Question about Garmin eTrex Vista GPS Receiver
No change time
Dear Sir ,
I have a problem for GPS eTrex vista .It is showed 17-AUG-25 without currently date.
Pls give me advice how to do.
Thks,
Orchid
You will need to backup all of your tracks, waypoints and routes to your PC. With the unit off, hold down the page, enter (joystick), and find buttons for 5 to 7 seconds while power up at the same time. Then go outside and let the unit get a fix on the satellites. This will fix the date problem. Once done go to the main menu and select setup and the system. Make sure WAAS is disabled. If you enable this option the date will get messed up again and you will have to do this all over. There was supposed to be a firmware upgrade that fixed this problem, however I found after flashing the firmware update, the date problem still occurs if WAAS is enabled.span.jajahWrapper { font-size:1em; color:#B11196; text-decoration:underline; } a.jajahLink { color:#000000; text-decoration:none; } span.jajahInLink:hover { background-color:#B11196; }
Posted on Jun 20, 2009
When do Flybe fly to Verona Italy from Southampton
Flybe Timetable
BE1223 07:35 10:55 . . W . . . . - - 16-Aug-17 - 30-Aug-17 BE1223 10:00 13:15 . . W . . . . - - 06-Sep-17 - 27-Sep-17 BE1225 10:05 13:25 . . . . . Sa . - - 02-Sep-17 - 23-Sep-17 BE1223 10:05 13:25 . . W . . Sa . - - 12-May-18 - 16-Jun-18 BE1225 10:10 13:30 . . . . . Sa . - - 19-Aug-17 - 26-Aug-17 BE1223 15:25 18:45 . . . . . Sa . - - 19-Aug-17 - 16-Sep-17 BE1225 15:25 18:45 . . . . . Sa . - - 12-May-18 - 16-Jun-18
Sep 13, 2017 | Cars & Trucks
Garmin eTrex Vista HCx searches for satellites but doesn't find any, since yesterday. Device has worked fine for a few years, has the latest firmware
I have the same problem. Satellite screen shows nothing except the rings. When I open the unit, one of the chip looks like broken; its label says K43 and V5.
Aug 09, 2009 | Garmin eTrex Vista HCx Handheld GPS...
Etrex Hcx Vista will no longer power on.
two day old unit is under warranty for replacement take it back to the store and get it replaced and be firm!
Jul 31, 2009 | Garmin eTrex Vista HCx Handheld GPS...
Garmin eTrex Vista Cx won't turn on
Call Garmin customer service, they are wonderful. My rubber thing around the outside became loose,and they sent me a new unit, even though it was almost 2 years old.
Apr 11, 2009 | Garmin eTrex Vista Cx GPS Receiver
My eTREX VISTA won't get a satelite fix any more
The unit needs to have the screen facing up. The unit will not read if it is vertical. Garmin cust serv finally helped me with that one. Once you turn on the unit, it could take up to 20 minutes (usually about 3) to grab satelites.
Mar 26, 2009 | Garmin eTrex Vista Cx GPS Receiver
I have no CD software but i want to install online software, pls
There is no software for your etrex GPS to install on your computer. You can, however, purchase Garmin maps to install onto your GPS. When you purchase this mapping software, it will include a copy of Mapsource, which is used to upload and download tracks and waypoints to your unit.
Mar 04, 2009 | Garmin eTrex Vista GPS Receiver
Etrex reset instrucitons
If your Garmin eTrex is a Legend and you want to do a "Reset", pls try:
Hard Reset:
With the unit turned off, press and hold the follow buttons: PAGE + Enter on the click stick. Then press and release the POWER. The unit will power up asking if you want to release all user data. Select yes, and the unit will be reset. After the master reset, place your unit outside, so that it has a clear view of the sky for 25 to 30 minutes for the unit to acquire new almanac data.
This was originally posted here and a wealth of other Legend information.
Alternately, this has been posted here at FixYa as well. Pls see this post.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jul 04, 2008 | Garmin eTrex Legend GPS Receiver
ETrex Vista shows incorrect date
Thanks for the great advice. My problem is fixed!! Yay!
