Question about Cub Cadet Street Sign- tractor lawn riding mower parts
I have a Cub cadet Z force. The hydraulic air breather cap on the right side has been missing for a while. After about 45 minutes of mowing I lose power in the right side. If I sit for a few minutes it will move again. I pulled the bottoms off the pumps. The hydraulic oil was yellow and runny on the right side. The left side was darker and thicker. I am trying to find out how much and what type of fluid I need.
    Genius:
  • 1,689 Answers
Hi foxlocks,
thank you for using fixya.
with regard to your query, you can use any synthetic based oil (80w 90) to have the old one changed, but it is strongly recommended that you use the Gear Oil that Cub Cadet manufactures or OEMed on. This Specific oil is available from the dealer where you got the Cadet.
or you can order it online with free shipping. Cub Cadet Gear Oil free shipping from Cub Cadet
As per the amount of oil to be used, you may want to refer to the owners manual or you can get the manual online as well.
Cub Cadet Operation Manual and Service Manual
Hope this helps, should you have other questions, please do not hesitate to let me know.
regards,
Voodoo
Posted on Apr 22, 2009
Cub Cadet HDS-2135 13B-214F100, runs great for 45 - 60 minutes then cuts out, only run on full choke, cannot mow but runs. Cools down works fine again
check the fuel filter and fuel line. it may need to be insulated to protect from heat. running on choke means it is starving for fuel . take the carburetor off and clean it real good. be sure the fuel lines are away from heat source.
Jun 09, 2016 | Cub Cadet Garden
Loses power while mowing
that wont cause your mower problem i think you have a dirty carb and fuel filter clean the fuel tank to put new gas from clean can in but to check charg system get voltmeter start engine let it run un hook positve side of battery put the red led of voltmeter on positive side and the black led to the negative side of battery and see how many volts produce 12 to 13.5 good below that replace regulator above that replace regulator
Jun 18, 2013 | Cub Cadet Garden
Cub cadet dies 20 minutes after starting
Slacke off the fuel filler cap when it starts to die, if it picks up again the fuel tank breather is blocked.
Apr 13, 2012 | Cub Cadet Garden
I have a series model 1018 cub cadet with electric mower deck. After mowing for about 45 minutes, I turned off the tractor for a few minutes. When I tried to restart, the battery was dead. I jumped started...
If you have access to an electric voltmeter, with it running check voltage at the battery. The engine should charge the battery and maintain system voltage so that the electic PTO will function. The electic PTO will not pull in if system voltage is too low.
Jul 08, 2011 | Cub Cadet Garden
I'm looking for help diagnosing a trouble with my model 1863 Cub Cadet, and wondered if you could help. The problem is that the engine sprays a very light mist of oil up under the hood and on top of the...
Check your crankcase breather (on side of block) . It could need cleaning/replacing and is loaded with oil/sludge causing this excessive blow-by to occur. Also check the tube running from the breather to the air filter housing. Make sure it is clean and clear.
Aug 11, 2010 | Cub Cadet Street Sign- tractor lawn riding...
I have an old Cub Cadet lawn tractor model 2155, where the PTO clutch stops working after about 15 minutes of mowing. It will re-engage after it stops, but will only mow for a couple hunder feet before it...
I have a Cub Cadet 2155 lawn tractor that mows great, purchase in 1999, however it started heating up about an hour into mowing and then I have to shut it down until cools. I have replaced the air filter & that did not work ?
Help.......Thanks
Aug 10, 2010 | Cub Cadet Street Sign- tractor lawn riding...
My cub cadet stops running 5-10 minuts
check the bowl for dirt or try putting in some stable
Jul 09, 2010 | Cub Cadet Street Sign- tractor lawn riding...
Cub Cadet 2165 Mower Shuts Down
did you happen to check the gas cap if the vent is clogged in it ? when it stalls loosen the gas cap and see if it makes a whoosh sound
Aug 31, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Cub cadet zforce
hello
check mower deck is not caked up with grass if it is it will not get enough air movementto force the grass up the chute
also try cutting in 2or3 passes so that you are not forcing too mush grass up the chute
hope this helps
Mar 13, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Cub Cadet Street Sign- tractor lawn riding mower parts Logo
110 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
Matt Olenzek
Matt Olenzek
roeb
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
