Question about SMC Barricade SMC7401BRA (SMC7401BRA-ADSL) Bridge/Router
I need to connect a real router with more ports to it 4-2 pcs
The barricade is workign fine for one pc but since it ahs only one port it doesnt route much. i have two different 4 port routers one with wireless and the other withought. id like to connect two computers a desktop and a laptop preferably with the wireless option. this means making either my netwave blitz base g4 wireless 4 port router model bwa611 or my lynksys network anywhere 4 port router model NRo41 connect throught the barricade model model smc 7401bra combination modem and single port router, now in use for a single computer. when i tried hooking them up mechanically and running the installation cds bothj failed to allow me to sue the connection though they both seemed to be capable of making a connection. my problem is i need to be able to control and use the connection, so i can gain access to the interent with both the desktop and laptop at the same time. my first choice is to have the wirelsss modem in the system, but if it wont wotk im ok with the linksys wired 4 port router. can anyone help me makie the connection.
    Brigadier General:
  • 10,406 Answers
Connect the LAN port on the Barricade to the WAN port on your wireless router. The Barricade should be "plug-and-play",
i.e., no need to configure it. Similarly, the WAN port on the wireless-router is plug-and-play, so it should automatically get an IP-address from the Barricade.
Use an Ethernet cable to connect the network-port on your computer to one of the LAN ports on the router.
Then, start Internet Explorer, and connect to the web-server "inside" the router. Run the "Wired Network Setup Wizard", and then the "Wireless Network Setup Wizard". When you're done, then your "wireless" device(s) (iPod Touch, laptop, XBox360) should be able to make a wireless connection.
Note: no need for any CDs to "install" anything.
Posted on Aug 23, 2010
With a data cable where do i connect the router to the pc which ports
There is only one way to connect a router to a pc and thankfully there is only one port also. The ethernet cable you have (looks like a over sized phone jack) will plug into the lan 1 port on the back of the router and then plug into the only spot it will plug into on your pc. Just look on the back for another over sized phone jack looking receptor and you should be up and running from there.
Good Luck.
May 10, 2011 | Buffalo Technology WHR-G54S Wireless...
Can I use a USB Modem (cricket) on the USB Port on SMC Barricade SMCBR14UP Router ? Thanks
No, this SMC router is designed for Broadband connection via RJ-45 connection thru WAN port.
The USB is there for USB printer as Printserver.
Jul 27, 2010 | SMC Barricade SMCBR14UP Router
Only one computer is able to get online out of the
If you are connecting the switch to a single port broadband modem/router then you will only get one ip address, therefore only one connection to the internet. If you buy a broadband router with multiple ports, with a builtin dhcp server that gives all other pcs on the network a private ip address, then all connected pcs will get access to the internet as it is routed over the single public ip address given by the isp (even if you use a switch as well!!).
Nov 10, 2009 | SMC EZ Switch SMCGS24 24x1000 Mbps
Using the SMC100 Barricade as a Wireless Access Point
use the wrt310n router as the router for the internet (where dsl modem is connected) then just connect the ethernet port (not wan port or internet port) of the SMC to the ethernet port of wrt310n
Oct 31, 2009 | SMC Barricade SMC7404WBRA (SMC7404WBRA EU)...
Configuring D-Link DI-524 router with airtel beetel 110bx1
Make sure you can go online directly to the airtel broadband. If internet works fine, connect the D-Link router to the Beetle. That should be going to the Internet port or WAN port of the D-link. Then your PC to port 1. Try to power cycle both devices now. Unplug the power to the router first then to the modem. Wait for 30 seconds. Power on modem first, wait for the lights to go solid, then power on the router. Check if the internet works fine hardwired. If it is, wireless should work as well. Just connect to the signal coming from the D-link.
Oct 31, 2008 | D-Link DI-524/DWL-G630 (di524dwlg630kit)...
Internet Intermittent Drop Out
To isolate the problem beter connect your wireless router directly to the modem and configure it, check if you are able to go online properly so that you can figure out the problem if your wireless router is not working properly, try upgrading the latest firmware and reset the router and reconfigure the router and that will fix your problem...
Oct 22, 2008 | Linksys Wireless-G WRT54G Router
Using both USB and Ethernet to connect to the internet
Does your router suports usb ports, normally routers do not support usb ports, please check if your router first suports usb ports
Jul 22, 2008 | Paradyne 6381 ADSL2+/ReachDSL Router...
Lost connection over wired LAN - wireless OK
A common fix is to re-set the modem. Just unplug the power to the modem for 30 seconds, then re-connect it. You could also bypass the router momentarily to see if the modem is working. Just connect one of the computers directly to the modem to verify connectivity. Your control panel should also have a utility to renew the IP address.
Sep 13, 2007 | SMC Barricade g SMCWBR14-G2 Wireless...
Port switch problem
Binz, have you tried doing a hard reset on the router, hold the reset button 30 seconds, login in will be user: admin password:admin -- if its an older model user blank password:admin, if that doesnt work, try updating your firmware, you didnt specify your router model, or I would link you to a firmware update
Aug 28, 2007 | Linksys BEFSX41 Router (DHBEFSX41)
Smc2804wbr barricade G
Check the network settings on the computer connecting to this ports (speed, half or full duplex, etc)
Aug 03, 2007 | SMC Barricade g SMC2804WBRP-G Wireless...
SMC Barricade SMC7401BRA (SMC7401BRA-ADSL) Bridge/Router Logo
114 people viewed this question
Top SMC Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a SMC Computer and Internet Expert? Answer questions, earn points and help others
