Usb 2.0 myflash disk not working in my computer
  • NitrusInc
    NitrusInc May 11, 2010
    Please let us know which Operating System you are using.
    If you are using Windows, you can find the version like this:
    Press and Hold the "Windows Logo Key on your keyboard" (Four wavy squares) + Press the "Pause Break" Key and release both.
  • 158 Answers
Hey you need to install the latest chipset driver of your motherboard and also the usb driver.
You can get this driver from your motherboard brand website.
Posted on Apr 22, 2009
Version on a flash usb formats myflash 16gb couss i have error
you could run the chkdsk utility
click start control panel administrive tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start or you might tick one box then return after its finished the first repair then return and tick the second box you should not do anything while the chkdsk utility is in progress any input may damage this drive
hope this helps you
Aug 30, 2011 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
How to rewmove write protected
If you have garantee from manufacture, use it. If not... you can find program for format you flash drive, but you need to know your manufacture and chipset on your flash drive. for example. I have MyFlash from A-Data, chipset/controller is USBest UT161-T6G. I found a program to unlock my flash drive. Good luck to you!
Aug 18, 2011 | Electronics - Others
I have a Hitachi external USB hard disk 320 GB. it was working fine at may laptop but when i tried using it with computer, the Windows cannot detect the USB Drive. i tried it with 2 computers. but its...
i have a Hitachi external USB hard disk 320 GB it was working fine at may laptop but when i tried using it with the computer ; the windows cannot detect the USB Drive . i tried it with 2 computer . but its still the same .pleas help i badly need my files
Dec 05, 2010 | Hitachi USB 2.0 to IDE 1.8" Aluminum...
Will not format - unknown capacity -
it's works on unknown capacity format problem
Requirements: A "corrupt" USB thumb/flash drive, and windows vista/7.
First of all, RESTART YOUR PC...(this is the only way it worked for me...hopefully it works the same for you)
1. Plug-in your USB flash drive to USB port.
2. Open Command Prompt with admin rights. Use any of the below methods to open Command Prompt.
*Type cmd in Start menu*
3. You need to know about the USB drive a little bit. Type in the following commands in the command prompt:
>>> First type DISKPART and hit enter to see the below message. (this opens the disk-partition manager)
>>> Next type LIST DISK command and note down YOUR FLASH DRIVE'S Disk number (eg: Disk 1). BE CAREFUL NOT TO CHOOSE YOUR PRIMARY HARD-DRIVE.
4. Next type all the below commands one by one. Here I assume that your disk drive no is "Disk 1".If you have Disk 2 as your USB flash drive then use Disk 2.Refer the above step to confirm it.
So below are the commands you need to type and execute one by one:
SELECT DISK 1
CLEAN
CREATE PARTITION PRIMARY
SELECT PARTITION 1
ASSIGN
FORMAT FS=NTFS
(Format process may take few minutes)
EXIT
If you did everything exactly, then your USB drive should be goos as new.
Nov 27, 2010 | Dane-Elec DaneElec 4GB USB Drive Copper...
I have a hitachi 500gb portable simpledrive and i have already connected both the usb cables to 2 different usb ports and the other end to the drive. it is still not detected. im using an old computer,...
Can you try connecting it to a different computer?
If it still does not work, then you have a "hardware" problem.
Remove the disk-drive from the enclosure, and temporarily attach it as a "slave" disk-drive in a desktop computer, to see if bypassing the USB-to-disk-drive interface will bypass the problem.
Nov 15, 2010 | Hitachi ( 0A30229-20pk) 400 GB Hard Drive
My disk on key does not work the computer does
1. Go to Start>> Right click My Computer>> Manage>> Device Manager 2. Expand the USB Controller section 3. Right click and Uninstall all of the listed USB devices 4. Reboot the system
Feb 28, 2010 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
Connect external hard disk IBM travel star 80GB USB port 2
Unless it's windows 98 you don't need a driver. If your computer can't see it, it's probably broken. Try plugging it in to another computer and see if it can see it
Oct 01, 2009 | IBM TravelStar 40GN 40 GB Hard Drive
My USB flashdrive cannot be opened
have you tried it on a different usb port? if that doesnt work you may also try it on a computer
Jul 09, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Scandisk Cruzer has loaded but can't be seen in My Computer
1. Download this tool:
http://dl.dropbox.com/u/4040651/HPUSBFW_2.2.3_MASTER.exe
2. Format
(Before removing USB flash drive click on the Safely Remove
Hardware icon and then click on USB flash drive you want to remove)
Apr 04, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Universal Serial Bus can't read flash disk
update the drivers sometimes thats all thats needed, or uninstall the flash disc and put into a different usb port
Mar 03, 2009 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