Nov 18, 2007 | Garmin ETREXVISTA GPS Receiver
Garmin Etrex Vista Date problem
Thanks to a hint from a user on another web forum, I have found a fix, at least for now.
Specifically, a normal "master rest" on the eTrex Vista is accomplished by holding down the "Page" button and "Enter" (i.e. the click stick) while powering up. You are prompted that a full reset will occur, and after confirming, the machine is reset. However, in my case, this achieved a full reset, but did not fix the date problem.
However, the undocumented "super master reset" on the eTrex Vista is achieved by simultaneously holding down the "Page, "Enter" and "Find" buttons while powering up. You have to hold all buttons in for about 5 to 7 seconds, and you DON'T get the warning message, but when the machine finally restarts, it is fully reset. After acquiring a satellite fix (took several minutes) - lo and behold - my time AND date both seem to be correct!
Oddly, neither Garmin tech support nor the local reseller seemed to know about this method of REALLY resetting the machine - I will pass on the information to them, for future reference.
The link which documents the "super master reset" procedure is here: http://www.gpsinformation.org/dale/secret.htm#reset
Hope this might also help other eTrex Vista owners who are experiencing the same date problem.
Nov 17, 2007 | Garmin eTrex Vista GPS Receiver
Garmin eTrex Legend
Do the following: 1 - Make sure you have fresh batteries in the unit and turn the unit on. 2 - Check the GPS date and Time. On the Main Menu at the bottom of the screen, you can see a date and time. If the date and time are not current, then the clock is your problem. You will have to wait for the almanac information to be updated. Details are below in a later section. 3 - Make sure your GPS is in the Normal Mode and not a demo mode. Verify other systems settings. Go to the main menu and click on Setup icon. From the Setup screen, access the System screen icon. Verify the following settings: GPS: normal WAAS: Enabled Language: English or your choice. Battery: Set according to your battery types. 4 - Check your GPSs Version Software. Go to the main menu and click on Setup icon. From the Setup screen, access the System screen icon. From the System screen, access the sub-menu icon in the upper right bar. Select "Software Version" from the list. Verify the actual software version for me. The latest version available for the eTrex Legend is version 3.90 dated March 2008. http://www8.garmin.com/support/download_details.jsp?id=711 Update the unit using this latest software and using Garmin's Webupdater. http://www8.garmin.com/products/webupdater/howtoinstall.jsp If that won't work, use the following download page to access the latest software updates per units. http://www8.garmin.com/support/blosp.jsp 5 - Resetting your GPS clock and almanac information Next you may need to acclimate your unit to a new date and time (almanac information). If you had your unit off and without batteries for over a month since you last accessed satellites, then your clock and almanac information may be incorrect. Even Garmin acknowledges this problem after software updates and the problem with accessing satellites. They state: "unit data including alamanac information may be incorrect or cleared. Back up all user data before upgrading. After installation is complete, place unit with a clear view of the sky for 15-30 minutes to re-acquire almanac data. " I know of no way to reset the clock using the GPS menus. All I can suggest is that you do the following: A - turn the unit on and wait 5 minutes or so for the "Poor Satellite Reception" screen to appear. See page 7 of the owner's manual. B - Set the "new location" to your area using the map when the "poor satellite reception screen" appears. Be sure to use the "map" option and not the "automatic". C - Set the GPS outside with a clear view of the sky. Check on it every 10 minutes. When the "Poor Satellite Reception" screen appears again, then click on "Restart Search". The "Restart Search" option is used when the date provided in the GPS is not today's date. (See page 7 of the Owner's manual for an example) Legend Owners Manual: http://www8.garmin.com/manuals/eTrexLegend_OwnersManual.pdf D - Once the GPS can track 4 satellites, then the clock should reset and you should be fine. This process could take up to an hour. I have had this problem with my eTrex Vista and eTrex Legend (both backup GPSs) and resolved it by having the clock reset. In fact, I just tried my eTrex Legend today after not using it for many months and storing it without batteries and it had this same problem. I followed the steps above to fix the problem. This took about 35 minutes.
Mar 28, 2007 | Garmin eTrex Legend GPS Receiver
Garmin eTrex Vista GPS Receiver Logo
396 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
