powered USB port, let it sit for 2 hours, then disconnect it. If you have a wall charger, plug in the iPod, then follow these steps while it is still plugged in.
Press and hold the Menu and Select buttons until the Apple logo appears
Immediately switch your figures to press and hold the Select and the Play/Pause buttons until "Disk Mode" appears at the top.
For a lot of people, this solves the problem. Connect the iPod to the computer and (assuming it shows up) reset the iPod again to get it out of Disk Mode. If at this point you still have the white screen, restore the iPod using the restore function in iTunes under the Summary tab (this will erase everything on the iPod and put it at factory settings).
Note: Do not disconnect or eject the iPod until the store is totally done. After you think it's done, wait another five minutes.
Thanks
Feb 24, 2011 | Apple iPod nano
How does one print envelopes on the xerox pro 232?
descicon.gif function showThisURL(){ $('.urldisplay').show(); } function hideThisURL(){ $('.urldisplay').hide(); } email-icon.gif print-icon.gif btn_remove_x.gif Return to Search Results Solutions for : How To Print on Envelopes in the Bypass Tray or Optional Envelope Tray Solution : Print on Envelopes in the Bypass Tray or Optional Envelope Tray This solution assumes that Number 10 envelopes are being used and printed on using Microsoft Word 2003 or 2007. Steps may vary if other applications are used.
NOTE: If necessary, make sure the envelopes are loaded correctly in the Bypass or Optional Envelope Tray. See the Related Items below for additional information.
From the computer using Word 2003:
  1. Open the application, and then select [Print] from the File menu. The Print window will be displayed.
  2. Select the required printer, and then click on [Close].
  3. Select [Envelopes and Labels] from the Tools menu. The Envelopes and Labels window will be displayed.
    NOTE: For Office 2003, click on [Tools], then [Letters and Mailings], and then select [Envelopes and Labels].
  4. Click on the [Envelope] tab.
  5. Enter the address and other information in the fields provided, and then click on [Options].
  6. Select [Size 10 (4 X 9.5)] from the Envelope size pull-down menu.
  7. Click on the [Printing Options] tab.
  8. Click on the second icon from the right under the For Feed Method section.
  9. Click on [Face-up].
  10. Select [Default Tray (automatically select)] from the Feed from pull-down menu.
    NOTE: If the Envelope Tray is being used, select [Tray 2].
  11. Click [OK].
  12. Click on [Print] to begin printing.
From the computer using Word 2007:
  3. Click on [Mailings] tab.
  4. Click on the [Envelopes] icon.
  5. Click on the [Envelopes] tab.
  6. Enter the address in the Delivery Address field.
  7. If necessary, enter the return address in the Return Address field.
  8. Click on the [Options] button.
  9. Click the [Envelope Options] tab.
  10. Select [Size 10] from the Envelope Size pull-down menu.
  11. Click the [Printing Options] tab.
  12. Click on the fifth icon from the left from the Feed Method section.
  13. Click on the [Face Up] radio button.
  14. Select [Bypass (Tray 5)] from the Feed From pull-down menu.
  15. Click [OK] twice.
Nov 23, 2010 | Xerox Office Equipment & Supplies
How do i print addres on envelopes on mx310
Yes through MS Word.
Go to the file menu select page setup select the paper tab and then from the drop down menu select paper size and select envelope. If you have multiple options for envelope like envelope9, envelope10, envelope11 etc. select the envelop size that you want. The paper size of the document will change to the specified envelope size and then you can print the document normally using any printer.
Jun 22, 2010 | Canon PIXMA MX310 All-In-One Printer
Can't print DL envelopes on a Pixma iP4600
Hi ...
If you like to print DL envolopes, check the below 3 points and I am sure you will be able to print from your printer.
Prepare the printer:
  1. Open the Rear Tray and pull out the Paper Support. Put your finger in the rounded indent of the Paper Support and pull it out until it stops. (See <1> in Figure 1 below.)
  2. Open the Paper Output Tray. Put your finger in the rounded indent beside the Paper Output Tray and open it gently. (See <2> in Figure 1 below.)
  3. Open the Output Tray Extension. Open up and set the Output Tray Extension completely by pressing down the hollow on its front side. (See <3> in Figure 1 below.)
  4. Adjust the position of the Paper Thickness Lever. Set it to the right when printing on envelopes or T-shirt transfers, and left when printing on any other type of paper. (See <4> in Figure 1 below.)
    * Figure 1
  5. Load the envelope.
    1. Load the envelope against the right side of the Rear Tray. (See <1> in Figure 3 below.)
    2. Load the envelope with the address side facing UP and the rear flaps DOWN on the left. (See Figure 2 below or, <b> in Figure 3 below.)
