Question about Compaq Evo N620c Notebook
No monitor n620c loptop
I have a n620c loptop, when i turned it on no monitor but when i plugged it in an external monitor its working but sometimes its getting automatic standby! can you help me out of this guys/gals? thanks!
  • sigmund sante
    sigmund sante Apr 22, 2009
    i've already did it but nothing happens! Just a blank black screen appears in my n620c! also when i close the lid of my loptop it does not standby but the setting for this is in default mode!
  • 155 Answers
To switch between monitor modes (internal/external) you have to press the key combination Fn+F4 (or F8) or the F key with a dual monitor icon printed on it. This happens when you use the laptop with an external monitor or projector, and you forget to return to the internal monitor mode.
Posted on Apr 22, 2009
Msi loptop no displays problem
Hi
I'm sorry but I could not find anything about this motherboard / machine. However most laptops have the facility to plug in a monitor via a VGA port on the machine. If doing this works then check settings on your computer to ensure that it is not set to only display on an external monitor. If it doesn't work, try booting your computer in "safe" mode (Press F8 during boot) if you can see anything either during boot or with ext monitor. If all these fail then probably the graphics section of your motherboard has probably failed and a new motherboard will be required to solve the problem unless the graphics card is separate (unusual in a laptop of this age).
Regards
Jul 15, 2014 | MSI KM2M Combo-L (MS-6738-010) Motherboard
My toughbook is on but the careen is black
Did you try to attach an external monitor to the VGA port?
Please start by making sure the Power on the Toughbook
is completely OFF. Then plug-in an external monitor to the
VGA port. Turn the monitor on first, then power-on the
CF28 Toughbook. (This is the same procedure for any
model of Toughbook). The external monitor only may turn on,
or sometimes both the external monitor AND internal LCD
may turn on simultaneously. If the external monitor does turn on,
then you may be faced with a burnt-out LCD.
Good Luck.
Regards,
Richard - Montreal Based
Authorized Panasonic Toughbook Dealer since 1989.
Dec 12, 2013 | Panasonic Toughbook 28 Notebook
THE SCREEN IS DARK. tHE LOPTOP TURNS ON BUT HAS NO DISPLAY. IT WILL NOT WORK ON EXTERNAL DISPLAY.
Your video card is bad. A bad LCD or backlight lamp would not prevent an external monitor from working. Even without a hard drive or Windows installed you would still get a text display on your screen. Some laptops have replaceable video cards but some are soldered to the motherboard and can't be replaced. This is a job for a repair shop, not a DIY project.
Sep 17, 2009 | Gateway Computers & Internet
No monitor display on my laptop notebook
TRY TO CONNECT THE VGA OF YOU EXTERNAL MONITOR, IF THER IS A DISPLAY THE LCD OF YOU LOPTOP ARE DIFFECTIVE
Aug 18, 2009 | Compaq Presario Notebook
My Compaq N620c powers up but only shows only a black screen
may be faulty processor, loose memory stick or a faulty power supply.
Jul 13, 2009 | Compaq Evo N620c Notebook
Gateway model m6307 screen won't turn on, the laptop turns on but not the screen
Remove the battery and then put it back after about 5 mins. Plug it into mains and see if that solves it. Sometimes when laptops "hang" like this-removing the battery solves it.
Jun 21, 2009 | Gateway M6307 Notebook
No monitor on screen but when plugged in external monitor it works but sometimes getting automatic standby mode
hi there,
take that oppurtunity when your on safe mode,goto system restore and have your system back when it was on normal operation,try it other than reinstalling your system,i think this is not a hardware problem from your monitor,doing this in all program,go to accessories,then system tools,then go to system restore click it and have select a previuos date that your computer work normal say" on april 1,then click it have it process just keep patience there a couple time to process this until the computer will tell you it was finished,just follow some instruction,maybe some file are missing on your vide card to hook up the monitor.have a nice day
Apr 22, 2009 | Computers & Internet
Powering
This is usually a sign of bad ram. remove the ram cover underneath, pull aside the pop out clips and remove the ram. hold the ram by its side and try not to touch the 'gold fingers'. Clean it / them with a soft clean paint brush along with their holders and re-insert. If this does not work and you have 2 sticks of ram then try each one on its own in one slot,then the other slot, turning on each time to identify the faulty module.
If this is no joy I would suspect the CPU. It could also be the motherboard video chip which is not repairable without a new motherboard but this is doubtful as it is not a common fault on this laptop.
Hope this helps some.
sparkyuiop.
Nov 21, 2008 | Compaq Evo N620c Notebook
Unable to use intex external TV tuner with acer 19''
Frontech external Miracle TV tuner not working with LCD(ACER 15") monitor. Error msg "input format not suppoting". But CRT monitor (samsung 14") is working with the same.
Pl give advice mr.reghu@yahoo.com
Jan 11, 2008 | Acer AL1916W 19" LCD Monitor
Wont post
after turning on wait for a moment.. about 5 mins. then press fn+f4
Jan 04, 2008 | Compaq Presario 700 470024-192 Notebook
Compaq Evo N620c Notebook Logo
145 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
