Question about Infinity Reference 7541a Car Audio Amplifier
Infinity Reference Amps stay illuminated
I just installed two amps in my truck...Infinity reference 475a and 1300a. When I turn the truck and receiver off the amps stay on and illuminated. Is this supposed to happen? I do have the remote power wired from each amp wired to the back of my kenwood receiver.
  • 655 Answers
Hello shaymus_hoos,
No, it isn't supposed to work that way. Although amps are usually wired with the positive directly to the vehicle battery, they aren't supposed to turn on unless power is supplied on the remote wire.
The problem is most likely in either the head unit or one of the amps. And if not corrected, the amps will sooner or later, completely drain the battery.
First see if it works properly with just one amp connected. Remove the remote turn-on from 1 amp at a time and test with the vehicle and head unit off and then on. If the problem is still there with just one amp connected, either the head unit is at fault or the remote wire is picking up 12V somewhere along it's path to the amps. Make sure you have it connected to the right wire on the Kenwood. Every Kenwood I've seen uses blue/white for the remote wire.
If both amps work OK separately, one of the amps is causing the problem. You may be able to correct it by using a relay to electrically separate the turn-on signal for each amp. You'll need a "double-throw, single-throw" type of relay. Here's a link to the Basic Car Audio Electronics web site that details the connections http://www.bcae1.com/. Connect the remote wire coming from the head unit to one side of the relay coil and ground the other side. Bring 12V positive from an "accessory" lead that is hot only when the ignition is in either the "ON" or "ACCESSORY" positions to one side of both sets of relay contacts (it doesn't matter which side). Connect the other sides of the relay contacts, one to each amp turn-on connector.
Hope this helps.
Posted on Apr 22, 2009
It can be possible to bi-amp a pair of Klipsch RB-81 with this receiver for stereo listening, and if yes, how...
Bi-amping indicated that you have two amps, one for the tweeters, adn another for the woofer, in a two way system. If you don't have two seperate amps, you can use the speaker A & B outputs to run seperate speaker llines to each set of speaker inputs, but that will not be true bi-amping. Another alternative is to use jumpers to connect the speaker inputs together, this not needing seperate amps. Here's a link to the owner's manual:
http://www.manualslib.com/manual/359882/Klipsch-Reference-Series-Rb-41-Ii.html#product-Reference%20Series%20RB-81%20II
Oct 14, 2013 | Sony STR-DH510 5.1 Channels Receiver
Infinity 1300a car amp won't turn off...
The possible area is definitely in the stanby switching circuit. A damage to the relay drive has made the power to be continuously on without the remote switch. You can have two solutions, one you can ignore the fault for the time being and connect a second relay fromt the system to trigger the relay and subsequently switch the amplifier main power. Or you must open the set and look in the remote switching area for a jammed relay, a faulty transistor drive or activation of the bias to the relay drive by a faulty component. Check this out with a good multimeter and you will solve the issue. I hope my advice helps. Good day
Jul 22, 2010 | Infinity Reference 1300a Car Audio...
My protect light wont turn off and my ground is good and all other wires are good also!
is your sub/speakers ok? unplug and probe the speakers to see if any of them are grounding out... or your amp my be shot...
Apr 30, 2010 | Infinity Reference 1300a Car Audio...
Protect light keeps comin on
MAKE SURE THE GROUND IS GOOD ON BODY OF CAR BOTH UNDER THE HOOD AND WHERE YOUR AMP IS GROUNDED
Apr 18, 2010 | Infinity Reference 1300a Car Audio...
What do you do when your amp keeps blowing fuses
First off which fuse is it? The inline fuse from the battery or the amplifiers power supply fuse? Blowing the main fuse from the battery is caused by either the load (your amp) drawing too much current or you have a short to ground somewhere. Maybe there is a tear in the 12Vdc line and it is shorting to the chassis of your car. If the amps power supply fuse is blowing as soon as it turns on your amp has a shorted power supply. This will require internal component changes by a technician. If it is blowing after operation at high volumes I would say change the impedance that the amp is driving. If you are at 2 ohm try to rewire your speakers for four ohm. (go from parallel to series wiring then bridge mono or operate the amp in stereo mode)
Feb 07, 2010 | Infinity Reference 1300a Car Audio...
Sound loss
bad system cofiguration too much load on rea amp
May 11, 2009 | Infinity 475A Car Audio Amplifier
Thunping coming from subs when car is turned off.
2 things to try, one. run your RCAs on the opposite side of the car as the positive wire. if you still hear the thumping try changing your RCAs. if you still hear the thumping, try a different anp or head unit. if you still hear the thumping, your subs are blown. best of luck
May 08, 2009 | Infinity Reference 1300a Car Audio...
INFINITY AMP PROTECTION LIGHT FLASHING
Overload maybe. If the amp is run at an improper impedence, the amp will shut down. If you are "CLIPPING" speakers / subwoofers the light will blink to indicate a hard clip . Example: 4ohm/2ohm stable amp with 4 ohm subs wired at 1 ohm.
Jan 28, 2009 | Infinity Reference 7541a Car Audio...
Infinity Reference 7541a Car Audio Amplifier Logo
186 people viewed this question
Top Infinity Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Colin Stickland
Colin Stickland
Are you an Infinity Car Audio and Video Expert? Answer questions, earn points and help others
