Fuel Gauge does not register correctly.
GMC 2005 SLT - The low fuel light comes on and I fill the tank. The tank is not empty and after I fill the tank the gas gauge will only register 1/2 or 1/4 tank. What could I do to correct this problem. It is a problem not to know the correct amount of gas in the tank. I have been writing down the mileage whenever I fill up and watching the odometer so I could fill it after 200 miles has registered on the total miles. Any advice? Thanks, Bill Gary
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 123 Answers
Chances are the float is stuck.
it works pretty much like a toilet tank
try to bounce the rear of the vehicle up and down when tank is middle full
this may free the floatting device and start the real reading
Posted on Apr 22, 2009
Low fuel light comes on after i fill gas tank on 2001 gmc sonoma
Check to see if the panel fuel gauge is showing the correct amount of fuel. If that's ok then the fuel tank float may be bad.
May 09, 2015 | 2001 GMC Sonoma Extended Cab
GMC envoy after I filled gas tank the low fuel light came on and as I was driving it would go off than come back on after a few miles the check engine light come on stayed on and the low fuel light still...
You will need to replace the fuel level sensor which is in the fuel tank.They have a lot of problems because the metal fingers on the sensor wear off and gives you the incorrect readings.This will also cause the check engine light to come on.You will probably have a level sensor code.This will be a lot easier if the fuel level is down to about a quarter tank or less.Also you should be able to get just the level sensor and not have to get the complete fuel pump module.Good luck.
Dec 02, 2009 | 2005 GMC Envoy Xl
Fuel guage not working correctly
your gauge is part of the integrated unit in the fuel pump module
Sep 12, 2009 | 2005 Chevrolet Malibu
My 2000 gmc fuel gauge will sometimes go from full to empty causing the low fuel light to come on. Also it does not ever go below 1/2 tank mark.
needs the fuel pump assembly....gauge sender is incorporated in this module...pretty expensive but the only alternative is to fill it up and reset your trip odometer each time...you should be good for 250 miles or better before next fill up!! good luck!
Sep 04, 2009 | 2000 GMC Denali
I have a 2005 Saturn Relay. Everytime we fill-up the tank, the gas gauge will stay on empty and the low fuel light will come on. Finally, after about 30 min of driving the gauge will slowly go up and...
Pick up a diagnostics module with reset capabilities, plug it in to the port below the steering column and reset the error codes. This will reset the sending unit and it should read correctly after the rest. I had a similar problem and this inexpensive solution fixed the issue. Saved or $500.00 in repair and diagnostics.
Jul 14, 2009 | 2005 Saturn Relay
Some of these GM's have a seperate fuel guage relay under the dash. Their not cheap. Since you could have anything from a bad sender in the tank to a bad relay its best to leave this to a professional. Next time this happens try smacking the fuel tank a few times hard. If the gauge goes up its most likely a sender in the tank issue. If nothing happens then it really needs to be diagnosed correctly.
Jul 14, 2009 | 2006 Isuzu Ascender
BMW X5 fuel guage doesn't register
hi will, it sounds like one or both of the fuel sending units has failed. the sender on the passenger side is responsible for reading empty to 1/2 tank, and the one on the driver's reads 1/2 to full. if the passenger sender is stuck down or failed, it could read empty when the tank is full. the senders are a pain to install correctly due to the installation angle. I have even seen techs at the dealer install them and have to reinstall them. i would recommend having both of the senders tested.
Apr 07, 2009 | TMI Products VizuaLogic 90A-79006-L563 BMW...
2003 Dodge Ram 1500 Fuel Gauge drops to empty while driving.
I have the same problem on my 2003 Dodge Ram 2500 5.7 Hemi. Also the gauge is sometimesslow to register after filling. Maybe 5 minutes.My neighbor has the same poblem with his 1999 Durango? I think this is a job for a recall.
Mar 23, 2009 | 1998 Dodge Ram 2500 2WD
2006 GMC Envoy XL gas gauge reads empty after filling, then slowly moves up after driving but will continue to lose pressure until it reads empty and the light is on, then the check engine light came...
Sending unit. Its all one unit including fuel pump, float, ect. The check engine light is because of the high or low resistance in the unit. Let me know if you have already fixed.. You have to drop the tank to get to it also.
Feb 24, 2009 | 2005 GMC Envoy Xl
49 people viewed this question
 Grubhead
Grubhead