      * Figure 2
    3. Pinch the Paper Guide and slide it against the left side of the envelope. (See <2> in Figure 3 below.)
      * Figure 3
      Note: Reset the Paper Thickness Lever to the left when you finish printing. (See <3> in Figure 3 below.)
Preparing Envelopes to Load:
  1. Press down firmly on the edges of the envelopes to make the folds crisp. Also, press firmly on the area that corresponds to the edges of the back flap.
  2. Remove any curling by holding the edges diagonally and bending them gently.
  3. If the edges of the envelope are inflated or are curling, place the envelope on a flat surface. With a pen, press down while moving it from the center toward the edges of the envelope.
  4. Ensure that no curl or puff exceeds 1/8 in. (3 mm).
Paper Type
Precaution
Envelope*
DL / #10
Set paper with the flap closed.
Unsuitable Envelopes:
  • Envelopes with an embossed or treated surface
  • Envelopes with a double flap or pressure seals
Printer Driver Settings:
  1. Select Envelope in Media Type.
  2. Select the size for envelopes.
    * In Windows, select DL Env. or Comm. Env. #10 in Page Size.
    * In Macintosh, select DL Envelope or #10 Envelope in Paper Size.
  3. Select Landscape in Orientation.
Note:
  • Be sure to set the printer driver setting properly. If you do not, the address will be printed in the wrong direction.
  • It may be required to change the paper size option to 'Envelope' in File Page Setup menu.
Don't forget to vote if this helps ... Cheers :)
Jul 27, 2009 | Canon PIXMA MX310 All-In-One Printer
How do I print addresses on #10 envelopes?
    1. Click Tools on the menu bar in Microsoft Word, and then do one of the following:
    2. Word 2000: Click Envelopes and Labels .
    • Word XP: Click Letters and Mailings , and then click Envelopes and Labels .
    1. Type the Delivery and Return address information.
    2. Click Options .
    1. On the Envelope Options tab, set the following options:
    2. Envelope size : set to match the loaded envelopes.
    • S. only: if you want to, select the Delivery point barcode to make it easier for mail sorting machinery to correctly route the envelope.
    • Return address: for Size 10 envelopes only, set the Return Address position to .8 inch in the From left section.
    • Click the Printing Options tab and verify that the following settings are selected:
      • Select the Feed Method option that shows the envelope on the far right side with the short edge first. For example, in the graphic below, the fourth image shows the envelope in the correct position.
      • Select Face down .
      • Examine the selected feed method image and verify that the envelope flap is on the left side of the envelope. If it is to the right, select or clear Clockwise rotation .
      • Click OK , and then click Print .
  • Jul 22, 2009 | HP Officejet 5610 All-In-One InkJet...
    Nokia 6233 mobile switch on but then hangup
    Dear
    When u connect to computer by data cable it shows three option, select data transfer option from it to transfer file like videos,music etc.
    while in this process phone will not displays menu option it shows data transfering
    if u want to display menu option u have to deattach usb data connection
    Thanks
    Feb 20, 2009 | Nokia 6233 Cellular Phone
    I can't figure out how to format address labels in Word 2007.
    You mean labels for like a mail-merge? (printing lots of addresses for envelopes etc?).
    1. Click the 5th menu from the left called Mailings.
    2. Then click the Labels Option
    Everything you need should be on the TAB under Mailings.
    Please let me know if that was what you were looking for?
    Thanks,
    Kaj
    Dec 17, 2008 | Computers & Internet
    Flashing message icon
    The blinking envelope icon appears to be a reminder that you have your old SMSs still stored on your SIM card, and N96 needs them to be transferred to the phone memory -ether internal, mass storage or memory card- to properly display and manage them. So what you need to do is go to your menu, open Messaging, hit Options, select 'Sim Messages' and then transfer your SMSs to the N96 memory. Then do the same again & delete the SIM messages that will cure the flashing icon.
    Nov 08, 2008 | Nokia N96 Smartphone
    New message display won't clear
    Alicyn,
    There is a way, but it will erase everything in your phone (PB, pix, mp3's, etc...). Might not be worth it.....
    But if that envelope is that annoying, then:
    Menu--Settings/Tools---Phone Settings--Security, enter the user code, Reset Default.
    Jun 08, 2008 | LG CHOCOLATE VX8500 Cellular Phone
    How do I override the paper size on a Canon imagerunner 2200?
    I have an image runner 2800 and I had the same problem. It drove me crazy I searched the entire menu. I finally figured it out. Pull out the paper tray which you want to change. There is a small dial on the right side with paper sizes on it. Select the right on and put the tray back. Your paper size should now have changed on the menu. You are welcome :-)
    Apr 29, 2008 | Canon (6981A002AA) for imagerunner 2200,...
    41 people viewed this question
     Grubhead
    Grubhead
