Question about Nikon Coolpix 4600 Digital Camera
Camera frozen when i went to take a picture it wouldn't work so i pushed a button saying something about a remote. It worked but then it froze with the lens out and the picture on the screen and now it won't chharge or turn off. I want to know what i can do or if i can take the memory card out because it was a clean one with nothing on it but it might damage the camera.
  • LeslieThauer Nov 12, 2007
    Had turned the camera on to take pictures and hag some time between pictures when the camera goes into to "sleep" mode, pushed the shutter button to "wake" it up and the camera froze with the lens out. Tried putting new batteries in and nothing .. still frozen .. HELP!!!
  • Anonymous Apr 13, 2008
    Same problem. Help,Help
(1) Load your camera with a freashly recharged battery.
(2) Switch on to see if it's working and still without the real time screen.
(3) Switch it off, and hold it tight in you palm with the LCD facing inward.
(4) Now, with you palm up, you should be able to see the model name 'CoolPix S6' under the lens and the flash.
(5) While holding the camera and aiming at the 'CoolPix S6', raise your other hand with the fist next to your ear.
(6) Match the aim as describe in(4) to the aim of your elbow 's protruded part and make pratice moves. Yes, you'are going to smack it
to your elbow.
(7) When you are ready, try first not to hit your elbow too hard once.
(8) Switch the camera on to check. If you have the 'Screen' now, congratulation! If not, repeat (4) to (8) but with a stronger impact
Force. You might have to try more times until your elbow could not take the sore.
Posted on Apr 13, 2008
  • Ann Golden
    Ann Golden Apr 23, 2016
    Thank you, this was very helpful. Ann Golden .
Same problem here! >_>
I wanted to check my pictures, and it completely frozen, so i took the memory card out but it still is frozen, with the lens out!
help! please!
Posted on Apr 11, 2008
SOURCE:
I need a new push button for an sl6195 rx
Heath-Zenith (I beleive they bought DESA) makes a battery remote push button bell that says its compatible with all Heath Zenith chimes. I bought one at Home Depot and it worked for my SL-6195-RX. (an on line doorbell seller and the Home Depot assoc all said it wouldn't work.)
UPC is 16963961975.
Item also shows a code "11G43" on a sticker on the back of the package.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/steven_7f54ab9063554f66
Nov 04, 2011 | Desa International White Wireless Plug In...
I tried to put my pictures onto my computer last night but the computer froze so I gave up but I took pictures this morning, and it was fine. Then the next picture I went to take nothing showed up on the...
Your coin battery that powers the memory system of your camera may be failing. This battery keeps your settings and powers your on board computer. Do not confuse this with your picture battery, as that only powers the lens and picture taking ability. The coin battery holds the program. See page 38 of your manual "Replacing the Date/Time battery."
Dec 20, 2010 | Canon EOS Rebel XS 35mm SLR Camera
You push the button and it will not take a picture. I put new batteries in it and it still will not take a picture.
My HTsi Plus never seems to be able to Auto Focus on a subject, so when you push the shutter button half-way, it just flashes the focus indicator (telling you it is unable to focus). Try switching over to the "Manual Focus" mode. On the front of the camera there is a button labeled "AF/M". Push that button to switch to manual focus. If the camera is in manual focus, the external LCD screen will say "M.Focus". Now try to snap a shot. If that still does not work, there may be something wrong with the camera or the lens. So, try using a different lens in manual focus mode. If it still does not work, then I would say the problem is with the camera itself.
Nov 15, 2010 | Minolta Maxxum HTsi Plus 35mm SLR Camera
I own a Fugifilm digital camera that is frozen
It swounds like the system battery may need replacing.
This is separate from the usual batteries that you change and charge up. look on the base of the camera to find a round disk with a groove in it. Inside is a button battery CR2032 or similar. This is the battery that controls all the setting you have set for brightness contrast number continuity etc etc. replace this noting the way it came out + up or down and i think your problem may be solved for abot $4.00
please rate my help++++Thanks for using FIXYA
May 08, 2010 | Cameras
L730 Frozen screen.
Try this...remove the battery and memory card. Switch the on-off button to off. Press all the buttons. Insert the card and then the battery. Turn it on. Does it work now?
Sep 07, 2009 | Samsung NV10 Digital Camera
Frozen Camera
Common problem.
Part called "Aperture Base" went bad and needs to be replaced.
Apr 02, 2009 | Minolta Maxxum 7000 35mm SLR Camera
Camera is frozen
Hello!!!
remove the battery and press the power button for few seconds and replace the batteries and try switching on!!!!
Aug 24, 2008 | Kodak EasyShare V1003 Digital Camera
Optio s6 frozen
By recharging the battery, and then restart the camera, it may just work.
Because you were working on a movie in the camera at the time it quit, that file may be corrupted.
It would be interesting to see what has happened on this problem.
Jul 22, 2008 | Pentax Optio M20 Digital Camera
Sansa 280 frozen
i froze up held lock button towards mic buton it has worked every time it happens.sansa280 16gb
Jan 09, 2008 | Audio Players & Recorders
Camera Frozen
I tried Option No.1 successfully when my Panasonic DMC-FZ7K froze once:
Option No1:
1. Try turning the camera on with the battery inserted.
2. Now remove the battery while the camera is on.
3. Flip the switch on the camera to off, then insert a fully charged battery. (Make sure that the battery's orientation is correct. Also make sure that the battery being used is not damaged).
4. Now flip the camera's switch to ON again.
Option No. 2:
If you can open the Setup menu then the camera can be reset which might help:
Turn on the camera.
1. Press MENU SET.
2. Press the left arrow button.
3. Press the down arrow button.
4. Press the right arrow button.
5. Now, press the up arrow button several times until the menu item named RESET is highlighted. Push the right arrow button and then select and set YES when the camera asks to be reset.
Oct 18, 2007 | Panasonic DMC-FX07 Digital Camera
Nikon Coolpix 4600 Digital Camera Logo
583 people viewed this question
Top Nikon Cameras Experts
Ric Donato
Ekse
pictureman4u
Are you a Nikon Camera Expert? Answer questions, earn points and help others
