Question about Sharp Aquos LC-46D62U 46 in. LCD HDTV
Screen damaged from fall, colored vert lines on left side from the damge
46" Sharp Aquos : Feel off the stand and damaged the screen about 14 inches from the left side and 6 inches from the top. Colored vertical lines run from top to bottom in that space of damage. The screen is not punctured but it shows damage beneath the surface. Is it a bust to try to have it fixed?
  • reji_farrar Apr 22, 2009
    Where can I get a replacement LCD screen for an Aquos 46in and how much?
  • 41 Answers
Unfortunately the LCD panel would need to be replaced. Even if there is not any signs of damage to the outside portion of the panel, one of the inner screens may have been fractured. I am not sure if the panel would be available because if i'm not mistaken Sharp just started making replacement panels.
Posted on Apr 22, 2009
    New Friend:
SCREEN DAMAGE FROM FALL
Posted on Dec 13, 2012
When tv is turned on you get poicture and sound but there are broken horizontal lines from top to bottom of screen. this occurs on all hdmi inputsincluding roku and dvd player.
How to fix lcd lines on Sharp tv screen, hdmi video board ...
? 3:43
https://www.youtube.com/watch?v=cHki4D0EwOo
May 24, 2014 - Uploaded by Tampatec
How to fix LCD lines on Sharp TV screen, hdmi video board easy ... Make Money From Your Broken Cracked LCD LED PLASMATV ... TV Repair Help for Vertical & Horizontal Lines on Your TV Screen ... Sharp Aquos LC-32 37 46 52DH65E 66E 77E - NoPic/Sound with ... Get video URL at current time.
comments on LCD Display Symptoms and causes. - YouTube
https://www.youtube.com/all_comments?v=DedJvyNm_s4
We have frequent outages causing the TV to turn on from standby mode when power returns. (These ..... Sharp LC-70LE650U 70-Inch Aquos TV TURNS ON WITH PERFECT PICTURE AND ..... It has thin horizontal lines on the top quarter of thescreen. ..... hey there, bought a 52lg60-ua had no image/picture but had sound.
? 2:01
https://www.youtube.com/watch?v=DedJvyNm_s4
Jan 28, 2016 | Sharp aquos 52 in lcd 1080p aquos 52...
What is causing vertical colored lines on the left 25% of my Sharp Aquos display?
Bad TCON board or Damaged screen. You can try and replace the TCON "Timing Control Board" and see if that helps. Replacing the Screen itself is very expensive and normally about half of what the unit cost new. Here is a video to give you a clue on how to do so, it is pretty easy when you know which board to replace.
LCD TV Repair Tutorial Con Board Common Symptoms Solutions How to Replace...
Jan 01, 2015 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Aquos LC-42D62U 42 in. HDTV LCD Television: 46 inch lcd screen hit with an object and cracked,...
Sorry,no! Because the LCD screen is about 90% of the LCD tv.No where else u will find a LCD screen for sale.Except the tvs corporation themself,LCD screen it limited produce,so the will charge u the LCD screen replacement same as a new tv or even more after the labors and LCD screen replacement.Ur tv now it only can be salvage as for electronics boards for parts that it.Not worth as a whole tv any more.
May 16, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Scratched sharp 46 inch lcd screen can it be replaced
The lcd screen is the most expensive component of the lcd screen/tv/monitor.
It makes no sense to try and replace it as first of all you won`t be able to find the part number required to do that job (e.g. the screens are internally made by sharp // special orders are placed to companies that only start the process for orders greater than tens of thousands of items) and secondly after a lcd panel has been replaced / installed you need to configure the colors, luminosity, contrast, balance etc through a data cable.
I am really sorry for your sharp lcd screen.
Nov 30, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Horizontal and vertical lines on the screen
i do no know take it back to the shop you got it from
Jun 04, 2009 | Sharp LC-46D64U 46 in. LCD HDTV
32 inch Sharp Aquos is less than a year old... I changed that channel and the picture was green or gray... i changed it again and got a normal picture once but now all channels are looking blank with a...
Contact Sharp to locate the nearest authorized Sharp servicer. Sharp Aquos servicers have to give Aquos TV top priority. Sharp provides very good and fast serice on these sets.
Apr 26, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
I can not remove the stand from my aquos 46 inch tv.
you will find 4 screws at the back of the tv about 4" inches from the bottom. lay the tv set flat on your bed. you will need a metric allen wrench to remove the 4 screw. once the 4 screws are removed slide the base away from the tv.
Jan 18, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Can not remove the stand to mount it on the wall
If the Aquos 46 is anything like the Aquos 42, the monitor is attached to the base with machine screws (bolts). They are located in the lower back portion of the monitor, probably need an Allen wrench to loosen and remove. Once that is done, the base can be removed from the monitor. Best way is to lay the monitor face down on a tabletop padded with foam, a quilt or blanket, etc to protect the screen as you work. Remove the stand from the monitor, not the monitor from the stand; it is easier and safer that way.
YIKES! Have a 46 inch 1080p Sharp Aquos. Last night when attaching the S video cable and was teetering the TV, the LCD screen scraped the corner of the stand and now there is 3 small black circles in the...
This will be horrible news, the screens are fragile and what happened is you broke the screen, And since this falls under customer abuse it will not be covered by warranty, so the cost of replacing that screen will run anywhere from $1200.00 to 1600.00
Feb 22, 2008 | Televison & Video
Sharp Aquos LC-46D62U 46 in. LCD HDTV Logo
625 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
